Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Xin Wang
codes-dev
Commits
f18e903f
Commit
f18e903f
authored
Sep 17, 2015
by
Misbah Mubarak
Browse files
Minor updates to dragonfly model
parent
c6bc9f8a
Changes
3
Hide whitespace changes
Inline
Side-by-side
src/models/networks/model-net/dragonfly.c
View file @
f18e903f
@@ -922,7 +922,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
num_chunks
num_chunks
if
num_chunks
if
num_chunks
num_chunks
num_chunks
1
int
i
int
i
for
i
0
i
num_chunks
i
for
i
0
i
num_chunks
i
@@ -959,6 +959,10 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
int
i
total_event_size
int
i
total_event_size
int
num_chunks
msg
packet_size
p
chunk_size
int
num_chunks
msg
packet_size
p
chunk_size
if
msg
packet_size
s
params
chunk_size
num_chunks
if
msg
packet_size
s
params
chunk_size
num_chunks
if
num_chunks
num_chunks
1
msg
packet_ID
lp
gid
g_tw_nlp
s
packet_counter
msg
packet_ID
lp
gid
g_tw_nlp
s
packet_counter
msg
travel_start_time
tw_now
lp
msg
travel_start_time
tw_now
lp
msg
my_N_hop
0
msg
my_N_hop
0
@@ -1103,6 +1107,9 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
if
cur_entry
msg
packet_size
s
params
chunk_size
if
cur_entry
msg
packet_size
s
params
chunk_size
num_chunks
num_chunks
if
num_chunks
num_chunks
1
if
cur_entry
msg
chunk_id
num_chunks
1
if
cur_entry
msg
chunk_id
num_chunks
1
cur_entry
msg
local_event_size_bytes
0
cur_entry
msg
0
bf
c2
1
bf
c2
1
@@ -1187,6 +1194,8 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
int
num_chunks
msg
packet_size
s
params
chunk_size
int
num_chunks
msg
packet_size
s
params
chunk_size
if
msg
packet_size
s
params
chunk_size
if
msg
packet_size
s
params
chunk_size
num_chunks
num_chunks
if
num_chunks
num_chunks
1
completed_packets
completed_packets
@@ -1639,7 +1648,7 @@ void dragonfly_router_final(router_state * s,
tw_lp
lp
tw_lp
lp
free
s
global_channel
free
s
global_channel
char
stats_file
getenv
"TRACER_LINK_FILE"
char *stats_file = getenv("TRACER_LINK_FILE");
if(stats_file != NULL) {
FILE *fout = fopen(stats_file, "a");
const dragonfly_param *p = s->params;
@@ -1653,7 +1662,7 @@ void dragonfly_router_final(router_state * s,
fprintf(fout, "\n");
result = flock(fileno(fout), LOCK_UN);
fclose(fout);
fclose(fout);
int
i
j
int
i
j
for
i
0
i
s
params
radix
i
for
i
0
i
s
params
radix
i
for
j
0
j
3
j
for
j
0
j
3
j
src/models/networks/model-net/torus.c
View file @
f18e903f
@@ -983,6 +983,7 @@ static void packet_send( nodes_state * s,
if
s
buffer
tmp_dir
tmp_dim
2
0
s
params
buffer_size
if
s
buffer
tmp_dir
tmp_dim
2
0
s
params
buffer_size
bf
c2
1
bf
c2
1
msg
saved_src_dir
tmp_dir
msg
saved_src_dir
tmp_dir
msg
saved_src_dim
tmp_dim
msg
saved_src_dim
tmp_dim
@@ -1070,12 +1071,12 @@ static void packet_arrive( nodes_state * s,
nodes_message
m
nodes_message
m
mn_stats
stat
mn_stats
stat
credit_send
s
bf
lp
msg
msg
my_N_hop
msg
my_N_hop
ts
0
1
tw_rand_exponential
lp
rng
MEAN_INTERVAL
200
ts
0
1
tw_rand_exponential
lp
rng
MEAN_INTERVAL
200
if
msg
packet_ID
TRACE
if
msg
packet_ID
TRACE
printf
\n
packet arrived at lp %d final dest %d "
int
lp
gid
int
msg
dest_lp
printf
\n
int
lp
gid
int
msg
dest_lp
credit_send
s
bf
lp
msg
if
lp
gid
msg
dest_lp
if
lp
gid
msg
dest_lp
uint64_t
num_chunks
msg
packet_size
s
params
chunk_size
uint64_t
num_chunks
msg
packet_size
s
params
chunk_size
tests/conf/modelnet-test-dragonfly.conf
View file @
f18e903f
@@ -24,5 +24,5 @@ PARAMS
global_bandwidth
"4.7"
global_bandwidth
"4.7"
cn_bandwidth
"5.25"
cn_bandwidth
"5.25"
message_size
"320"
message_size
"320"
routing
minimal
routing
adaptive
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
