Commit c29fa7d7 authored by Jonathan Jenkins's avatar Jonathan Jenkins
extern C-ify headers
parent 1803c5a3
...@@ -7,6 +7,10 @@ ...@@ -7,6 +7,10 @@
#ifndef CODES_CALLBACK_H #ifndef CODES_CALLBACK_H
#define CODES_CALLBACK_H #define CODES_CALLBACK_H
#ifdef __cplusplus
extern "C" {
#endif
#include <assert.h> #include <assert.h>
#include "codes/lp-msg.h" #include "codes/lp-msg.h"
...@@ -83,6 +87,10 @@ struct codes_cb_params { ...@@ -83,6 +87,10 @@ struct codes_cb_params {
assert(_esize >= (_cb_info_ptr)->cb_ret_offset + sizeof(_ret_type)); \ assert(_esize >= (_cb_info_ptr)->cb_ret_offset + sizeof(_ret_type)); \
} while (0) } while (0)
#ifdef __cplusplus
#endif
#endif /* end of include guard: CODES_CALLBACK_H */ #endif /* end of include guard: CODES_CALLBACK_H */
...@@ -20,6 +20,10 @@ ...@@ -20,6 +20,10 @@
#ifndef CODES_JOBMAP_H #ifndef CODES_JOBMAP_H
#define CODES_JOBMAP_H #define CODES_JOBMAP_H
#ifdef __cplusplus
extern "C" {
#endif
/** type markers and parameter defs for jobmaps **/ /** type markers and parameter defs for jobmaps **/
enum codes_jobmap_type { enum codes_jobmap_type {
...@@ -80,6 +84,10 @@ int codes_jobmap_get_num_jobs(struct codes_jobmap_ctx const * c); ...@@ -80,6 +84,10 @@ int codes_jobmap_get_num_jobs(struct codes_jobmap_ctx const * c);
int codes_jobmap_get_num_ranks(int job_id, struct codes_jobmap_ctx const * c); int codes_jobmap_get_num_ranks(int job_id, struct codes_jobmap_ctx const * c);
#ifdef __cplusplus
#endif
#endif #endif
...@@ -13,6 +13,10 @@ ...@@ -13,6 +13,10 @@
#ifndef CODES_MAPPING_CONTEXT_H #ifndef CODES_MAPPING_CONTEXT_H
#define CODES_MAPPING_CONTEXT_H #define CODES_MAPPING_CONTEXT_H
#ifdef __cplusplus
extern "C" {
#endif
#include <stdbool.h> #include <stdbool.h>
#include <ross.h> #include <ross.h>
...@@ -101,6 +105,10 @@ char const * codes_mctx_get_annotation( ...@@ -101,6 +105,10 @@ char const * codes_mctx_get_annotation(
char const * dest_lp_name, char const * dest_lp_name,
tw_lpid sender_id); tw_lpid sender_id);
#ifdef __cplusplus
#endif
#endif /* end of include guard: CODES_MAPPING_CONTEXT_H */ #endif /* end of include guard: CODES_MAPPING_CONTEXT_H */
...@@ -12,6 +12,10 @@ ...@@ -12,6 +12,10 @@
#ifndef CODES_WORKLOAD_H #ifndef CODES_WORKLOAD_H
#define CODES_WORKLOAD_H #define CODES_WORKLOAD_H
#ifdef __cplusplus
extern "C" {
#endif
#include "configuration.h" #include "configuration.h"
...@@ -326,6 +330,10 @@ void codes_workload_add_method(struct codes_workload_method const * method); ...@@ -326,6 +330,10 @@ void codes_workload_add_method(struct codes_workload_method const * method);
* will shut down automatically once they have issued their last event. * will shut down automatically once they have issued their last event.
