Commit 2621641d authored by Misbah Mubarak's avatar Misbah Mubarak
Adding documentation for random allocation script
parent 18ef519a
...@@ -10,4 +10,11 @@ There are three lines in the config_alloc.conf file. ...@@ -10,4 +10,11 @@ There are three lines in the config_alloc.conf file.
dragonfly, this number would be 1056 dragonfly, this number would be 1056
3rd line: the number of ranks of each application. 3rd line: the number of ranks of each application.
To generate multiple random allocations with the same network configuration,
listgen-upd.py can be used (Works only for random allocations right now). The
configuration file (Example in config_alloc-upd) will then look like:
1st line: allocation policy, must be rand
2nd line: the total terminal number of nodes in the system
3rd line: the number of random allocations to generate
4th line: number of ranks for each application.
Markdown is supported
0%
or
Please register or to comment
