Commit ff5f4b51 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
adding missing pieces in change log
parent 257daea9
...@@ -15,11 +15,12 @@ networks: ...@@ -15,11 +15,12 @@ networks:
addition of the SlimFly network topology, corresponding to the Wolfe et al. addition of the SlimFly network topology, corresponding to the Wolfe et al.
paper "Modeling a Million-node Slim Fly Network using Parallel Discrete-event paper "Modeling a Million-node Slim Fly Network using Parallel Discrete-event
Simulation", to appear at SIGSIM-PADS'16. See ___ Simulation", to appear at SIGSIM-PADS'16. See README.slimfly.txt
(src/networks/model-net/doc).
modelnet now supports sampling at regular intervals. Dragonfly LPs can modelnet now supports sampling at regular intervals. Dragonfly LPs can
currently make use of this - others can be added based on demand. See currently make use of this - others can be added based on demand. See
___. (src/network-workloads/README_synthetic.txt).
allow 0-byte messages in model-net. allow 0-byte messages in model-net.
...@@ -50,7 +51,8 @@ removed scalatrace workload generator, which never made it to a usable state. ...@@ -50,7 +51,8 @@ removed scalatrace workload generator, which never made it to a usable state.
a new checkpoint IO workload generator has been added, based on the Daly paper a new checkpoint IO workload generator has been added, based on the Daly paper
"A higher order estimate of the optimum checkpoint interval for restart "A higher order estimate of the optimum checkpoint interval for restart
dumps" at Future Generation Computing Systems 2004. See ___. dumps" at Future Generation Computing Systems 2004. See README.codes-workload
(src/workload).
utilities: utilities:
Markdown is supported
0% or .
Please register or to comment
