Commit 611d1ea7 authored by Noah's avatar Noah
Browse files
Fixed issue %152 (providing commandline options for LP IO output). Updated slimfly workload README.
parent ad1e90b5
...@@ -19,12 +19,14 @@ HOW TO RUN: ...@@ -19,12 +19,14 @@ HOW TO RUN:
ROSS optimistic mode: ROSS optimistic mode:
mpirun -n 4 src/network-workloads/model-net-synthetic-slimfly --sync=3 --traffic=1 mpirun -n 4 src/network-workloads/model-net-synthetic-slimfly --sync=3 --traffic=1
--lp-io-dir=mn_synthetic --lp-io-use-suffix=1
--load=0.95 -- ../../jenkins/codes/src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf --load=0.95 -- ../../jenkins/codes/src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf
ROSS serial mode: ROSS serial mode:
./src/network-workloads/model-net-synthetic-slimfly --sync=1 --traffic=1 ./src/network-workloads/model-net-synthetic-slimfly --sync=1 --traffic=1
--load=0.95 -- ../../jenkins/codes/src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf --lp-io-dir=mn_synthetic --lp-io-use-suffix=1
--load=0.95 -- ../src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf
options: options:
...@@ -40,6 +40,11 @@ int *worst_dest; //Array mapping worst case destination for each router ...@@ -40,6 +40,11 @@ int *worst_dest; //Array mapping worst case destination for each router
int num_terminals; int num_terminals;
int total_routers; int total_routers;
static char lp_io_dir[356] = {'\0'};
static lp_io_handle io_handle;
static unsigned int lp_io_use_suffix = 0;
static int do_lp_io = 0;
/* whether to pull instead of push */ /* whether to pull instead of push */
static int do_pull = 0; static int do_pull = 0;
...@@ -125,8 +130,10 @@ const tw_optdef app_opt [] = ...@@ -125,8 +130,10 @@ const tw_optdef app_opt [] =
TWOPT_GROUP("Model net synthetic traffic " ), TWOPT_GROUP("Model net synthetic traffic " ),
TWOPT_UINT("traffic", traffic, "UNIFORM RANDOM=1, NEAREST NEIGHBOR=2 "), TWOPT_UINT("traffic", traffic, "UNIFORM RANDOM=1, NEAREST NEIGHBOR=2 "),
TWOPT_STIME("arrival_time", arrival_time, "INTER-ARRIVAL TIME"), TWOPT_STIME("arrival_time", arrival_time, "INTER-ARRIVAL TIME"),
TWOPT_STIME("load", load, "percentage of packet inter-arrival rate to simulate"), TWOPT_STIME("load", load, "percentage of packet inter-arrival rate to simulate"),
TWOPT_END(), TWOPT_CHAR("lp-io-dir", lp_io_dir, "Where to place io output (unspecified -> no output"),
TWOPT_UINT("lp-io-use-suffix", lp_io_use_suffix, "Whether to append uniq suffix to lp-io directory (default 0)"),
TWOPT_END(),
const tw_lptype* svr_get_lp_type() const tw_lptype* svr_get_lp_type()
...@@ -432,14 +439,9 @@ int main( ...@@ -432,14 +439,9 @@ int main(
int rank; int rank;
int num_nets; int num_nets;
int *net_ids; int *net_ids;
char* anno;
lp_io_handle handle;
tw_opt_add(app_opt); tw_opt_add(app_opt);
tw_init(&argc, &argv); tw_init(&argc, &argv);
offset = 1;
if(argc < 2) if(argc < 2)
...@@ -456,18 +458,10 @@ int main( ...@@ -456,18 +458,10 @@ int main(
svr_add_lp_type(); svr_add_lp_type();
codes_mapping_setup(); codes_mapping_setup();
net_ids = model_net_configure(&num_nets); net_ids = model_net_configure(&num_nets);
assert(num_nets==1); // assert(num_nets==1);
net_id = *net_ids; net_id = *net_ids;
free(net_ids); free(net_ids);
//slimfly
/* if(net_id != DRAGONFLY)
printf("\n The test works with dragonfly model configuration only! ");
MPI_Finalize();
return 0;
num_servers_per_rep = codes_mapping_get_lp_count("MODELNET_GRP", 1, "server", NULL, 1); num_servers_per_rep = codes_mapping_get_lp_count("MODELNET_GRP", 1, "server", NULL, 1);
configuration_get_value_int(&config, "PARAMS", "num_terminals", NULL, &num_terminals); configuration_get_value_int(&config, "PARAMS", "num_terminals", NULL, &num_terminals);
configuration_get_value_int(&config, "PARAMS", "num_routers", NULL, &num_routers_per_grp); configuration_get_value_int(&config, "PARAMS", "num_routers", NULL, &num_routers_per_grp);
...@@ -475,12 +469,21 @@ int main( ...@@ -475,12 +469,21 @@ int main(
num_nodes = num_groups * num_routers_per_grp * num_servers_per_rep; num_nodes = num_groups * num_routers_per_grp * num_servers_per_rep;
num_nodes_per_grp = num_routers_per_grp * num_servers_per_rep; num_nodes_per_grp = num_routers_per_grp * num_servers_per_rep;
total_routers = num_routers_per_grp * num_routers_per_grp * 2; total_routers = num_routers_per_grp * num_routers_per_grp * 2;
printf("before lpio\n");
if(lp_io_prepare("modelnet-test", LP_IO_UNIQ_SUFFIX, &handle, MPI_COMM_WORLD) < 0) /* if(lp_io_prepare("modelnet-test", LP_IO_UNIQ_SUFFIX, &handle, MPI_COMM_WORLD) < 0)
return(-1); return(-1);
printf("after lpio\n"); */
if(lp_io_dir[0])
do_lp_io = 1;
int flags = lp_io_use_suffix ? LP_IO_UNIQ_SUFFIX : 0;
int ret = lp_io_prepare(lp_io_dir, flags, &io_handle, MPI_COMM_WORLD);
assert(ret == 0 || !"lp_io_prepare failure");
//WORST_CASE Initialization array //WORST_CASE Initialization array
if(traffic == WORST_CASE) if(traffic == WORST_CASE)
...@@ -495,8 +498,15 @@ printf("after lpio\n"); ...@@ -495,8 +498,15 @@ printf("after lpio\n");
#endif #endif
tw_run(); tw_run();
model_net_report_stats(net_id);
if (do_lp_io){
int ret = lp_io_flush(io_handle, MPI_COMM_WORLD);
assert(ret == 0 || !"lp_io_flush failure");
if(rank == 0) if(rank == 0)
...@@ -512,11 +522,12 @@ printf("after lpio\n"); ...@@ -512,11 +522,12 @@ printf("after lpio\n");
#endif #endif
if(lp_io_flush(handle, MPI_COMM_WORLD) < 0) /* if(lp_io_flush(handle, MPI_COMM_WORLD) < 0)
tw_end(); tw_end();
Markdown is supported
0% or .
Please register or to comment