#ifdef __cplusplus
#endif
#endif /* CODES_WORKLOAD_H */ #endif /* CODES_WORKLOAD_H */
...@@ -8,6 +8,10 @@ ...@@ -8,6 +8,10 @@
#ifndef CODES_H #ifndef CODES_H
#define CODES_H #define CODES_H
#ifdef __cplusplus
extern "C" {
#endif
...@@ -90,6 +94,10 @@ static inline void codes_local_latency_reverse(tw_lp *lp) ...@@ -90,6 +94,10 @@ static inline void codes_local_latency_reverse(tw_lp *lp)
return; return;
#ifdef __cplusplus
#endif
#endif /* CODES_H */ #endif /* CODES_H */
...@@ -7,6 +7,14 @@ ...@@ -7,6 +7,14 @@
/* SUMMARY: /* SUMMARY:
* CODES custom mapping file for ROSS * CODES custom mapping file for ROSS
#ifndef CODES_MAPPING_H
#define CODES_MAPPING_H
#ifdef __cplusplus
extern "C" {
#endif
#include "codes.h" #include "codes.h"
#include "lp-type-lookup.h" #include "lp-type-lookup.h"
...@@ -220,6 +228,12 @@ int codes_mapping_get_anno_cid_by_name(char const * annotation); ...@@ -220,6 +228,12 @@ int codes_mapping_get_anno_cid_by_name(char const * annotation);
int codes_mapping_get_anno_cid_by_lpid(tw_lpid id); int codes_mapping_get_anno_cid_by_lpid(tw_lpid id);
char const * codes_mapping_get_anno_name_by_cid(int cid); char const * codes_mapping_get_anno_name_by_cid(int cid);
#ifdef __cplusplus
#endif
#endif
* Local variables: * Local variables:
* c-indent-level: 4 * c-indent-level: 4
#ifndef __CONFIGURATION_H__ #ifndef __CONFIGURATION_H__
#define __CONFIGURATION_H__ #define __CONFIGURATION_H__
#ifdef __cplusplus
extern "C" {
#endif
#include <stddef.h> #include <stddef.h>
#include <inttypes.h> #include <inttypes.h>
#include <mpi.h> #include <mpi.h>
...@@ -249,6 +253,10 @@ extern ConfigHandle config; ...@@ -249,6 +253,10 @@ extern ConfigHandle config;
extern config_lpgroups_t lpconf; extern config_lpgroups_t lpconf;
#ifdef __cplusplus
#endif
#endif #endif
#ifndef __JENKINS_HASH__ #ifndef __JENKINS_HASH__
#define __JENKINS_HASH__ #define __JENKINS_HASH__
#ifdef __cplusplus
extern "C" {
#endif
#include <sys/types.h> #include <sys/types.h>
#include <stdint.h> #include <stdint.h>
...@@ -39,6 +43,10 @@ void bj_hashlittle2( ...@@ -39,6 +43,10 @@ void bj_hashlittle2(
#define bj_hashmask(n) (bj_hashsize(n)-1) #define bj_hashmask(n) (bj_hashsize(n)-1)
#ifdef __cplusplus
#endif
#endif #endif
#ifndef __LS_MODEL__ #ifndef __LS_MODEL__
#define __LS_MODEL__ #define __LS_MODEL__
#ifdef __cplusplus
extern "C" {
#endif
#include "codes-callback.h" #include "codes-callback.h"
...@@ -110,6 +114,10 @@ void lsm_configure(void); ...@@ -110,6 +114,10 @@ void lsm_configure(void);
#define LSM_DEBUG 0 #define LSM_DEBUG 0
#ifdef __cplusplus
#endif
#endif #endif
#ifndef LP_IO_H #ifndef LP_IO_H
#define LP_IO_H #define LP_IO_H
#ifdef __cplusplus
extern "C" {
#endif
typedef char* lp_io_handle; typedef char* lp_io_handle;
...@@ -33,6 +37,10 @@ static inline char* lp_io_handle_to_dir(lp_io_handle handle) ...@@ -33,6 +37,10 @@ static inline char* lp_io_handle_to_dir(lp_io_handle handle)
return(strdup(handle)); return(strdup(handle));
#ifdef __cplusplus
#endif
#endif /* LP_IO_H */ #endif /* LP_IO_H */
#ifndef LP_MSG_H #ifndef LP_MSG_H
#define LP_MSG_H #define LP_MSG_H
#ifdef __cplusplus
extern "C" {
#endif
#include "ross.h" #include "ross.h"
/* It is good practice to always include the src LPID, a unique message /* It is good practice to always include the src LPID, a unique message
...@@ -24,6 +28,10 @@ typedef struct msg_header_s { ...@@ -24,6 +28,10 @@ typedef struct msg_header_s {
/* data structure utilities */ /* data structure utilities */
void msg_set_header(int magic, int event_type, tw_lpid src, msg_header *h); void msg_set_header(int magic, int event_type, tw_lpid src, msg_header *h);
#ifdef __cplusplus
#endif
#endif /* end of include guard: LP_MSG_H */ #endif /* end of include guard: LP_MSG_H */
#ifndef LP_TYPE_LOOKUP_H #ifndef LP_TYPE_LOOKUP_H
