Commit ab72e458 authored by Philip Carns's avatar Philip Carns
Browse files
add version of jenkins hash used by triton model
parent 5c67f8d1
#ifndef __JENKINS_HASH__
#define __JENKINS_HASH__
#include <sys/types.h>
#include <stdint.h>
/* This header declares and exports Bob Jenkins hash functions define in lookup3.c.
* lookup3.c was downloaded from: http://www.burtleburtle.net/bob/c/lookup3.c
* See: http://www.burtleburtle.net/bob/hash/doobs.html for more information.
* Export other functions in that library as necessary.
void bj_hashlittle2(
const void *key, /* the key to hash */
size_t length, /* length of the key */
uint32_t *pc, /* IN: primary initval, OUT: primary hash */
uint32_t *pb); /* IN: secondary initval, OUT: secondary hash */
/* bj_hashsize(shift) gives a hash table size that is a power of 2, good for bj_hashlittle2.
* shift values are:
* 1024 -> 10
* 4096 -> 12
* 16384 -> 14
* 65536 -> 16
* 262144 -> 18
* 1048576 -> 20
#define bj_hashsize(n) ((uint32_t)1<<(n))
/* bj_hashmask(n) gives a mask reasonable for returning a hash between 0 and the hashtable size.
#define bj_hashmask(n) (bj_hashsize(n)-1)
#endif
...@@ -59,7 +59,8 @@ nobase_include_HEADERS = \ ...@@ -59,7 +59,8 @@ nobase_include_HEADERS = \
codes/codes.h \ codes/codes.h \
codes/configuration.h \ codes/configuration.h \
codes/dotconf.h \ codes/dotconf.h \
codes/lp-io.h codes/lp-io.h \
codes/jenkins-hash.h
src_libcodes_base_a_SOURCES = \ src_libcodes_base_a_SOURCES = \
codes/codesparser.h \ codes/codesparser.h \
...@@ -99,6 +100,7 @@ src_libcodes_base_a_SOURCES = \ ...@@ -99,6 +100,7 @@ src_libcodes_base_a_SOURCES = \
src/util/configuration.c \ src/util/configuration.c \
src/util/dotconf.c \ src/util/dotconf.c \
src/util/lp-io.c \ src/util/lp-io.c \
src/util/lookup3.c \
codes/codeslogging.h \ codes/codeslogging.h \
src/logging/codeslogging.c \ src/logging/codeslogging.c \
codes/timeline.h \ codes/timeline.h \
#include "codes/jenkins-hash.h"
lookup3.c, by Bob Jenkins, May 2006, Public Domain.
These are functions for producing 32-bit hashes for hash table lookup.
hashword(), hashlittle(), hashlittle2(), hashbig(), mix(), and final()
are externally useful functions. Routines to test the hash are included
if SELF_TEST is defined. You can use this free for any purpose. It's in
the public domain. It has no warranty.
You probably want to use hashlittle(). hashlittle() and hashbig()
hash byte arrays. hashlittle() is faster than hashbig() on
little-endian machines. Intel and AMD are little-endian machines.
On second thought, you probably want hashlittle2(), which is identical to
hashlittle() except it returns two 32-bit hashes for the price of one.
You could implement hashbig2() if you wanted but I haven't bothered here.
If you want to find a hash of, say, exactly 7 integers, do
a = i1; b = i2; c = i3;
mix(a,b,c);
a += i4; b += i5; c += i6;
mix(a,b,c);
a += i7;
final(a,b,c);
then use c as the hash value. If you have a variable length array of
4-byte integers to hash, use hashword(). If you have a byte array (like
a character string), use hashlittle(). If you have several byte arrays, or
a mix of things, see the comments above hashlittle().
Why is this so big? I read 12 bytes at a time into 3 4-byte integers,
then mix those integers. This is fast (you can do a lot more thorough
mixing with 12*3 instructions on 3 integers than you can with 3 instructions
on 1 byte), but shoehorning those bytes into integers efficiently is messy.
#define SELF_TEST 1
#include <stdio.h> /* defines printf for tests */
#include <time.h> /* defines time_t for timings in the test */
#include <stdint.h> /* defines uint32_t etc */
#include <sys/param.h> /* attempt to define endianness */
#ifdef linux
# include <endian.h> /* attempt to define endianness */
#endif
* My best guess at if you are big-endian or little-endian. This may
* need adjustment.
