Commit 2b0cd41e authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
modelnet sampling interface and event loop
NOTE: no models implement it yet
parent 3059a209
...@@ -97,6 +97,8 @@ enum model_net_base_event_type { ...@@ -97,6 +97,8 @@ enum model_net_base_event_type {
MN_BASE_NEW_MSG, MN_BASE_NEW_MSG,
// schedule next packet // schedule next packet
MN_BASE_SCHED_NEXT, MN_BASE_SCHED_NEXT,
// gather a sample from the underlying model
MN_BASE_SAMPLE,
// message goes directly down to topology-specific event handler // message goes directly down to topology-specific event handler
MN_BASE_PASS MN_BASE_PASS
...@@ -54,7 +54,11 @@ struct model_net_method ...@@ -54,7 +54,11 @@ struct model_net_method
int (*mn_get_msg_sz)(); int (*mn_get_msg_sz)();
void (*mn_report_stats)(); void (*mn_report_stats)();
void (*mn_collective_call)(char const * category, int message_size, int remote_event_size, const void* remote_event, tw_lp* sender); void (*mn_collective_call)(char const * category, int message_size, int remote_event_size, const void* remote_event, tw_lp* sender);
void (*mn_collective_call_rc)(int message_size, tw_lp* sender); void (*mn_collective_call_rc)(int message_size, tw_lp* sender);
event_f mn_sample_fn;
revent_f mn_sample_rc_fn;
init_f mn_sample_init_fn;
final_f mn_sample_fini_fn;
extern struct model_net_method * method_array[]; extern struct model_net_method * method_array[];
...@@ -140,6 +140,14 @@ void model_net_register(); ...@@ -140,6 +140,14 @@ void model_net_register();
* modelnet_order configuration parameter */ * modelnet_order configuration parameter */
int* model_net_configure(int *id_count); int* model_net_configure(int *id_count);
/* Sets up a sampling loop for model net events. The sampling data provided by
* each modelnet lp is model-defined. This is a PE-wide setting. Data is sent
* to LP-IO with the category modelnet-samples */
void model_net_enable_sampling(tw_stime interval);
/* Returns 1 if modelnet is performing sampling, 0 otherwise */
int model_net_sampling_enabled(void);
/* Initialize/configure the network(s) based on the CODES configuration. /* Initialize/configure the network(s) based on the CODES configuration.
* returns an array of the network ids, indexed in the order given by the * returns an array of the network ids, indexed in the order given by the
* modelnet_order configuration parameter * modelnet_order configuration parameter
...@@ -2851,6 +2851,10 @@ struct model_net_method dragonfly_method = ...@@ -2851,6 +2851,10 @@ struct model_net_method dragonfly_method =
.mn_get_msg_sz = dragonfly_get_msg_sz, .mn_get_msg_sz = dragonfly_get_msg_sz,
.mn_report_stats = dragonfly_report_stats, .mn_report_stats = dragonfly_report_stats,
.mn_collective_call = dragonfly_collective, .mn_collective_call = dragonfly_collective,
.mn_collective_call_rc = dragonfly_collective_rc .mn_collective_call_rc = dragonfly_collective_rc,
.mn_sample_fn = NULL,
.mn_sample_rc_fn = NULL,
.mn_sample_init_fn = NULL,
.mn_sample_fini_fn = NULL
...@@ -155,7 +155,11 @@ struct model_net_method loggp_method = ...@@ -155,7 +155,11 @@ struct model_net_method loggp_method =
.mn_get_msg_sz = loggp_get_msg_sz, .mn_get_msg_sz = loggp_get_msg_sz,
.mn_report_stats = loggp_report_stats, .mn_report_stats = loggp_report_stats,
