Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Xin Wang
codes-dev
Commits
47bbd8b0
Commit
47bbd8b0
authored
Feb 09, 2016
by
Misbah Mubarak
Browse files
Adding AMG 1728 config file, minor updates to dragonfly model
parent
171ca1a0
Changes
5
Show whitespace changes
Inline
Side-by-side
src/Makefile.subdir
View file @
47bbd8b0
@@ -148,6 +148,7 @@ src_libcodes_a_SOURCES = \
src/network-workloads/model-net-mpi-wrklds.c
src/network-workloads/model-net-mpi-replay.c
src/network-workloads/model-net-synthetic.c
src/network-workloads/read-dumpi-traces.c
src/network-workloads/model-net-dumpi-traces-dump.c
@@ -169,6 +170,7 @@ bin_PROGRAMS += src/network-workloads/model-net-mpi-replay
bin_PROGRAMS
bin_PROGRAMS
bin_PROGRAMS
bin_PROGRAMS
bin_PROGRAMS
bin_PROGRAMS
bin_PROGRAMS
src_workload_codes_workload_dump_SOURCES
@@ -179,6 +181,7 @@ src_network_workloads_model_net_mpi_replay_SOURCES = src/network-workloads/model
src_network_workloads_model_net_mpi_wrklds_SOURCES
src_network_workloads_model_net_synthetic_SOURCES
src_network_workloads_model_net_dumpi_traces_dump_SOURCES
src_network_workloads_read_dumpi_traces_SOURCES
#bin_PROGRAMS += src/network-workload/codes-nw-test
src/network-workloads/conf/modelnet-mpi-test-dfly-amg-1728.conf
0 → 100644
View file @
47bbd8b0
LPGROUPS
MODELNET_GRP
repetitions
"510"
nw
lp
"5"
modelnet_dragonfly
"5"
modelnet_dragonfly_router
"1"
PARAMS
packet_size
"512"
modelnet_order
"dragonfly"
"dragonfly_router"
# scheduler options
modelnet_scheduler
"fcfs"
chunk_size
"256"
# modelnet_scheduler="round-robin";
num_routers
"10"
local_vc_size
"16384"
global_vc_size
"32768"
cn_vc_size
"16384"
local_bandwidth
"5.25"
global_bandwidth
"4.7"
cn_bandwidth
"5.25"
message_size
"560"
routing
"minimal"
View file @
47bbd8b0
@@ -1446,7 +1446,7 @@ int main( int argc, char** argv )
model_net_register
model_net_register
net_ids
model_net_configure
num_nets
net_ids
model_net_configure
num_nets
assert
num_nets
1
assert(num_nets == 1);
net_id
net_ids
net_id
net_ids
free
net_ids
free
net_ids
src/networks/model-net/dragonfly.c
View file @
47bbd8b0
@@ -365,14 +365,14 @@ static int dragonfly_rank_hash_compare(
static
int
dragonfly_hash_func
void
k
int
table_size
static
int
dragonfly_hash_func
void
k
int
table_size
struct
dfly_hash_key
tmp
struct
dfly_hash_key
k
struct
dfly_hash_key
tmp
struct
dfly_hash_key
k
uint32_t
pc
0
pb
0
uint32_t pc = 0, pb = 0;
bj_hashlittle2
tmp
sizeof
tmp
pc
pb
bj_hashlittle2(tmp, sizeof(*tmp), &pc, &pb);
uint64_t key = (~tmp->message_id) + (tmp->message_id << 18);
uint64_t
key
tmp
message_id
tmp
message_id
18
key
key
21
key
key
21
key
key
tmp
sender_id
4
key
key
tmp
sender_id
4
key
key
tmp
sender_id
key
key
tmp
sender_id
return (int)(key & (table_size - 1));
return
int
key
table_size
1
return
int
pc
table_size
1
return (int)(pc % (table_size - 1));
/* convert GiB/s and bytes to ns */
@@ -1366,7 +1366,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
if
bf
c7
if
bf
c7
assert
hash_link
assert(!hash_link);
N_finished_msgs
N_finished_msgs
s
finished_msgs
s
finished_msgs
total_msg_sz
msg
total_size
total_msg_sz
msg
total_size
@@ -1386,14 +1386,14 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
assert
tmp
assert
tmp
tmp
num_chunks
tmp
num_chunks
if
bf
c5
if(bf->c5)
assert(hash_link);
assert(hash_link);
qhash_del(hash_link);
free(tmp->remote_event_data);
free(tmp);
free(tmp);
s->rank_tbl_pop--;
s->rank_tbl_pop--;
return
return
void
send_remote_event
terminal_state
s
terminal_message
msg
tw_lp
lp
tw_bf
bf
char
event_data
int
remote_event_size
void
send_remote_event
terminal_state
s
terminal_message
msg
tw_lp
lp
tw_bf
bf
char
event_data
int
remote_event_size
@@ -1450,15 +1450,15 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
if
total_chunks
if
total_chunks
total_chunks
1
total_chunks
1
if
tmp
if(tmp)
if
tmp
num_chunks
total_chunks
tmp
num_chunks
0
if(tmp->num_chunks >= total_chunks || tmp->num_chunks
0)
tw_output
lp
\n
invalid number of chunks %d for LP %ld "
tmp
num_chunks
lp
gid
tw_output(lp, "\n invalid number of chunks %d for LP %ld ", tmp->num_chunks, lp->gid);
tw_lp_suspend(lp, 0, 0);
return;
return;
assert
lp
gid
msg
dest_terminal_id
assert
lp
gid
msg
dest_terminal_id
if
msg
packet_ID
LLU
TRACK_PKT
if
msg
packet_ID
LLU
TRACK_PKT
@@ -1571,7 +1571,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
assert
tmp
assert
tmp
tmp
num_chunks
tmp
num_chunks
/* if its the last chunk of the packet then handle the remote event data */
if
msg
chunk_id
num_chunks
1
if
msg
chunk_id
num_chunks
1
bf
c1
1
bf
c1
1
@@ -1581,6 +1580,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
N_finished_packets
N_finished_packets
s
finished_packets
s
finished_packets
if
msg
remote_event_size_bytes
0
tmp
remote_event_data
if
msg
0
tmp
remote_event_data
/* Retreive the remote event entry */
tests/conf/modelnet-test-dragonfly.conf
View file @
47bbd8b0
@@ -14,7 +14,7 @@ PARAMS
modelnet_order
"dragonfly"
"dragonfly_router"
modelnet_order
"dragonfly"
"dragonfly_router"
# scheduler options
# scheduler options
modelnet_scheduler
"fcfs"
modelnet_scheduler
"fcfs"
chunk_size
3
2"
chunk_size
"2
56
num_routers
"4"
num_routers
"4"
local_vc_size
"2048"
local_vc_size
"2048"
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