#if (defined(__BYTE_ORDER) && defined(__LITTLE_ENDIAN) && \
__BYTE_ORDER == __LITTLE_ENDIAN) || \
(defined(i386) || defined(__i386__) || defined(__i486__) || \
defined(__i586__) || defined(__i686__) || defined(vax) || defined(MIPSEL))
# define HASH_LITTLE_ENDIAN 1
# define HASH_BIG_ENDIAN 0
#elif (defined(__BYTE_ORDER) && defined(__BIG_ENDIAN) && \
__BYTE_ORDER == __BIG_ENDIAN) || \
(defined(sparc) || defined(POWERPC) || defined(mc68000) || defined(sel))
# define HASH_LITTLE_ENDIAN 0
# define HASH_BIG_ENDIAN 1
#else
#endif
#define hashsize(n) ((uint32_t)1<<(n))
#define hashmask(n) (hashsize(n)-1)
#define rot(x,k) (((x)<<(k)) | ((x)>>(32-(k))))
mix -- mix 3 32-bit values reversibly.
This is reversible, so any information in (a,b,c) before mix() is
still in (a,b,c) after mix().
If four pairs of (a,b,c) inputs are run through mix(), or through
mix() in reverse, there are at least 32 bits of the output that
are sometimes the same for one pair and different for another pair.
This was tested for:
* pairs that differed by one bit, by two bits, in any combination
of top bits of (a,b,c), or in any combination of bottom bits of
(a,b,c).
* "differ" is defined as +, -, ^, or ~^. For + and -, I transformed
the output delta to a Gray code (a^(a>>1)) so a string of 1's (as
is commonly produced by subtraction) look like a single 1-bit
difference.
* the base values were pseudorandom, all zero but one bit set, or
all zero plus a counter that starts at zero.
Some k values for my "a-=c; a^=rot(c,k); c+=b;" arrangement that
satisfy this are
4 6 8 16 19 4
9 15 3 18 27 15
14 9 3 7 17 3
Well, "9 15 3 18 27 15" didn't quite get 32 bits diffing
for "differ" defined as + with a one-bit base and a two-bit delta. I
used http://burtleburtle.net/bob/hash/avalanche.html to choose
the operations, constants, and arrangements of the variables.
This does not achieve avalanche. There are input bits of (a,b,c)
that fail to affect some output bits of (a,b,c), especially of a. The
most thoroughly mixed value is c, but it doesn't really even achieve
avalanche in c.
This allows some parallelism. Read-after-writes are good at doubling
the number of bits affected, so the goal of mixing pulls in the opposite
direction as the goal of parallelism. I did what I could. Rotates
seem to cost as much as shifts on every machine I could lay my hands
on, and rotates are much kinder to the top and bottom bits, so I used
rotates.
#define mix(a,b,c) \
a -= c; a ^= rot(c, 4); c += b; \
b -= a; b ^= rot(a, 6); a += c; \
c -= b; c ^= rot(b, 8); b += a; \
a -= c; a ^= rot(c,16); c += b; \
b -= a; b ^= rot(a,19); a += c; \
c -= b; c ^= rot(b, 4); b += a; \
final -- final mixing of 3 32-bit values (a,b,c) into c
Pairs of (a,b,c) values differing in only a few bits will usually
produce values of c that look totally different. This was tested for
(a,b,c).
difference.
These constants passed:
14 11 25 16 4 14 24
12 14 25 16 4 14 24
and these came close:
4 8 15 26 3 22 24
10 8 15 26 3 22 24
11 8 15 26 3 22 24
#define final(a,b,c) \
c ^= b; c -= rot(b,14); \
a ^= c; a -= rot(c,11); \
b ^= a; b -= rot(a,25); \
c ^= b; c -= rot(b,16); \
a ^= c; a -= rot(c,4); \
b ^= a; b -= rot(a,14); \
c ^= b; c -= rot(b,24); \
* hashlittle2: return 2 32-bit hash values
* This is identical to hashlittle(), except it returns two 32-bit hash
* values instead of just one. This is good enough for hash table
* lookup with 2^^64 buckets, or if you want a second hash if you're not
* happy with the first, or if you want a probably-unique 64-bit ID for
* the key. *pc is better mixed than *pb, so use *pc first. If you want
* a 64-bit value do something like "*pc + (((uint64_t)*pb)<<32)".
uint32_t *pb) /* IN: secondary initval, OUT: secondary hash */
uint32_t a,b,c; /* internal state */
union { const void *ptr; size_t i; } u; /* needed for Mac Powerbook G4 */
/* Set up the internal state */
a = b = c = 0xdeadbeef + ((uint32_t)length) + *pc;
c += *pb;
u.ptr = key;
if (HASH_LITTLE_ENDIAN && ((u.i & 0x3) == 0)) {
const uint32_t *k = (const uint32_t *)key; /* read 32-bit chunks */
#ifdef VALGRIND
const uint8_t *k8;
#endif
/*------ all but last block: aligned reads and affect 32 bits of (a,b,c) */
while (length > 12)
a += k[0];
b += k[1];
c += k[2];
mix(a,b,c);
length -= 12;
k += 3;
/*----------------------------- handle the last (probably partial) block */
* "k[2]&0xffffff" actually reads beyond the end of the string, but
* then masks off the part it's not allowed to read. Because the
* string is aligned, the masked-off tail is in the same word as the
* rest of the string. Every machine with memory protection I've seen
* does it on word boundaries, so is OK with this. But VALGRIND will
* still catch it and complain. The masking trick does make the hash
* noticably faster for short strings (like English words).