.mn_collective_call = loggp_collective, .mn_collective_call = loggp_collective,
.mn_collective_call_rc = loggp_collective_rc .mn_collective_call_rc = loggp_collective_rc,
static void loggp_init( static void loggp_init(
...@@ -35,6 +35,9 @@ static int num_params = 0; ...@@ -35,6 +35,9 @@ static int num_params = 0;
static const char * annos[CONFIGURATION_MAX_ANNOS]; static const char * annos[CONFIGURATION_MAX_ANNOS];
static model_net_base_params all_params[CONFIGURATION_MAX_ANNOS]; static model_net_base_params all_params[CONFIGURATION_MAX_ANNOS];
static tw_stime mn_sample_interval = 0.0;
static int mn_sample_enabled = 0;
typedef struct model_net_base_state { typedef struct model_net_base_state {
int net_id; int net_id;
// whether scheduler loop is running // whether scheduler loop is running
...@@ -112,6 +115,26 @@ tw_lptype model_net_base_lp = { ...@@ -112,6 +115,26 @@ tw_lptype model_net_base_lp = {
/**** BEGIN IMPLEMENTATIONS ****/ /**** BEGIN IMPLEMENTATIONS ****/
mn_sample_interval = interval;
mn_sample_enabled = 1;
return mn_sample_enabled;
// schedule sample event - want to be precise, so no noise here
static void issue_sample_event(tw_lp *lp)
tw_event *e = tw_event_new(lp->gid, mn_sample_interval, lp);
model_net_wrap_msg *m = tw_event_data(e);
msg_set_header(model_net_base_magic, MN_BASE_SAMPLE, lp->gid, &m->h);
tw_event_send(e);
void model_net_base_register(int *do_config_nets){ void model_net_base_register(int *do_config_nets){
// here, we initialize ALL lp types to use the base type // here, we initialize ALL lp types to use the base type
for (int i = 0; i < MAX_NETS; i++){ for (int i = 0; i < MAX_NETS; i++){
...@@ -319,6 +342,28 @@ void model_net_base_lp_init( ...@@ -319,6 +342,28 @@ void model_net_base_lp_init(
// initialize the model-net method // initialize the model-net method
ns->sub_type->init(ns->sub_state, lp); ns->sub_type->init(ns->sub_state, lp);
// check validity of sampling function
event_f sample = method_array[ns->net_id]->mn_sample_fn;
revent_f rsample = method_array[ns->net_id]->mn_sample_rc_fn;
if (model_net_sampling_enabled()) {
if (sample == NULL) {
tw_error(TW_LOC,
"Sampling requested for a model that doesn't provide it\n");
else if (rsample == NULL &&
(g_tw_synchronization_protocol == OPTIMISTIC ||
g_tw_synchronization_protocol == OPTIMISTIC_DEBUG)) {
tw_error(TW_LOC,
else {
init_f sinit = method_array[ns->net_id]->mn_sample_init_fn;
if (sinit != NULL)
sinit(ns->sub_state, lp);
issue_sample_event(lp);
void model_net_base_event( void model_net_base_event(
...@@ -327,7 +372,8 @@ void model_net_base_event( ...@@ -327,7 +372,8 @@ void model_net_base_event(
model_net_wrap_msg * m, model_net_wrap_msg * m,
tw_lp * lp){ tw_lp * lp){
assert(m->h.magic == model_net_base_magic); assert(m->h.magic == model_net_base_magic);
void * sub_msg;
switch (m->h.event_type){ switch (m->h.event_type){
case MN_BASE_NEW_MSG: case MN_BASE_NEW_MSG:
handle_new_msg(ns, b, m, lp); handle_new_msg(ns, b, m, lp);
...@@ -335,8 +381,15 @@ void model_net_base_event( ...@@ -335,8 +381,15 @@ void model_net_base_event(
case MN_BASE_SCHED_NEXT: case MN_BASE_SCHED_NEXT:
handle_sched_next(ns, b, m, lp); handle_sched_next(ns, b, m, lp);
break; break;
case MN_BASE_SAMPLE: ;
assert(model_net_sampling_enabled() && sample != NULL);
