Commit b49a0715 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
some fixes to dragonfly model as suggested by UIUC folks
parent 57ddfd1b
...@@ -30,6 +30,8 @@ struct terminal_message ...@@ -30,6 +30,8 @@ struct terminal_message
unsigned int dest_terminal_id; unsigned int dest_terminal_id;
/* source terminal ID of the dragonfly */ /* source terminal ID of the dragonfly */
unsigned int src_terminal_id; unsigned int src_terminal_id;
/* local LP ID to calculate the radix of the sender node/router */
unsigned int local_id;
/* number of hops traversed by the packet */ /* number of hops traversed by the packet */
short my_N_hop; short my_N_hop;
/* Intermediate LP ID from which this message is coming */ /* Intermediate LP ID from which this message is coming */
...@@ -487,10 +487,12 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -487,10 +487,12 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw
int is_terminal = 0; int is_terminal = 0;
const dragonfly_param *p = s->params; const dragonfly_param *p = s->params;
int sender_radix;
// Notify sender terminal about available buffer space // Notify sender terminal about available buffer space
if(msg->last_hop == TERMINAL) if(msg->last_hop == TERMINAL)
dest = msg->src_terminal_id; dest = msg->src_terminal_id;
sender_radix = msg->local_id % p->num_cn;
//determine the time in ns to transfer the credit //determine the time in ns to transfer the credit
credit_delay = (1 / p->cn_bandwidth) * CREDIT_SIZE; credit_delay = (1 / p->cn_bandwidth) * CREDIT_SIZE;
type = T_BUFFER; type = T_BUFFER;
...@@ -499,11 +501,13 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -499,11 +501,13 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw
else if(msg->last_hop == GLOBAL) else if(msg->last_hop == GLOBAL)
dest = msg->intm_lp_id; dest = msg->intm_lp_id;
sender_radix = p->num_cn + (msg->local_id % p->num_routers);
credit_delay = (1 / p->global_bandwidth) * CREDIT_SIZE; credit_delay = (1 / p->global_bandwidth) * CREDIT_SIZE;
else if(msg->last_hop == LOCAL) else if(msg->last_hop == LOCAL)
sender_radix = p->num_cn + p->num_routers + (msg->local_id % p->num_routers);
credit_delay = (1/p->local_bandwidth) * CREDIT_SIZE; credit_delay = (1/p->local_bandwidth) * CREDIT_SIZE;
else else
...@@ -511,18 +515,19 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -511,18 +515,19 @@ void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw
// Assume it takes 0.1 ns of serialization latency for processing the credits in the queue // Assume it takes 0.1 ns of serialization latency for processing the credits in the queue
int output_port = msg->saved_vc / p->num_vcs; int output_port = msg->saved_vc / p->num_vcs;
msg->saved_available_time = s->next_credit_available_time[output_port];
s->next_credit_available_time[output_port] = maxd(tw_now(lp), s->next_credit_available_time[output_port]); msg->saved_available_time = s->next_credit_available_time[sender_radix];
s->next_credit_available_time[sender_radix] = maxd(tw_now(lp), s->next_credit_available_time[output_port]);
ts = credit_delay + 0.1 + tw_rand_exponential(lp->rng, (double)credit_delay/1000); ts = credit_delay + 0.1 + tw_rand_exponential(lp->rng, (double)credit_delay/1000);
s->next_credit_available_time[output_port]+=ts; s->next_credit_available_time[sender_radix]+=ts;
if (is_terminal){ if (is_terminal){
buf_e = model_net_method_event_new(dest, buf_e = model_net_method_event_new(dest,
s->next_credit_available_time[output_port] - tw_now(lp), lp, s->next_credit_available_time[sender_radix] - tw_now(lp), lp,
DRAGONFLY, (void**)&buf_msg, NULL); DRAGONFLY, (void**)&buf_msg, NULL);
else{ else{
buf_e = tw_event_new(dest, s->next_credit_available_time[output_port] - tw_now(lp) , lp); buf_e = tw_event_new(dest, s->next_credit_available_time[sender_radix] - tw_now(lp) , lp);
buf_msg = tw_event_data(buf_e); buf_msg = tw_event_data(buf_e);
buf_msg->vc_index = msg->saved_vc; buf_msg->vc_index = msg->saved_vc;
...@@ -665,6 +670,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * ...@@ -665,6 +670,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp *
m->last_hop = TERMINAL; m->last_hop = TERMINAL;
m->intm_group_id = -1; m->intm_group_id = -1;
m->local_event_size_bytes = 0; m->local_event_size_bytes = 0;
m->local_id = s->terminal_id;
tw_event_send(e); tw_event_send(e);
// Each chunk is 32B and the VC occupancy is in chunks to enable efficient flow control // Each chunk is 32B and the VC occupancy is in chunks to enable efficient flow control
...@@ -1367,7 +1373,6 @@ router_packet_send( router_state * s, ...@@ -1367,7 +1373,6 @@ router_packet_send( router_state * s,
output_port = get_output_port(s, bf, msg, lp, next_stop); output_port = get_output_port(s, bf, msg, lp, next_stop);
output_chan = output_port * s->params->num_vcs; output_chan = output_port * s->params->num_vcs;
// Even numbered channels for minimal routing // Even numbered channels for minimal routing
// Odd numbered channels for nonminimal routing // Odd numbered channels for nonminimal routing
// Separate the queue occupancy into minimal and non minimal virtual channels if the min & non min // Separate the queue occupancy into minimal and non minimal virtual channels if the min & non min
...@@ -1444,6 +1449,7 @@ if( msg->packet_ID == TRACK && next_stop != msg->dest_terminal_id && msg->chunk_ ...@@ -1444,6 +1449,7 @@ if( msg->packet_ID == TRACK && next_stop != msg->dest_terminal_id && msg->chunk_
m->last_hop = LOCAL; m->last_hop = LOCAL;
m->saved_vc = output_chan; m->saved_vc = output_chan;
m->local_id = s->router_id;
msg->old_vc = output_chan; msg->old_vc = output_chan;
m->intm_lp_id = lp->gid; m->intm_lp_id = lp->gid;
s->vc_occupancy[output_chan]++; s->vc_occupancy[output_chan]++;
Markdown is supported
0% or .
Please register or to comment