#ifndef VALGRIND
switch(length)
case 12: c+=k[2]; b+=k[1]; a+=k[0]; break;
case 11: c+=k[2]&0xffffff; b+=k[1]; a+=k[0]; break;
case 10: c+=k[2]&0xffff; b+=k[1]; a+=k[0]; break;
case 9 : c+=k[2]&0xff; b+=k[1]; a+=k[0]; break;
case 8 : b+=k[1]; a+=k[0]; break;
case 7 : b+=k[1]&0xffffff; a+=k[0]; break;
case 6 : b+=k[1]&0xffff; a+=k[0]; break;
case 5 : b+=k[1]&0xff; a+=k[0]; break;
case 4 : a+=k[0]; break;
case 3 : a+=k[0]&0xffffff; break;
case 2 : a+=k[0]&0xffff; break;
case 1 : a+=k[0]&0xff; break;
case 0 : *pc=c; *pb=b; return; /* zero length strings require no mixing */
#else /* make valgrind happy */
k8 = (const uint8_t *)k;
switch(length)
case 11: c+=((uint32_t)k8[10])<<16; /* fall through */
case 10: c+=((uint32_t)k8[9])<<8; /* fall through */
case 9 : c+=k8[8]; /* fall through */
case 7 : b+=((uint32_t)k8[6])<<16; /* fall through */
case 6 : b+=((uint32_t)k8[5])<<8; /* fall through */
case 5 : b+=k8[4]; /* fall through */
case 3 : a+=((uint32_t)k8[2])<<16; /* fall through */
case 2 : a+=((uint32_t)k8[1])<<8; /* fall through */
case 1 : a+=k8[0]; break;
#endif /* !valgrind */
} else if (HASH_LITTLE_ENDIAN && ((u.i & 0x1) == 0)) {
const uint16_t *k = (const uint16_t *)key; /* read 16-bit chunks */
const uint8_t *k8;
/*--------------- all but last block: aligned reads and different mixing */
while (length > 12)
a += k[0] + (((uint32_t)k[1])<<16);
b += k[2] + (((uint32_t)k[3])<<16);
c += k[4] + (((uint32_t)k[5])<<16);
mix(a,b,c);
length -= 12;
k += 6;
switch(length)
case 12: c+=k[4]+(((uint32_t)k[5])<<16);
b+=k[2]+(((uint32_t)k[3])<<16);
a+=k[0]+(((uint32_t)k[1])<<16);
break;
case 10: c+=k[4];
break;
case 8 : b+=k[2]+(((uint32_t)k[3])<<16);
break;
case 6 : b+=k[2];
break;
case 4 : a+=k[0]+(((uint32_t)k[1])<<16);
break;
case 2 : a+=k[0];
break;
case 1 : a+=k8[0];
break;
} else { /* need to read the key one byte at a time */
const uint8_t *k = (const uint8_t *)key;
/*--------------- all but the last block: affect some 32 bits of (a,b,c) */
while (length > 12)
a += k[0];
a += ((uint32_t)k[1])<<8;
a += ((uint32_t)k[2])<<16;
a += ((uint32_t)k[3])<<24;
b += k[4];
b += ((uint32_t)k[5])<<8;
b += ((uint32_t)k[6])<<16;
b += ((uint32_t)k[7])<<24;
c += k[8];
c += ((uint32_t)k[9])<<8;
c += ((uint32_t)k[10])<<16;
c += ((uint32_t)k[11])<<24;
mix(a,b,c);
length -= 12;
k += 12;
/*-------------------------------- last block: affect all 32 bits of (c) */
switch(length) /* all the case statements fall through */
case 12: c+=((uint32_t)k[11])<<24;
case 11: c+=((uint32_t)k[10])<<16;
case 10: c+=((uint32_t)k[9])<<8;
case 9 : c+=k[8];
case 8 : b+=((uint32_t)k[7])<<24;
case 7 : b+=((uint32_t)k[6])<<16;
case 6 : b+=((uint32_t)k[5])<<8;
case 5 : b+=k[4];
case 4 : a+=((uint32_t)k[3])<<24;
case 3 : a+=((uint32_t)k[2])<<16;
case 2 : a+=((uint32_t)k[1])<<8;
case 1 : a+=k[0];
break;
final(a,b,c);
*pc=c; *pb=b;
Markdown is supported
0% or .
Please register or to comment
