Commit 9c9edb04 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Added debugging information about event population, minor fixes
parent 8ac8bdee
...@@ -31,7 +31,7 @@ ...@@ -31,7 +31,7 @@
#define WINDOW_LENGTH 0 #define WINDOW_LENGTH 0
// debugging parameters // debugging parameters
#define TRACK 25 #define TRACK -1
#define PRINT_ROUTER_TABLE 1 #define PRINT_ROUTER_TABLE 1
#define DEBUG 0 #define DEBUG 0
...@@ -42,7 +42,7 @@ ...@@ -42,7 +42,7 @@
#define dprintf(_fmt, ...) \ #define dprintf(_fmt, ...) \
do {if (CLIENT_DBG) printf(_fmt, __VA_ARGS__);} while (0) do {if (CLIENT_DBG) printf(_fmt, __VA_ARGS__);} while (0)
long term_ecount, router_ecount, term_pending_ecount, router_pending_ecount; long term_ecount, router_ecount, term_rev_ecount, router_rev_ecount;
static double maxd(double a, double b) { return a < b ? b : a; } static double maxd(double a, double b) { return a < b ? b : a; }
...@@ -328,6 +328,8 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -328,6 +328,8 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
p->total_terminals = p->total_routers * p->num_cn; p->total_terminals = p->total_routers * p->num_cn;
if(!g_tw_mynode)
printf("\n Total nodes %d routers %d groups %d radix %d num_vc %d ", p->num_cn * p->total_routers, printf("\n Total nodes %d routers %d groups %d radix %d num_vc %d ", p->num_cn * p->total_routers,
p->total_routers, p->total_routers,
p->num_groups, p->num_groups,
...@@ -396,7 +398,7 @@ static void dragonfly_report_stats() ...@@ -396,7 +398,7 @@ static void dragonfly_report_stats()
printf("\n ADAPTIVE ROUTING STATS: %d packets routed minimally %d packets routed non-minimally completed packets %d ", total_minimal_packets, total_nonmin_packets, total_completed_packets); printf("\n ADAPTIVE ROUTING STATS: %d packets routed minimally %d packets routed non-minimally completed packets %d ", total_minimal_packets, total_nonmin_packets, total_completed_packets);
printf("\n Max terminal occupancy %d max router occupancy %d ", max_term_occupancy, max_router_occupancy); printf("\n Max terminal occupancy %d max router occupancy %d ", max_term_occupancy, max_router_occupancy);
printf("\n Total terminal events generated %ld router events %ld ", total_term_events, total_router_events); printf("\n Event population: total committed terminal events:%ld router events: %ld ", total_term_events, total_router_events);
return; return;
...@@ -542,7 +544,6 @@ tw_lpid getRouterFromGroupID(int dest_gid, ...@@ -542,7 +544,6 @@ tw_lpid getRouterFromGroupID(int dest_gid,
/*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/ /*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/
void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void router_credit_send(router_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
router_ecount++;
tw_event * buf_e; tw_event * buf_e;
tw_stime ts; tw_stime ts;
terminal_message * buf_msg; terminal_message * buf_msg;
...@@ -615,7 +616,9 @@ static void packet_generate_send_rc(terminal_state * s, ...@@ -615,7 +616,9 @@ static void packet_generate_send_rc(terminal_state * s,
terminal_message * msg, terminal_message * msg,
tw_lp * lp) tw_lp * lp)
term_ecount++; term_rev_ecount++;
term_ecount--;
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
s->terminal_available_time = msg->saved_available_time; s->terminal_available_time = msg->saved_available_time;
...@@ -625,8 +628,8 @@ static void packet_generate_send_rc(terminal_state * s, ...@@ -625,8 +628,8 @@ static void packet_generate_send_rc(terminal_state * s,
