Commit 959f2fb3 authored by mubarak's avatar mubarak Committed by Misbah Mubarak
Browse files
change for simulating MPI wait operations
parent 88be4862
...@@ -10,7 +10,7 @@ ...@@ -10,7 +10,7 @@
#include "ross.h" #include "ross.h"
#define MAX_LENGTH 512 #define MAX_LENGTH 512
//#define MAX_REQUESTS 128 #define MAX_REQUESTS 128
/* struct to hold the actual data from a single MPI event*/ /* struct to hold the actual data from a single MPI event*/
typedef struct mpi_event_list mpi_event_list; typedef struct mpi_event_list mpi_event_list;
...@@ -37,12 +37,19 @@ enum NW_WORKLOADS ...@@ -37,12 +37,19 @@ enum NW_WORKLOADS
#endif #endif
OTHERS, /* add the names of other workload generators here */ OTHERS, /* add the names of other workload generators here */
enum mpi_workload_type enum mpi_workload_type
/* sleep/delay to simulate computation or other activity */ /* sleep/delay to simulate computation or other activity */
CODES_NW_DELAY = 1, CODES_NW_DELAY = 1,
/* MPI wait all operation */ /* MPI wait all operation */
//CODES_NW_WAITALL, CODES_NW_WAITALL,
/* MPI Wait operation */
CODES_NW_WAIT,
/* MPI Waitsome operation */
CODES_NW_WAITSOME,
/* MPI Waitany operation */
CODES_NW_WAITANY,
/* terminator; there are no more operations for this rank */ /* terminator; there are no more operations for this rank */
CODES_NW_END, CODES_NW_END,
/* MPI blocking send operation */ /* MPI blocking send operation */
...@@ -68,9 +75,9 @@ enum mpi_workload_type ...@@ -68,9 +75,9 @@ enum mpi_workload_type
/* MPI Allreduce operation */ /* MPI Allreduce operation */
CODES_NW_ALLREDUCE, CODES_NW_ALLREDUCE,
/* MPI test all operation */ /* MPI test all operation */
//CODES_NW_TESTALL, CODES_NW_TESTALL,
/* MPI test operation */ /* MPI test operation */
//CODES_NW_TEST, CODES_NW_TEST,
/* Generic collective operation */ /* Generic collective operation */
CODES_NW_COL, CODES_NW_COL,
...@@ -83,6 +90,7 @@ struct mpi_event_list ...@@ -83,6 +90,7 @@ struct mpi_event_list
enum mpi_workload_type op_type; enum mpi_workload_type op_type;
double start_time; double start_time;
double end_time; double end_time;
double sim_start_time;
/* parameters for each operation type */ /* parameters for each operation type */
union union
...@@ -100,7 +108,7 @@ struct mpi_event_list ...@@ -100,7 +108,7 @@ struct mpi_event_list
short data_type; /* MPI data type to be matched with the recv */ short data_type; /* MPI data type to be matched with the recv */
int count; /* number of elements to be received */ int count; /* number of elements to be received */
int tag; /* tag of the message */ int tag; /* tag of the message */
//int32_t request; int16_t req_id;
} send; } send;
struct struct
...@@ -110,22 +118,21 @@ struct mpi_event_list ...@@ -110,22 +118,21 @@ struct mpi_event_list
short data_type; /* MPI data type to be matched with the send */ short data_type; /* MPI data type to be matched with the send */
int count; /* number of elements to be sent */ int count; /* number of elements to be sent */
} recv; } recv;
struct struct
int num_bytes; int num_bytes;
} collective; } collective;
/*struct struct
int count; int count;
int requests[MAX_REQUESTS]; int16_t* req_ids;
} wait_all; } waits;
struct struct
int flag; } wait;
} test;*/
}u; }u;
