Commit a6c7399d authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Adding safety check for dragonfly configuration
parent 2b01edc0
...@@ -287,6 +287,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -287,6 +287,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
char routing_str[MAX_NAME_LENGTH]; char routing_str[MAX_NAME_LENGTH];
configuration_get_value(&config, "PARAMS", "routing", anno, routing_str, configuration_get_value(&config, "PARAMS", "routing", anno, routing_str,
MAX_NAME_LENGTH); MAX_NAME_LENGTH);
...@@ -312,6 +313,8 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -312,6 +313,8 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
p->radix = p->num_vcs * p->radix = p->num_vcs *
(p->num_cn + p->num_global_channels + p->num_routers); (p->num_cn + p->num_global_channels + p->num_routers);
p->total_routers = p->num_groups * p->num_routers; p->total_routers = p->num_groups * p->num_routers;
p->total_terminals = p->total_routers * p->num_cn; p->total_terminals = p->total_routers * p->num_cn;
printf("\n Total nodes %d routers %d groups %d radix %d num_vc %d ", p->num_cn * p->total_routers, printf("\n Total nodes %d routers %d groups %d radix %d num_vc %d ", p->num_cn * p->total_routers,
p->total_routers, p->total_routers,
...@@ -1804,12 +1807,16 @@ void router_setup(router_state * r, tw_lp * lp) ...@@ -1804,12 +1807,16 @@ void router_setup(router_state * r, tw_lp * lp)
bj_hashlittle2(LP_METHOD_NM, strlen(LP_METHOD_NM), &h1, &h2); bj_hashlittle2(LP_METHOD_NM, strlen(LP_METHOD_NM), &h1, &h2);
router_magic_num = h1 + h2; router_magic_num = h1 + h2;
num_routers_per_mgrp = codes_mapping_get_lp_count (lp_group_name, 1, "dragonfly_router",
NULL, 0);
int num_grp_reps = codes_mapping_get_group_reps(lp_group_name);
char anno[MAX_NAME_LENGTH]; char anno[MAX_NAME_LENGTH];
codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL, codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL,
&mapping_type_id, anno, &mapping_rep_id, &mapping_offset); &mapping_type_id, anno, &mapping_rep_id, &mapping_offset);
NULL, 0);
if (anno[0] == '\0'){ if (anno[0] == '\0'){
r->anno = NULL; r->anno = NULL;
r->params = &all_params[num_params-1]; r->params = &all_params[num_params-1];
...@@ -1822,6 +1829,12 @@ void router_setup(router_state * r, tw_lp * lp) ...@@ -1822,6 +1829,12 @@ void router_setup(router_state * r, tw_lp * lp)
// shorthand // shorthand
const dragonfly_param *p = r->params; const dragonfly_param *p = r->params;
/* Checking for consistency of configuration */
if(p->total_routers != num_grp_reps * num_routers_per_mgrp)
tw_error(TW_LOC,
"\n Config error: num_routers specified %d total routers computed in the network %d does not match with repetitions * dragonfly_router %d ",
p->num_routers, p->total_routers, num_grp_reps * num_routers_per_mgrp);
r->router_id=mapping_rep_id * num_routers_per_mgrp + mapping_offset; r->router_id=mapping_rep_id * num_routers_per_mgrp + mapping_offset;
r->group_id=r->router_id/p->num_routers; r->group_id=r->router_id/p->num_routers;
Markdown is supported
0% or .
Please register or to comment