s->packet_counter--; s->packet_counter--;
s->output_vc_state[vc] = VC_IDLE; s->output_vc_state[vc] = VC_IDLE;
if(bf->c2) //if(bf->c2)
s->max_term_vc_occupancy = msg->saved_occupancy; // s->max_term_vc_occupancy = msg->saved_occupancy;
if (msg->chunk_id == (msg->num_chunks-1)){ if (msg->chunk_id == (msg->num_chunks-1)){
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
...@@ -650,6 +653,7 @@ static void packet_generate_send(terminal_state * s, ...@@ -650,6 +653,7 @@ static void packet_generate_send(terminal_state * s,
bf->c1 = 0; bf->c1 = 0;
term_ecount++; term_ecount++;
term_rev_ecount++;
const dragonfly_param *p = s->params; const dragonfly_param *p = s->params;
...@@ -666,8 +670,6 @@ static void packet_generate_send(terminal_state * s, ...@@ -666,8 +670,6 @@ static void packet_generate_send(terminal_state * s,
if(!num_chunks) if(!num_chunks)
num_chunks = 1; num_chunks = 1;
msg->num_chunks = num_chunks;
if(!msg->packet_ID) if(!msg->packet_ID)
msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter + tw_rand_integer(lp->rng, 0, lp->gid + g_tw_nlp * s->packet_counter); msg->packet_ID = lp->gid + g_tw_nlp * s->packet_counter + tw_rand_integer(lp->rng, 0, lp->gid + g_tw_nlp * s->packet_counter);
...@@ -714,6 +716,7 @@ static void packet_generate_send(terminal_state * s, ...@@ -714,6 +716,7 @@ static void packet_generate_send(terminal_state * s,
else else
travel_start_time = msg->travel_start_time; travel_start_time = msg->travel_start_time;
m->num_chunks = num_chunks;
m->magic = router_magic_num; m->magic = router_magic_num;
m->origin_router_id = s->router_id; m->origin_router_id = s->router_id;
m->type = R_FORWARD; m->type = R_FORWARD;
...@@ -733,13 +736,13 @@ static void packet_generate_send(terminal_state * s, ...@@ -733,13 +736,13 @@ static void packet_generate_send(terminal_state * s,
tw_event_send(e); tw_event_send(e);
if(msg->packet_ID == TRACK && msg->chunk_id == msg->num_chunks - 1) if(msg->packet_ID == TRACK && msg->chunk_id == num_chunks - 1)
printf("\n packet %d generated chunk id %d reach at time %lf ", printf("\n packet %d generated chunk id %d reach at time %lf ",
msg->packet_ID, msg->packet_ID,
msg->chunk_id, msg->chunk_id,
s->terminal_available_time - tw_now(lp)); s->terminal_available_time - tw_now(lp));
if(msg->chunk_id == msg->num_chunks - 1) if(msg->chunk_id == num_chunks - 1)
// now that message is sent, issue an "idle" event to tell the scheduler // now that message is sent, issue an "idle" event to tell the scheduler
// when I'm next available // when I'm next available
...@@ -767,7 +770,7 @@ static void packet_generate_send(terminal_state * s, ...@@ -767,7 +770,7 @@ static void packet_generate_send(terminal_state * s,
if(s->vc_occupancy[chan] > s->max_term_vc_occupancy) if(s->vc_occupancy[chan] > s->max_term_vc_occupancy)
bf->c2 = 1; bf->c2 = 1;
msg->saved_occupancy = s->max_term_vc_occupancy; //msg->saved_occupancy = s->max_term_vc_occupancy;
s->max_term_vc_occupancy = s->vc_occupancy[chan]; s->max_term_vc_occupancy = s->vc_occupancy[chan];
...@@ -825,10 +828,10 @@ static void packet_arrive_rc(terminal_state * s, ...@@ -825,10 +828,10 @@ static void packet_arrive_rc(terminal_state * s,
term_ecount++; term_ecount--;
term_rev_ecount++;
uint64_t num_chunks = msg->num_chunks; uint64_t num_chunks = msg->num_chunks;
if (msg->packet_size % s->params->chunk_size)
num_chunks++;
if(msg->chunk_id == num_chunks - 1) if(msg->chunk_id == num_chunks - 1)
completed_packets--; completed_packets--;
