Commit 50577225 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
cleaning up dist tarball
parent 67917219
...@@ -20,7 +20,7 @@ pkgconfigdir = $(libdir)/pkgconfig ...@@ -20,7 +20,7 @@ pkgconfigdir = $(libdir)/pkgconfig
pkgconfig_DATA = maint/codes-base.pc pkgconfig_DATA = maint/codes-base.pc
$(pkgconfig_DATA): config.status $(pkgconfig_DATA): config.status
EXTRA_DIST += prepare.sh INSTALL RELEASE_NOTES COPYRIGHT EXTRA_DIST += prepare.sh COPYRIGHT configure.ac reformat.sh uc-codes.cfg
AM_CPPFLAGS = -I$(top_srcdir)/src ${ROSS_CPPFLAGS} AM_CPPFLAGS = -I$(top_srcdir)/src ${ROSS_CPPFLAGS}
...@@ -35,6 +35,7 @@ include Make.rules ...@@ -35,6 +35,7 @@ include Make.rules
include $(top_srcdir)/scripts/Makefile.subdir include $(top_srcdir)/scripts/Makefile.subdir
include $(top_srcdir)/src/Makefile.subdir include $(top_srcdir)/src/Makefile.subdir
include $(top_srcdir)/tests/Makefile.subdir include $(top_srcdir)/tests/Makefile.subdir
include $(top_srcdir)/doc/Makefile.subdir
if USE_DARSHAN if USE_DARSHAN
AM_CPPFLAGS += ${DARSHAN_CFLAGS} -DUSE_DARSHAN=1 AM_CPPFLAGS += ${DARSHAN_CFLAGS} -DUSE_DARSHAN=1
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
# Process this file with autoconf to produce a configure script. # Process this file with autoconf to produce a configure script.
AC_PREREQ([2.67]) AC_PREREQ([2.67])
AC_INIT([codes-base], [0.3.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes-base], [0.4.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
AC_CANONICAL_TARGET AC_CANONICAL_TARGET
AC_CANONICAL_SYSTEM AC_CANONICAL_SYSTEM
docs_general = doc/BUILD_STEPS doc/GETTING_STARTED doc/RELEASE_NOTES
docs_best_practices = \
doc/acmsmall.cls \
doc/algorithm.sty \
doc/algorithmic.sty \
doc/codes-best-practices.tex \
doc/Makefile
docs_examples = \
doc/example/example.c \
doc/example/example.conf \
doc/example/Makefile \
doc/example_heterogeneous/example.c \
doc/example_heterogeneous/example.conf \
doc/example_heterogeneous/example_torus.conf \
doc/example_heterogeneous/Makefile \
doc/example_heterogeneous/README
docs_workload = \
doc/workload/example.kernel.txt \
doc/workload/meta.txt
EXTRA_DIST += $(docs_general) $(docs_best_practices) $(docs_examples) \
$(docs_workload)
...@@ -20,6 +20,7 @@ EXTRA_DIST += tests/lp-io-test.sh \ ...@@ -20,6 +20,7 @@ EXTRA_DIST += tests/lp-io-test.sh \
tests/workload/README.txt \ tests/workload/README.txt \
tests/mapping_test.sh \ tests/mapping_test.sh \
tests/lsm-test.sh \ tests/lsm-test.sh \
tests/resource-test.sh \
tests/conf/buffer_test.conf \ tests/conf/buffer_test.conf \
tests/conf/lsm-test.conf \ tests/conf/lsm-test.conf \
tests/conf/mapping_test.conf \ tests/conf/mapping_test.conf \
Markdown is supported
0% or .
Please register or to comment
