Commit 5c89e29c authored by Jonathan Jenkins's avatar Jonathan Jenkins
cleaning up dist tarball
parent 1ad10977
...@@ -18,8 +18,10 @@ pkgconfigdir = $(libdir)/pkgconfig ...@@ -18,8 +18,10 @@ pkgconfigdir = $(libdir)/pkgconfig
pkgconfig_DATA = maint/codes-net.pc pkgconfig_DATA = maint/codes-net.pc
$(pkgconfig_DATA): config.status $(pkgconfig_DATA): config.status
EXTRA_DIST += prepare.sh GETTING_STARTED COPYRIGHT RELEASE_NOTES TODO.txt \ EXTRA_DIST += \
misc/README misc/ptrn_loggp-2.4.6.patch prepare.sh TODO.txt configure.ac uc-codes.cfg reformat.sh \
misc/README misc/ptrn_loggp-2.4.6.patch \
doc/BUILD_STEPS doc/GETTING_STARTED doc/RELEASE_NOTES
AM_CPPFLAGS = -I$(top_srcdir)/src ${CODES_BASE_CFLAGS} AM_CPPFLAGS = -I$(top_srcdir)/src ${CODES_BASE_CFLAGS}
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
# Process this file with autoconf to produce a configure script. # Process this file with autoconf to produce a configure script.
AC_PREREQ([2.67]) AC_PREREQ([2.67])
AC_INIT([codes-net], [0.3.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes]) AC_INIT([codes-net], [0.4.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes])
AC_CANONICAL_TARGET AC_CANONICAL_TARGET
AC_CANONICAL_SYSTEM AC_CANONICAL_SYSTEM
lib_LIBRARIES += src/libcodes-net.a lib_LIBRARIES += src/libcodes-net.a
EXTRA_DIST += \ EXTRA_DIST += \
src/models/network-workloads/README.txt \ src/models/network-workloads/README_synthetic.txt \
src/models/network-workloads/README_traces.txt \
src/models/network-workloads/conf/modelnet-mpi-test.conf \ src/models/network-workloads/conf/modelnet-mpi-test.conf \
src/models/network-workloads/conf/modelnet-mpi-test-cry-router.conf \ src/models/network-workloads/conf/modelnet-mpi-test-cry-router.conf \
src/models/network-workloads/conf/modelnet-mpi-test-dragonfly.conf \ src/models/network-workloads/conf/modelnet-mpi-test-dragonfly.conf \
Markdown is supported
0%
or
Please register or to comment