#define LP_TYPE_LOOKUP_H #define LP_TYPE_LOOKUP_H
#ifdef __cplusplus
extern "C" {
#endif
/* look up the lp type registered through lp_type_register. Mostly used /* look up the lp type registered through lp_type_register. Mostly used
...@@ -17,6 +21,10 @@ const tw_lptype* lp_type_lookup(const char* name); ...@@ -17,6 +21,10 @@ const tw_lptype* lp_type_lookup(const char* name);
/* register an LP with CODES/ROSS */ /* register an LP with CODES/ROSS */
void lp_type_register(const char* name, const tw_lptype* type); void lp_type_register(const char* name, const tw_lptype* type);
#ifdef __cplusplus
#endif
#endif /* LP_TYPE_LOOKUP_H */ #endif /* LP_TYPE_LOOKUP_H */
...@@ -10,6 +10,10 @@ ...@@ -10,6 +10,10 @@
#ifndef MODEL_NET_INSPECT_H #ifndef MODEL_NET_INSPECT_H
#define MODEL_NET_INSPECT_H #define MODEL_NET_INSPECT_H
#ifdef __cplusplus
extern "C" {
#endif
/* ALL FUNCTIONS /* ALL FUNCTIONS
* anno is the annotation specified in the configuration (NULL -> no * anno is the annotation specified in the configuration (NULL -> no
* annotation), while ignore_annotations is a flag controlling whether * annotation), while ignore_annotations is a flag controlling whether
...@@ -37,6 +41,10 @@ int model_net_torus_get_flat_id( ...@@ -37,6 +41,10 @@ int model_net_torus_get_flat_id(
const int * dim_lens, const int * dim_lens,
const int * dim_ids); const int * dim_ids);
#ifdef __cplusplus
#endif
#endif /* end of include guard: MODEL_NET_INSPECT_H */ #endif /* end of include guard: MODEL_NET_INSPECT_H */
#ifndef MODEL_NET_LP_H #ifndef MODEL_NET_LP_H
#define MODEL_NET_LP_H #define MODEL_NET_LP_H
#ifdef __cplusplus
extern "C" {
#endif
#include "model-net.h" #include "model-net.h"
...@@ -126,6 +130,10 @@ typedef struct model_net_wrap_msg { ...@@ -126,6 +130,10 @@ typedef struct model_net_wrap_msg {
} msg; } msg;
} model_net_wrap_msg; } model_net_wrap_msg;
#ifdef __cplusplus
#endif
#endif /* end of include guard: MODEL_NET_LP_H */ #endif /* end of include guard: MODEL_NET_LP_H */
#ifndef MODELNET_METHOD_H #ifndef MODELNET_METHOD_H
#define MODELNET_METHOD_H #define MODELNET_METHOD_H
#ifdef __cplusplus
extern "C" {
#endif
// forward decl of model_net_method since we currently have a circular include // forward decl of model_net_method since we currently have a circular include
...@@ -63,6 +67,10 @@ struct model_net_method ...@@ -63,6 +67,10 @@ struct model_net_method
extern struct model_net_method * method_array[]; extern struct model_net_method * method_array[];
#ifdef __cplusplus
#endif
#endif /* MODELNET_METHOD_H */ #endif /* MODELNET_METHOD_H */
...@@ -9,6 +9,10 @@ ...@@ -9,6 +9,10 @@
#ifndef MODEL_NET_SCHED_H #ifndef MODEL_NET_SCHED_H
#define MODEL_NET_SCHED_H #define MODEL_NET_SCHED_H
#ifdef __cplusplus
extern "C" {
#endif
...@@ -195,6 +199,10 @@ void model_net_sched_set_default_params(mn_sched_params *sched_params); ...@@ -195,6 +199,10 @@ void model_net_sched_set_default_params(mn_sched_params *sched_params);
extern char * sched_names[]; extern char * sched_names[];
#ifdef __cplusplus
#endif
#endif /* end of include guard: MODEL_NET_SCHED_H */ #endif /* end of include guard: MODEL_NET_SCHED_H */
#ifndef MODELNET_H #ifndef MODELNET_H
#define MODELNET_H #define MODELNET_H
#ifdef __cplusplus
extern "C" {
#endif
#include <codes/lp-type-lookup.h> #include <codes/lp-type-lookup.h>
#include <codes/configuration.h> #include <codes/configuration.h>
...@@ -396,6 +400,11 @@ void model_net_print_stats(tw_lpid lpid, mn_stats mn_stats_array[]); ...@@ -396,6 +400,11 @@ void model_net_print_stats(tw_lpid lpid, mn_stats mn_stats_array[]);
/* find model-net statistics */ /* find model-net statistics */
mn_stats* model_net_find_stats(char const * category, mn_stats mn_stats_array[]); mn_stats* model_net_find_stats(char const * category, mn_stats mn_stats_array[]);
