Commit 86def1aa authored by Noah Wolfe's avatar Noah Wolfe
Browse files
testing everything but saving port and chan
parent 42e1a96a
...@@ -3042,8 +3042,16 @@ void slim_router_packet_send_rc(router_state * s, ...@@ -3042,8 +3042,16 @@ void slim_router_packet_send_rc(router_state * s,
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
s->next_output_available_time[output_port] = msg->saved_available_time; if(bf->c11)
s->link_traffic[output_port] -= msg->packet_size % s->params->chunk_size;
if(bf->c12)
s->link_traffic[output_port] -= s->params->chunk_size; s->link_traffic[output_port] -= s->params->chunk_size;
create_prepend_to_terminal_message_list(s->pending_msgs[output_port], create_prepend_to_terminal_message_list(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan, msg); s->pending_msgs_tail[output_port], output_chan, msg);
...@@ -3095,26 +3103,41 @@ slim_router_packet_send( router_state * s, ...@@ -3095,26 +3103,41 @@ slim_router_packet_send( router_state * s,
int to_terminal = 1, global = 0; int to_terminal = 1, global = 0;
double delay = s->params->cn_delay; double delay = s->params->cn_delay;
double bandwidth = s->params->cn_bandwidth;
if(output_port < s->params->num_local_channels) if(output_port < s->params->num_local_channels)
to_terminal = 0; to_terminal = 0;
delay = s->params->local_delay; delay = s->params->local_delay;
bandwidth = s->params->local_bandwidth;
else if(output_port < s->params->num_local_channels + s->params->num_global_channels) else if(output_port < s->params->num_local_channels + s->params->num_global_channels)
global = 1; global = 1;
delay = s->params->global_delay; delay = s->params->global_delay;
bandwidth = s->params->global_bandwidth;
ts = g_tw_lookahead + delay + tw_rand_unif(lp->rng) + s->params->router_delay; uint64_t num_chunks = cur_entry->msg.packet_size / s->params->chunk_size;
if(msg->packet_size % s->params->chunk_size)
num_chunks++;
if(!num_chunks)
num_chunks = 1;
double bytetime = delay;
if((cur_entry->msg.packet_size % s->params->chunk_size) && (cur_entry->msg.chunk_id == num_chunks - 1))
bytetime = bytes_to_ns(cur_entry->msg.packet_size % s->params->chunk_size, bandwidth);
ts = g_tw_lookahead + tw_rand_unif(lp->rng) + bytetime + s->params->router_delay;
msg->saved_available_time = s->next_output_available_time[output_port]; msg->saved_available_time = s->next_output_available_time[output_port];
s->next_output_available_time[output_port] = s->next_output_available_time[output_port] =
maxd(s->next_output_available_time[output_port], tw_now(lp)); maxd(s->next_output_available_time[output_port], tw_now(lp));
s->next_output_available_time[output_port] += ts; s->next_output_available_time[output_port] += ts;
ts = s->next_output_available_time[output_port] - tw_now(lp);
// dest can be a router or a terminal, so we must check // dest can be a router or a terminal, so we must check
void * m_data; void * m_data;
if (to_terminal) if (to_terminal)
...@@ -3145,7 +3168,14 @@ slim_router_packet_send( router_state * s, ...@@ -3145,7 +3168,14 @@ slim_router_packet_send( router_state * s,
m->intm_lp_id = lp->gid; m->intm_lp_id = lp->gid;
m->magic = slim_router_magic_num; m->magic = slim_router_magic_num;
if((cur_entry->msg.packet_size % s->params->chunk_size) && (cur_entry->msg.chunk_id == num_chunks - 1)) {
bf->c11 = 1;
s->link_traffic[output_port] += (cur_entry->msg.packet_size %
s->params->chunk_size);
} else {
bf->c12 = 1;
s->link_traffic[output_port] += s->params->chunk_size; s->link_traffic[output_port] += s->params->chunk_size;
/* Determine the event type. If the packet has arrived at the final /* Determine the event type. If the packet has arrived at the final
* destination router then it should arrive at the destination terminal * destination router then it should arrive at the destination terminal
...@@ -3168,14 +3198,19 @@ slim_router_packet_send( router_state * s, ...@@ -3168,14 +3198,19 @@ slim_router_packet_send( router_state * s,
copy_terminal_list_entry(cur_entry, msg); copy_terminal_list_entry(cur_entry, msg);
slim_delete_terminal_message_list(cur_entry); slim_delete_terminal_message_list(cur_entry);
cur_entry = s->pending_msgs[output_port][2]; cur_entry = s->pending_msgs[output_port][3];
s->next_output_available_time[output_port] -= s->params->router_delay;
ts -= s->params->router_delay;
if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][2];
if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][1]; if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][1];
if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][0]; if(cur_entry == NULL) cur_entry = s->pending_msgs[output_port][0];
if(cur_entry != NULL) if(cur_entry != NULL)
bf->c3 = 1; bf->c3 = 1;
slim_terminal_message *m_new; slim_terminal_message *m_new;
ts = g_tw_lookahead + delay + tw_rand_unif(lp->rng); ts = ts + g_tw_lookahead * tw_rand_unif(lp->rng);
tw_event *e_new = tw_event_new(lp->gid, ts, lp); tw_event *e_new = tw_event_new(lp->gid, ts, lp);
m_new = tw_event_data(e_new); m_new = tw_event_data(e_new);
m_new->type = R_SEND; m_new->type = R_SEND;
Markdown is supported
0% or .
Please register or to comment
