Commit 28489902 authored by Shane Snyder's avatar Shane Snyder
Browse files
Autoconf bug fix to get darshan-util lib path
parent 3c2a04b5
...@@ -96,7 +96,8 @@ if test "x${with_darshan}" != "x" ; then ...@@ -96,7 +96,8 @@ if test "x${with_darshan}" != "x" ; then
AC_CHECK_FILE([${with_darshan}/lib/pkgconfig/darshan-util.pc], AC_CHECK_FILE([${with_darshan}/lib/pkgconfig/darshan-util.pc],
AM_CONDITIONAL(USE_DARSHAN, true), AM_CONDITIONAL(USE_DARSHAN, true),
AC_MSG_ERROR(Could not find darshan-util.pc)) AC_MSG_ERROR(Could not find darshan-util.pc))
DARSHAN_LIBS=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --static --libs` DARSHAN_LIBS=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --libs`
DARSHAN_LIBS+=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --static --libs`
DARSHAN_CFLAGS=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --cflags` DARSHAN_CFLAGS=`PKG_CONFIG_PATH=${with_darshan}/lib/pkgconfig pkg-config darshan-util --cflags`
AC_SUBST(DARSHAN_LIBS) AC_SUBST(DARSHAN_LIBS)
AC_SUBST(DARSHAN_CFLAGS) AC_SUBST(DARSHAN_CFLAGS)
Markdown is supported
0% or .
Please register or to comment
