Commit a349938c authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Adding congestion control in dragonfly (mostly comes from uiuc_tracer)
parent a78fee52
...@@ -40,6 +40,9 @@ struct terminal_message ...@@ -40,6 +40,9 @@ struct terminal_message
/* number of hops traversed by the packet */ /* number of hops traversed by the packet */
short my_N_hop; short my_N_hop;
short my_l_hop, my_g_hop;
short saved_channel;
/* Intermediate LP ID from which this message is coming */ /* Intermediate LP ID from which this message is coming */
unsigned int intm_lp_id; unsigned int intm_lp_id;
short new_vc; short new_vc;
...@@ -77,6 +80,7 @@ struct terminal_message ...@@ -77,6 +80,7 @@ struct terminal_message
/* LP ID of the sending node, has to be a network node in the dragonfly */ /* LP ID of the sending node, has to be a network node in the dragonfly */
tw_lpid sender_node; tw_lpid sender_node;
tw_lpid next_stop;
/* for reverse computation */ /* for reverse computation */
struct pending_router_msgs * saved_elem; struct pending_router_msgs * saved_elem;
This diff is collapsed.
...@@ -915,7 +915,7 @@ static void packet_generate( nodes_state * s, ...@@ -915,7 +915,7 @@ static void packet_generate( nodes_state * s,
m_gen_data_src = (char*)m_gen_data_src + msg->remote_event_size_bytes; m_gen_data_src = (char*)m_gen_data_src + msg->remote_event_size_bytes;
if (msg->local_event_size_bytes) if (msg->local_event_size_bytes)
memcpy(m_gen_data, m_gen_data_src, msg->local_event_size_bytes); memcpy(m_gen_data, m_gen_data_src, msg->local_event_size_bytes);
tw_event_send(e_gen); tw_event_send(e_gen);
...@@ -16,14 +16,13 @@ PARAMS ...@@ -16,14 +16,13 @@ PARAMS
modelnet_scheduler="fcfs"; modelnet_scheduler="fcfs";
chunk_size="32"; chunk_size="32";
# modelnet_scheduler="round-robin"; # modelnet_scheduler="round-robin";
num_vcs="1";
num_routers="4"; num_routers="4";
local_vc_size="2048"; local_vc_size="2048";
global_vc_size="8192"; global_vc_size="8192";
cn_vc_size="512"; cn_vc_size="1024";
local_bandwidth="5.25"; local_bandwidth="5.25";
global_bandwidth="4.7"; global_bandwidth="4.7";
cn_bandwidth="5.25"; cn_bandwidth="5.25";
message_size="312"; message_size="320";
routing="minimal"; routing="minimal";
...@@ -24,8 +24,8 @@ ...@@ -24,8 +24,8 @@
#include "codes/configuration.h" #include "codes/configuration.h"
#include "codes/lp-type-lookup.h" #include "codes/lp-type-lookup.h"
#define NUM_REQS 1 /* number of requests sent by each server */ #define NUM_REQS 5 /* number of requests sent by each server */
#define PAYLOAD_SZ 2048 /* size of simulated data payload, bytes */ #define PAYLOAD_SZ 4096 /* size of simulated data payload, bytes */
static int net_id = 0; static int net_id = 0;
static int num_routers = 0; static int num_routers = 0;
...@@ -455,7 +455,7 @@ static void handle_ack_event( ...@@ -455,7 +455,7 @@ static void handle_ack_event(
memcpy(m_remote, m_local, sizeof(svr_msg)); memcpy(m_remote, m_local, sizeof(svr_msg));
m_remote->svr_event_type = (do_pull) ? ACK : REQ; m_remote->svr_event_type = (do_pull) ? ACK : REQ;
// printf("handle_ack_event(), lp %llu.\n", (unsigned long long)lp->gid); printf("handle_ack_event(), lp %llu.\n", (unsigned long long)lp->gid);
/* safety check that this request got to the right server */ /* safety check that this request got to the right server */
// printf("\n m->src %d lp->gid %d ", m->src, lp->gid); // printf("\n m->src %d lp->gid %d ", m->src, lp->gid);
...@@ -514,7 +514,7 @@ static void handle_req_event( ...@@ -514,7 +514,7 @@ static void handle_req_event(
m_remote->svr_event_type = ACK; m_remote->svr_event_type = ACK;
//printf("handle_req_event(), lp %llu src %llu .\n", (unsigned long long)lp->gid, (unsigned long long) m->src); printf("handle_req_event(), lp %llu src %llu .\n", (unsigned long long)lp->gid, (unsigned long long) m->src);
Markdown is supported
0% or .
Please register or to comment
