Commit 45f18ddf authored by Philip Carns's avatar Philip Carns
Browse files
update Darshan instructions
parent 9f2740fa
...@@ -49,10 +49,14 @@ working from the CODES master branches, use the ROSS master branch. ...@@ -49,10 +49,14 @@ working from the CODES master branches, use the ROSS master branch.
breaks libdumpi's function wrappers through const'ifying the MPI breaks libdumpi's function wrappers through const'ifying the MPI
interface). interface).
To enable using the darshan I/O generator Use the --with-darshan argument to configure to enable the optional
(http://www.mcs.anl.gov/research/projects/darshan/), use the option Darshan I/O workload generator
--with-darshan=/path/to/darshan with configure (http://www.mcs.anl.gov/research/projects/darshan/). In order to use
this option, you must either have the darshan-util portion
of Darshan installed in the default system path, or else add
<DARSHAN_PREFIX>/lib/pkgconfig to your PKG_CONFIG_PATH environment
variable before calling configure.
3 - Build and install codes-base 3 - Build and install codes-base
make && make install make && make install
Markdown is supported
0% or .
Please register or to comment