...@@ -856,7 +859,7 @@ static void packet_arrive_rc(terminal_state * s, ...@@ -856,7 +859,7 @@ static void packet_arrive_rc(terminal_state * s,
dragonfly_max_latency = msg->saved_available_time; dragonfly_max_latency = msg->saved_available_time;
if (msg->chunk_id == (msg->num_chunks)-1 && if (msg->chunk_id == num_chunks-1 &&
msg->remote_event_size_bytes && msg->remote_event_size_bytes &&
msg->is_pull) msg->is_pull)
...@@ -871,10 +874,10 @@ static void packet_arrive(terminal_state * s, ...@@ -871,10 +874,10 @@ static void packet_arrive(terminal_state * s,
++term_ecount; term_ecount++;
term_rev_ecount++;
num_chunks++;
completed_packets++; completed_packets++;
...@@ -1299,7 +1302,9 @@ terminal_buf_update_rc(terminal_state * s, ...@@ -1299,7 +1302,9 @@ terminal_buf_update_rc(terminal_state * s,
term_rev_ecount++;
int msg_indx = msg->vc_index; int msg_indx = msg->vc_index;
s->vc_occupancy[msg_indx]++; s->vc_occupancy[msg_indx]++;
if(s->vc_occupancy[msg_indx] == s->params->cn_vc_size) if(s->vc_occupancy[msg_indx] == s->params->cn_vc_size)
...@@ -1314,6 +1319,8 @@ terminal_buf_update(terminal_state * s, ...@@ -1314,6 +1319,8 @@ terminal_buf_update(terminal_state * s,
term_rev_ecount++;
// Update the buffer space associated with this router LP // Update the buffer space associated with this router LP
s->vc_occupancy[msg_indx]--; s->vc_occupancy[msg_indx]--;
...@@ -1624,8 +1631,10 @@ static void router_packet_forward_rc( router_state * s, ...@@ -1624,8 +1631,10 @@ static void router_packet_forward_rc( router_state * s,
router_rev_ecount++;
router_ecount--;
router_ecount++;
total_hops--; total_hops--;
...@@ -1668,6 +1677,7 @@ static void router_packet_forward( router_state * s, ...@@ -1668,6 +1677,7 @@ static void router_packet_forward( router_state * s,
router_ecount++; router_ecount++;
bf->c2 = 0; bf->c2 = 0;
...@@ -1681,11 +1691,6 @@ static void router_packet_forward( router_state * s, ...@@ -1681,11 +1691,6 @@ static void router_packet_forward( router_state * s,
float bandwidth = s->params->local_bandwidth; float bandwidth = s->params->local_bandwidth;
if(msg->packet_size % s->params->chunk_size)
num_chunks++;
if(!num_chunks)
num_chunks = 1;
total_hops++; total_hops++;
...@@ -1947,10 +1952,10 @@ void router_buf_update_rc( ...@@ -1947,10 +1952,10 @@ void router_buf_update_rc(
uint64_t num_chunks = msg->packet_size/s->params->chunk_size; router_ecount--;
if(msg->packet_size % s->params->chunk_size) router_rev_ecount++;
num_chunks++;
...@@ -1967,6 +1972,9 @@ void router_buf_update_rc( ...@@ -1967,6 +1972,9 @@ void router_buf_update_rc(
/* Update the buffer space associated with this router LP */ /* Update the buffer space associated with this router LP */
void router_buf_update(router_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void router_buf_update(router_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
router_ecount++;
if(TRACK == lp->gid) if(TRACK == lp->gid)
...@@ -2057,9 +2065,6 @@ void terminal_rc_event_handler(terminal_state * s, tw_bf * bf, terminal_message ...@@ -2057,9 +2065,6 @@ void terminal_rc_event_handler(terminal_state * s, tw_bf * bf, terminal_message
/* Reverse computation handler for a router event */ /* Reverse computation handler for a router event */
void router_rc_event_handler(router_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) void router_rc_event_handler(router_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
num_chunks++;
switch(msg->type) switch(msg->type)
case R_FORWARD: case R_FORWARD:
Markdown is supported
0% or .
Please register or to comment
