Commit 2b5f713e authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
cleaned, made user-friendly the workload print util
parent dc5519e2
...@@ -17,16 +17,25 @@ static struct option long_opts[] = ...@@ -17,16 +17,25 @@ static struct option long_opts[] =
{"type", required_argument, NULL, 't'}, {"type", required_argument, NULL, 't'},
{"num-ranks", required_argument, NULL, 'n'}, {"num-ranks", required_argument, NULL, 'n'},
{"d-log", optional_argument, NULL, 'l'}, {"d-log", required_argument, NULL, 'l'},
{"d-aggregator-cnt", optional_argument, NULL, 'a'}, {"d-aggregator-cnt", required_argument, NULL, 'a'},
{NULL, 0, NULL, 0} {NULL, 0, NULL, 0}
void usage(){
fprintf(stderr,
"Usage: codes-workload-dump --type TYPE --num-ranks N "
"[--d-log LOG --d-aggregator-cnt CNT]\n"
"--type: type of workload (currently only \"darshan_io_workload\")\n"
"--num-ranks: number of ranks to process\n"
"--d-log: darshan log file\n"
"--d-aggregator-cnt: number of aggregators for collective I/O in darshan\n");
int main(int argc, char *argv[]) int main(int argc, char *argv[])
char ch; char ch;
while ((ch = getopt_long(argc, argv, "t:l:a:", long_opts, NULL)) != -1){ while ((ch = getopt_long(argc, argv, "t:n:l:a:", long_opts, NULL)) != -1){
switch (ch){ switch (ch){
case 't': case 't':
strcpy(type, optarg); strcpy(type, optarg);
...@@ -44,13 +53,38 @@ int main(int argc, char *argv[]) ...@@ -44,13 +53,38 @@ int main(int argc, char *argv[])
if (type[0] == '\0'){
fprintf(stderr, "Expected \"--type\" argument\n");
usage();
return 1;
if (n == -1){
fprintf(stderr, "Expected \"--num-ranks\" argument\n");
usage();
return 1;
int i; int i;
char *wparams; char *wparams;
if (strcmp(type, "darshan_io_workload") == 0){ if (strcmp(type, "darshan_io_workload") == 0){
wparams = (char*)&d_params; if (d_params.log_file_path[0] == '\0'){
fprintf(stderr, "Expected \"--d-log\" argument for darshan workload\n");
usage();
return 1;
else if (d_params.aggregator_cnt == 0){
fprintf(stderr, "Expected \"--d-aggregator-cnt\" argument for darshan workload\n");
usage();
return 1;
else{
else { else {
wparams = NULL; fprintf(stderr, "Invalid type argument\n");
usage();
return 1;
for (i = 0 ; i < n; i++){ for (i = 0 ; i < n; i++){
struct codes_workload_op op; struct codes_workload_op op;
Markdown is supported
0% or .
Please register or to comment