#ifdef __cplusplus
#endif
#endif /* MODELNET_H */ #endif /* MODELNET_H */
#ifndef DRAGONFLY_H #ifndef DRAGONFLY_H
#define DRAGONFLY_H #define DRAGONFLY_H
#ifdef __cplusplus
extern "C" {
#endif
typedef struct terminal_message terminal_message; typedef struct terminal_message terminal_message;
...@@ -92,6 +96,10 @@ struct terminal_message ...@@ -92,6 +96,10 @@ struct terminal_message
tw_lpid next_stop; tw_lpid next_stop;
#ifdef __cplusplus
#endif
#endif /* end of include guard: DRAGONFLY_H */ #endif /* end of include guard: DRAGONFLY_H */
#ifndef LOGGP_H #ifndef LOGGP_H
#define LOGGP_H #define LOGGP_H
#ifdef __cplusplus
extern "C" {
#endif
#include "../model-net-sched.h" #include "../model-net-sched.h"
/* types of events that will constitute triton requests */ /* types of events that will constitute triton requests */
...@@ -45,6 +49,10 @@ struct loggp_message ...@@ -45,6 +49,10 @@ struct loggp_message
tw_stime recv_time_saved; tw_stime recv_time_saved;
#ifdef __cplusplus
#endif
#endif /* end of include guard: LOGGP_H */ #endif /* end of include guard: LOGGP_H */
#ifndef SIMPLENET_UPD_H #ifndef SIMPLENET_UPD_H
#define SIMPLENET_UPD_H #define SIMPLENET_UPD_H
#ifdef __cplusplus
extern "C" {
#endif
typedef struct sn_message sn_message; typedef struct sn_message sn_message;
...@@ -39,6 +43,10 @@ struct sn_message ...@@ -39,6 +43,10 @@ struct sn_message
#ifdef __cplusplus
#endif
#endif /* end of include guard: SIMPLENET_UPD_H */ #endif /* end of include guard: SIMPLENET_UPD_H */
#ifndef SIMPLEP2P_H #ifndef SIMPLEP2P_H
#define SIMPLEP2P_H #define SIMPLEP2P_H
#ifdef __cplusplus
extern "C" {
#endif
typedef struct sp_message sp_message; typedef struct sp_message sp_message;
enum sp_event_type enum sp_event_type
...@@ -47,6 +51,10 @@ struct sp_message ...@@ -47,6 +51,10 @@ struct sp_message
tw_stime recv_prev_idle_all_saved; tw_stime recv_prev_idle_all_saved;
#ifdef __cplusplus
#endif
#endif /* end of include guard: SIMPLEP2P_H */ #endif /* end of include guard: SIMPLEP2P_H */
#ifndef TORUS_H #ifndef TORUS_H
#define TORUS_H #define TORUS_H
#ifdef __cplusplus
extern "C" {
#endif
typedef enum nodes_event_t nodes_event_t; typedef enum nodes_event_t nodes_event_t;
typedef struct nodes_message nodes_message; typedef struct nodes_message nodes_message;
...@@ -90,6 +94,10 @@ struct nodes_message ...@@ -90,6 +94,10 @@ struct nodes_message
int remote_event_size_bytes; int remote_event_size_bytes;
#ifdef __cplusplus
#endif
#endif /* end of include guard: TORUS_H */ #endif /* end of include guard: TORUS_H */
...@@ -14,6 +14,10 @@ ...@@ -14,6 +14,10 @@
#ifndef SRC_COMMON_UTIL_QUICKHASH_H #ifndef SRC_COMMON_UTIL_QUICKHASH_H
#define SRC_COMMON_UTIL_QUICKHASH_H #define SRC_COMMON_UTIL_QUICKHASH_H
#ifdef __cplusplus
extern "C" {
#endif
#include <stdlib.h> #include <stdlib.h>
#include "codes/quicklist.h" #include "codes/quicklist.h"
...@@ -336,6 +340,10 @@ static inline int quickhash_null32_hash(void *k, int table_size) ...@@ -336,6 +340,10 @@ static inline int quickhash_null32_hash(void *k, int table_size)
return(int)(*tmp & (table_size - 1)); return(int)(*tmp & (table_size - 1));
#ifdef __cplusplus
#endif
#endif /* SRC_COMMON_UTIL_QUICKHASH_H */ #endif /* SRC_COMMON_UTIL_QUICKHASH_H */
...@@ -25,6 +25,10 @@ ...@@ -25,6 +25,10 @@
#ifndef QUICKLIST_H #ifndef QUICKLIST_H
#define QUICKLIST_H #define QUICKLIST_H
#ifdef __cplusplus
extern "C" {
#endif
struct qlist_head { struct qlist_head {
...@@ -289,4 +293,8 @@ static inline struct qlist_head * qlist_find( ...@@ -289,4 +293,8 @@ static inline struct qlist_head * qlist_find(
* vim: ts=8 sts=4 sw=4 expandtab * vim: ts=8 sts=4 sw=4 expandtab
#ifdef __cplusplus
#endif
#endif /* QUICKLIST_H */ #endif /* QUICKLIST_H */
#ifndef RC_STACK_H #ifndef RC_STACK_H
#define RC_STACK_H #define RC_STACK_H
#ifdef __cplusplus
