Commit 63d7ce1c authored by Jonathan Jenkins's avatar Jonathan Jenkins
version bump, changelog cleanup
parent 1237d2fd
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
# Process this file with autoconf to produce a configure script. # Process this file with autoconf to produce a configure script.
AC_PREREQ([2.67]) AC_PREREQ([2.67])
AC_INIT([codes], [0.5.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes], [0.5.1], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
AC_CANONICAL_TARGET AC_CANONICAL_TARGET
AC_CANONICAL_SYSTEM AC_CANONICAL_SYSTEM
0.5.0 0.5.1 (June 09, 2016)
network:
corrected link latency calculation in dragonfly model
printf argument mismatch in dragonfly model
refactors to the torus bandwidth calculation to mirror that of the other
networks (no functional change)
more robust type conversions in dragonfly (int sizes -> uint64_t)
0.5.0 (May 24, 2016)
general: general:
...@@ -25,7 +41,7 @@ modelnet now supports sampling at regular intervals. Dragonfly LPs can ...@@ -25,7 +41,7 @@ modelnet now supports sampling at regular intervals. Dragonfly LPs can
dragonfly and torus network models credit-based flow control has been updated. dragonfly and torus network models credit-based flow control has been updated.
Dragonfly model's adaptive routing algorithms have been updated. For details, Dragonfly model's adaptive routing algorithms have been updated. For details,
see paper "Enabling Parallel Simulation of Large-Scale HPC Network Systems", see paper "Enabling Parallel Simulation of Large-Scale HPC Network Systems",
M.Mubarak et al., at IEEE Trans. on Parallel and Distributed Systems (TPDS). M.Mubarak et al., at IEEE Trans. on Parallel and Distributed Systems (TPDS).
allow 0-byte messages in model-net. allow 0-byte messages in model-net.
...@@ -88,8 +104,18 @@ model_net_event_rc (use model_net_event_rc2, which will eventually be renamed ...@@ -88,8 +104,18 @@ model_net_event_rc (use model_net_event_rc2, which will eventually be renamed
codes_event_new (define your own bounds-checking macro if need be) codes_event_new (define your own bounds-checking macro if need be)
0.4.0 0.4.1 (September 30, 2015)
general:
fix compatibility with recent ROSS releases
0.4.0 (May 6, 2015)
codes-base codes-base
...@@ -215,7 +241,9 @@ Adding network workload test program for debugging ...@@ -215,7 +241,9 @@ Adding network workload test program for debugging
Updating MPI wait/wait_all code in replay tool Updating MPI wait/wait_all code in replay tool
0.3.0 ----------
0.3.0 (November 7, 2014)
Markdown is supported
0% or
Please register or to comment
