Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Xin Wang
codes-dev
Commits
793b36de
Commit
793b36de
authored
Apr 16, 2014
by
Jonathan Jenkins
Browse files
stats caveats, cleaning up dbg msgs for simplewan
parent
4a1599b2
Changes
2
Hide whitespace changes
Inline
Side-by-side
src/models/networks/model-net/README.simplewan.txt
View file @
793b36de
@@ -34,3 +34,18 @@ ignored, but linebreaks are not, and delimit rows of the matrix. The relative
simplewan identifiers 1..N are assigned to simplewan LPs in the order of
their appearance in the codes-configuration file. In the future, a full NxN
matrix may be used to facilitate asymmetric link capacities if the need arises.
Caveats:
The model-net statistics are slightly more complex than in other model-net
implementations because there are in essence multiple queues per simplewan
instance. In particular, the "send time" and "recv time" stats are computed as
ranges of time in which the simplewan LP is actively sending/receiving data
from *any* link. Hence, simple bandwidth calculations (send bytes / send time)
may not be accurate due to skew in message issuance.
Having more than one category in simplewan will cause the times in the
derived "all" category to be off. "all" is currently implemented as the sum of
the various categories, which doesn't work when times in certain categories may
overlap.
src/models/networks/model-net/simplewan.c
View file @
793b36de
@@ -18,6 +18,8 @@
@@ -18,6 +18,8 @@
#define CATEGORY_NAME_MAX 16
#define CATEGORY_MAX 12
#define SIMPLEWAN_DEBUG 0
/*Define simplewan data types and structs*/
typedef
struct
sw_message
sw_message
typedef
struct
sw_message
sw_message
typedef
struct
sw_state
sw_state
typedef
struct
sw_state
sw_state
@@ -533,12 +535,15 @@ static void handle_msg_ready_event(
m
recv_next_idle_all_saved
idles
recv_next_idle_all
m
idles
recv_next_idle_all
m
recv_prev_idle_all_saved
idles
recv_prev_idle_all
m
idles
recv_prev_idle_all
#if SIMPLEWAN_DEBUG
printf
"%d: from_id:%d now: %8.3lf next_idle_recv: %8.3lf
\n
printf
\n
ns
id
m
src_mn_rel_id
ns
id
m
src_mn_rel_id
tw_now
lp
ns
recv_next_idle
m
src_mn_rel_id
tw_now
lp
ns
recv_next_idle
m
src_mn_rel_id
printf
"%d: BEFORE all_idles_recv %8.3lf %8.3lf
\n
printf
\n
ns
id
ns
id
idles
recv_prev_idle_all
idles
recv_next_idle_all
idles
recv_prev_idle_all
idles
recv_next_idle_all
#endif
/* update global idles, recv time */
if
tw_now
lp
idles
recv_next_idle_all
if
tw_now
lp
idles
recv_next_idle_all
@@ -552,6 +557,7 @@ static void handle_msg_ready_event(
idles
recv_next_idle_all
ns
recv_next_idle
m
src_mn_rel_id
idles
recv_next_idle_all
ns
recv_next_idle
m
src_mn_rel_id
#if SIMPLEWAN_DEBUG
printf
"%d: AFTER all_idles_recv %8.3lf %8.3lf"
printf
ns
id
idles
recv_prev_idle_all
idles
recv_next_idle_all
ns
id
idles
recv_prev_idle_all
idles
recv_next_idle_all
if
m
event_size_bytes
0
if
m
event_size_bytes
0
@@ -560,6 +566,7 @@ static void handle_msg_ready_event(
else
else
printf
" - without event
\n
printf
" - without event
\n
#endif
/* copy only the part of the message used by higher level */
if
m
event_size_bytes
if
m
event_size_bytes
@@ -665,11 +672,13 @@ static void handle_msg_start_event(
if
stat
max_event_size
total_event_size
if
stat
max_event_size
total_event_size
stat
max_event_size
total_event_size
stat
max_event_size
total_event_size
#if SIMPLEWAN_DEBUG
printf
"%d: to_id:%d now: %8.3lf next_idle_send: %8.3lf
\n
printf
\n
ns
id
dest_rel_id
ns
id
dest_rel_id
tw_now
lp
ns
send_next_idle
dest_rel_id
tw_now
lp
ns
send_next_idle
dest_rel_id
printf
"%d: BEFORE all_idles_send %8.3lf %8.3lf
\n
printf
\n
ns
id
idles
send_prev_idle_all
idles
send_next_idle_all
ns
id
idles
send_prev_idle_all
idles
send_next_idle_all
#endif
/* update global idles, send time */
if
tw_now
lp
idles
send_next_idle_all
if
tw_now
lp
idles
send_next_idle_all
@@ -682,6 +691,7 @@ static void handle_msg_start_event(
idles
send_next_idle_all
ns
send_next_idle
dest_rel_id
idles
send_next_idle_all
ns
send_next_idle
dest_rel_id
#if SIMPLEWAN_DEBUG
printf
"%d: AFTER all_idles_send %8.3lf %8.3lf"
printf
ns
id
idles
send_prev_idle_all
idles
send_next_idle_all
ns
id
idles
send_prev_idle_all
idles
send_next_idle_all
if
m
local_event_size_bytes
0
if
m
0
@@ -690,6 +700,7 @@ static void handle_msg_start_event(
else
else
printf
" - without local event
\n
printf
\n
#endif
/* create new event to send msg to receiving NIC */
// printf("\n msg start sending to %d ", dest_id);
@@ -753,10 +764,12 @@ static tw_stime simplewan_packet_event(
xfer_to_nic_time
codes_local_latency
sender
xfer_to_nic_time
codes_local_latency
sender
#if SIMPLEWAN_DEBUG
printf
"%lu: final %lu packet sz %d remote sz %d self sz %d is_last_pckt %d latency %lf
\n
printf
\n
dest_id
1
2
final_dest_lp
packet_size
dest_id
1
2
final_dest_lp
packet_size
remote_event_size
self_event_size
is_last_pckt
remote_event_size
self_event_size
is_last_pckt
xfer_to_nic_time
offset
xfer_to_nic_time
offset
#endif
e_new
tw_event_new
dest_id
xfer_to_nic_time
offset
sender
e_new
tw_event_new
dest_id
xfer_to_nic_time
offset
sender
msg
tw_event_data
e_new
msg
tw_event_data
e_new
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
