Skip to content
GitLab
Menu
Projects
Groups
Snippets
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Xin Wang
codes-dev
Commits
887dc82c
Commit
887dc82c
authored
Jul 18, 2017
by
Misbah Mubarak
Browse files
Adding threshold for dumpi traces, fixing background traffic reverse handler
parent
b25e8d10
Changes
3
Hide whitespace changes
Inline
Side-by-side
src/network-workloads/conf/dragonfly-custom/modelnet-test-dragonfly-theta.conf
View file @
887dc82c
@@ -13,13 +13,13 @@ LPGROUPS
PARAMS
PARAMS
# packet size in the network
packet_size
1024
packet_size
2048
modelnet_order
"dragonfly_custom"
"dragonfly_custom_router"
modelnet_order
"dragonfly_custom"
# scheduler options
# scheduler options
modelnet_scheduler
"fcfs"
modelnet_scheduler
"fcfs"
# chunk size in the network (when chunk size = packet size, packets will not be
# divided into chunks)
chunk_size
1024
chunk_size
2048
# modelnet_scheduler="round-robin";
# number of routers within each group
# this is dictated by the dragonfly configuration files
src/network-workloads/model-net-mpi-replay.c
View file @
887dc82c
@@ -423,7 +423,11 @@ static void notify_background_traffic_rc(
void
ns
void
ns
void
bf
void
bf
void
m
void
m
tw_rand_reverse_unif
lp
rng
int
num_jobs
codes_jobmap_get_num_jobs
jobmap_ctx
for
int
i
0
i
num_jobs
1
i
lp
rng
static
void
static
void
@@ -2591,7 +2595,8 @@ int modelnet_mpi_replay(MPI_Comm comm, int* argc, char*** argv )
int
ret
lp_io_flush
io_handle
MPI_COMM_CODES
int
ret
lp_io_flush
io_handle
MPI_COMM_CODES
assert
ret
0
"lp_io_flush failure"
assert
ret
0
printf
\n
Synthetic traffic stats: data received per proc %lf bytes
\n
g_total_syn_data
num_syn_clients
if
is_synthetic
printf
\n
\n
g_total_syn_data
num_syn_clients
model_net_report_stats
net_id
net_id
src/workload/methods/codes-dumpi-trace-nw-wrkld.c
View file @
887dc82c
@@ -46,6 +46,7 @@ extern struct codes_jobmap_ctx *jobmap_ctx;
static
struct
qhash_table
rank_tbl
NULL
static
struct
qhash_table
rank_tbl
NULL
static
int
rank_tbl_pop
0
static
int
rank_tbl_pop
0
static
unsigned
int
max_threshold
INT_MAX
/* context of the MPI workload */
typedef
struct
rank_mpi_context
typedef
struct
rank_mpi_context
@@ -54,6 +55,7 @@ typedef struct rank_mpi_context
// whether we've seen an init op (needed for timing correctness)
int
is_init
int
is_init
int
num_reqs
int
num_reqs
unsigned
int
num_ops
int64_t
my_rank
int64_t
my_rank
double
last_op_time
double
last_op_time
double
init_time
double
init_time
@@ -785,6 +787,7 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
my_ctx
is_init
0
my_ctx
is_init
0
my_ctx
num_reqs
0
my_ctx
num_reqs
0
my_ctx
dumpi_mpi_array
dumpi_init_op_data
my_ctx
dumpi_mpi_array
dumpi_init_op_data
my_ctx
num_ops
0
if
rank
10
if
rank
10
sprintf
file_name
"%s000%d.bin"
dumpi_params
file_name
rank
sprintf
file_name
"%s000%d.bin"
dumpi_params
file_name
rank
@@ -931,8 +934,20 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
while
active
finalize_reached
while
active
finalize_reached
num_calls
num_calls
my_ctx
num_ops
#ifdef ENABLE_CORTEX
active
cortex_undumpi_read_single_call
profile
callarr
transarr
void
my_ctx
finalize_reached
if
my_ctx
num_ops
max_threshold
active
profile
callarr
transarr
void
my_ctx
finalize_reached
else
struct
codes_workload_op
op
op
op_type
CODES_WK_END
op
start_time
my_ctx
last_op_time
op
end_time
my_ctx
last_op_time
1
dumpi_insert_next_op
my_ctx
dumpi_mpi_array
op
break
#else
#else
active
profile
callarr
void
my_ctx
finalize_reached
active
profile
callarr
void
my_ctx
finalize_reached
#endif
#endif
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