sub_msg = ((char*)m)+msg_offsets[ns->net_id];
sample(ns->sub_state, b, sub_msg, lp);
break;
case MN_BASE_PASS: ; case MN_BASE_PASS: ;
void * sub_msg = ((char*)m)+msg_offsets[ns->net_id]; sub_msg = ((char*)m)+msg_offsets[ns->net_id];
ns->sub_type->event(ns->sub_state, b, sub_msg, lp); ns->sub_type->event(ns->sub_state, b, sub_msg, lp);
break; break;
...@@ -352,7 +405,8 @@ void model_net_base_event_rc( ...@@ -352,7 +405,8 @@ void model_net_base_event_rc(
void * sub_msg;
handle_new_msg_rc(ns, b, m, lp); handle_new_msg_rc(ns, b, m, lp);
...@@ -360,8 +414,14 @@ void model_net_base_event_rc( ...@@ -360,8 +414,14 @@ void model_net_base_event_rc(
handle_sched_next_rc(ns, b, m, lp); handle_sched_next_rc(ns, b, m, lp);
break; break;
revent_f sample_rc = method_array[ns->net_id]->mn_sample_rc_fn;
assert(model_net_sampling_enabled() && sample_rc != NULL);
sample_rc(ns->sub_state, b, sub_msg, lp);
break;
ns->sub_type->revent(ns->sub_state, b, sub_msg, lp); ns->sub_type->revent(ns->sub_state, b, sub_msg, lp);
break; break;
...@@ -369,13 +429,14 @@ void model_net_base_event_rc( ...@@ -369,13 +429,14 @@ void model_net_base_event_rc(
assert(!"model_net_base event type not known"); assert(!"model_net_base event type not known");
break; break;
*(int*)b = 0;
void model_net_base_finalize( void model_net_base_finalize(
model_net_base_state * ns, model_net_base_state * ns,
final_f sfini = method_array[ns->net_id]->mn_sample_fini_fn;
if (sfini != NULL)
sfini(ns->sub_state, lp);
ns->sub_type->final(ns->sub_state, lp); ns->sub_type->final(ns->sub_state, lp);
free(ns->sub_state); free(ns->sub_state);
...@@ -120,8 +120,12 @@ struct model_net_method simplenet_method = ...@@ -120,8 +120,12 @@ struct model_net_method simplenet_method =
.mn_get_lp_type = sn_get_lp_type, .mn_get_lp_type = sn_get_lp_type,
.mn_get_msg_sz = sn_get_msg_sz, .mn_get_msg_sz = sn_get_msg_sz,
.mn_report_stats = sn_report_stats, .mn_report_stats = sn_report_stats,
.mn_collective_call = simple_net_collective, .mn_collective_call = simple_net_collective,
.mn_collective_call_rc = simple_net_collective_rc .mn_collective_call_rc = simple_net_collective_rc,
static void sn_init( static void sn_init(
...@@ -151,7 +151,11 @@ struct model_net_method simplep2p_method = ...@@ -151,7 +151,11 @@ struct model_net_method simplep2p_method =
.mn_get_msg_sz = sp_get_msg_sz, .mn_get_msg_sz = sp_get_msg_sz,
.mn_report_stats = sp_report_stats, .mn_report_stats = sp_report_stats,
.mn_collective_call = simple_wan_collective, .mn_collective_call = simple_wan_collective,
.mn_collective_call_rc = simple_wan_collective_rc .mn_collective_call_rc = simple_wan_collective_rc,
static void sp_init( static void sp_init(
...@@ -1981,7 +1981,11 @@ struct model_net_method torus_method = ...@@ -1981,7 +1981,11 @@ struct model_net_method torus_method =
.mn_get_msg_sz = torus_get_msg_sz, .mn_get_msg_sz = torus_get_msg_sz,
.mn_report_stats = torus_report_stats, .mn_report_stats = torus_report_stats,
.mn_collective_call = torus_collective, .mn_collective_call = torus_collective,
.mn_collective_call_rc = torus_collective_rc .mn_collective_call_rc = torus_collective_rc,
/* user-facing modelnet functions */ /* user-facing modelnet functions */
Markdown is supported
0% or .
Please register or to comment