...@@ -178,6 +178,7 @@ int handleDUMPIISend(const dumpi_isend *prm, uint16_t thread, const dumpi_time * ...@@ -178,6 +178,7 @@ int handleDUMPIISend(const dumpi_isend *prm, uint16_t thread, const dumpi_time *
wrkld_per_rank.u.send.dest_rank = prm->dest; wrkld_per_rank.u.send.dest_rank = prm->dest;
wrkld_per_rank.u.send.source_rank = myctx->my_rank; wrkld_per_rank.u.send.source_rank = myctx->my_rank;
wrkld_per_rank.start_time = cpu->start.nsec; wrkld_per_rank.start_time = cpu->start.nsec;
wrkld_per_rank.u.send.req_id = prm->request;
wrkld_per_rank.end_time = cpu->stop.nsec; wrkld_per_rank.end_time = cpu->stop.nsec;
assert(wrkld_per_rank.u.send.num_bytes > 0); assert(wrkld_per_rank.u.send.num_bytes > 0);
...@@ -200,9 +201,12 @@ int handleDUMPIIRecv(const dumpi_irecv *prm, uint16_t thread, const dumpi_time * ...@@ -200,9 +201,12 @@ int handleDUMPIIRecv(const dumpi_irecv *prm, uint16_t thread, const dumpi_time *
wrkld_per_rank->u.recv.num_bytes = prm->count * get_num_bytes(prm->datatype); wrkld_per_rank->u.recv.num_bytes = prm->count * get_num_bytes(prm->datatype);
wrkld_per_rank->u.recv.source_rank = prm->source; wrkld_per_rank->u.recv.source_rank = prm->source;
wrkld_per_rank->u.recv.dest_rank = -1; wrkld_per_rank->u.recv.dest_rank = -1;
wrkld_per_rank->u.recv.req_id = prm->request;
wrkld_per_rank->start_time = cpu->start.nsec; wrkld_per_rank->start_time = cpu->start.nsec;
wrkld_per_rank->end_time = cpu->stop.nsec; wrkld_per_rank->end_time = cpu->stop.nsec;
if(wrkld_per_rank->u.recv.num_bytes == 0)
wrkld_per_rank->u.recv.num_bytes = 8;
assert(wrkld_per_rank->u.recv.num_bytes > 0); assert(wrkld_per_rank->u.recv.num_bytes > 0);
dumpi_insert_next_op(myctx->dumpi_mpi_array, wrkld_per_rank); dumpi_insert_next_op(myctx->dumpi_mpi_array, wrkld_per_rank);
...@@ -229,6 +233,9 @@ int handleDUMPISend(const dumpi_send *prm, uint16_t thread, ...@@ -229,6 +233,9 @@ int handleDUMPISend(const dumpi_send *prm, uint16_t thread,
if(wrkld_per_rank.u.send.num_bytes < 0) if(wrkld_per_rank.u.send.num_bytes < 0)
printf("\n Number of bytes %d count %d data type %d num_bytes %d", prm->count * get_num_bytes(prm->datatype), prm->count, prm->datatype, get_num_bytes(prm->datatype)); printf("\n Number of bytes %d count %d data type %d num_bytes %d", prm->count * get_num_bytes(prm->datatype), prm->count, prm->datatype, get_num_bytes(prm->datatype));
if(wrkld_per_rank.u.send.num_bytes == 0)
wrkld_per_rank.u.send.num_bytes = 8;
// printf("\n Number of data bytes %d ", prm->count);
dumpi_insert_next_op(myctx->dumpi_mpi_array, &wrkld_per_rank); dumpi_insert_next_op(myctx->dumpi_mpi_array, &wrkld_per_rank);
update_compute_time(cpu, myctx); update_compute_time(cpu, myctx);
...@@ -329,6 +336,92 @@ int handleDUMPIAlltoall(const dumpi_alltoall *prm, uint16_t thread, ...@@ -329,6 +336,92 @@ int handleDUMPIAlltoall(const dumpi_alltoall *prm, uint16_t thread,
return 0; return 0;
int handleDUMPIWait(const dumpi_wait *prm, uint16_t thread,
const dumpi_time *cpu, const dumpi_time *wall,
const dumpi_perfinfo *perf, void *userarg)
rank_mpi_context* myctx = (rank_mpi_context*)userarg;
struct mpi_event_list wrkld_per_rank;
wrkld_per_rank.op_type = CODES_NW_WAIT;
wrkld_per_rank.u.wait.req_id = prm->request;
return 0;
int handleDUMPIWaitsome(const dumpi_waitsome *prm, uint16_t thread,
int i;
wrkld_per_rank.op_type = CODES_NW_WAITSOME;
wrkld_per_rank.u.waits.count = prm->count;
wrkld_per_rank.u.waits.req_ids = (int16_t*)malloc(prm->count * sizeof(int16_t));
for( i = 0; i < prm->count; i++ )
wrkld_per_rank.u.waits.req_ids[i] = (int16_t)prm->requests[i];
return 0;
int handleDUMPIWaitany(const dumpi_waitany *prm, uint16_t thread,
int i;
wrkld_per_rank.op_type = CODES_NW_WAITANY;
return 0;
int handleDUMPIWaitall(const dumpi_waitall *prm, uint16_t thread,
int i;
wrkld_per_rank.op_type = CODES_NW_WAITALL;
wrkld_per_rank.u.waits.req_ids[i] = prm->requests[i];
return 0;
int handleDUMPIAlltoallv(const dumpi_alltoallv *prm, uint16_t thread, int handleDUMPIAlltoallv(const dumpi_alltoallv *prm, uint16_t thread,
const dumpi_time *cpu, const dumpi_time *wall, const dumpi_time *cpu, const dumpi_time *wall,
const dumpi_perfinfo *perf, void *uarg) const dumpi_perfinfo *perf, void *uarg)
...@@ -423,7 +516,7 @@ int dumpi_trace_nw_workload_load(const char* params, int rank) ...@@ -423,7 +516,7 @@ int dumpi_trace_nw_workload_load(const char* params, int rank)
if(!rank_tbl) if(!rank_tbl)
rank_tbl = qhash_init(hash_rank_compare, quickhash_32bit_hash, RANK_HASH_TABLE_SIZE); rank_tbl = qhash_init(hash_rank_compare, quickhash_64bit_hash, RANK_HASH_TABLE_SIZE);
return -1; return -1;
...@@ -468,14 +561,14 @@ int dumpi_trace_nw_workload_load(const char* params, int rank) ...@@ -468,14 +561,14 @@ int dumpi_trace_nw_workload_load(const char* params, int rank)
callbacks.on_ibsend = (dumpi_ibsend_call)handleDUMPIGeneric; callbacks.on_ibsend = (dumpi_ibsend_call)handleDUMPIGeneric;
callbacks.on_issend = (dumpi_issend_call)handleDUMPIGeneric; callbacks.on_issend = (dumpi_issend_call)handleDUMPIGeneric;
callbacks.on_irsend = (dumpi_irsend_call)handleDUMPIGeneric; callbacks.on_irsend = (dumpi_irsend_call)handleDUMPIGeneric;
callbacks.on_wait = (dumpi_wait_call)handleDUMPIGeneric; callbacks.on_wait = (dumpi_wait_call)handleDUMPIWait;
callbacks.on_test = (dumpi_test_call)handleDUMPIGeneric; callbacks.on_test = (dumpi_test_call)handleDUMPIGeneric;
callbacks.on_request_free = (dumpi_request_free_call)handleDUMPIGeneric; callbacks.on_request_free = (dumpi_request_free_call)handleDUMPIGeneric;
callbacks.on_waitany = (dumpi_waitany_call)handleDUMPIGeneric; callbacks.on_waitany = (dumpi_waitany_call)handleDUMPIWaitany;
callbacks.on_testany = (dumpi_testany_call)handleDUMPIGeneric; callbacks.on_testany = (dumpi_testany_call)handleDUMPIGeneric;
callbacks.on_waitall = (dumpi_waitall_call)handleDUMPIGeneric; callbacks.on_waitall = (dumpi_waitall_call)handleDUMPIWaitall;
callbacks.on_testall = (dumpi_testall_call)handleDUMPIGeneric; callbacks.on_testall = (dumpi_testall_call)handleDUMPIGeneric;
callbacks.on_waitsome = (dumpi_waitsome_call)handleDUMPIGeneric; callbacks.on_waitsome = (dumpi_waitsome_call)handleDUMPIWaitsome;
callbacks.on_testsome = (dumpi_testsome_call)handleDUMPIGeneric; callbacks.on_testsome = (dumpi_testsome_call)handleDUMPIGeneric;
callbacks.on_iprobe = (dumpi_iprobe_call)handleDUMPIGeneric; callbacks.on_iprobe = (dumpi_iprobe_call)handleDUMPIGeneric;
callbacks.on_probe = (dumpi_probe_call)handleDUMPIGeneric; callbacks.on_probe = (dumpi_probe_call)handleDUMPIGeneric;
Markdown is supported
0% or .
Please register or to comment
