Commit 1a1aa525 authored by Philip Carns's avatar Philip Carns
Browse files
add lp-io-test along with make check rules/script
parent 61860f5c
...@@ -33,4 +33,5 @@ AM_CXXFLAGS = $(AM_CFLAGS) ...@@ -33,4 +33,5 @@ AM_CXXFLAGS = $(AM_CFLAGS)
include Make.rules include Make.rules
include $(top_srcdir)/src/Makefile.subdir include $(top_srcdir)/src/Makefile.subdir
include $(top_srcdir)/tests/Makefile.subdir
check_PROGRAMS += tests/lp-io-test
TESTS += tests/lp-io-test.sh
EXTRA_DIST += tests/lp-io-test.sh
testlib = src/libcodes-base.a
tests_lp_io_test_LDADD = $(testlib) ${ROSS_LIBS}
tests_lp_io_test_LDFLAGS = ${ROSS_LDFLAGS}
tests_lp_io_test_SOURCES = tests/lp-io-test.c
* Copyright (C) 2011, University of Chicago
* See COPYRIGHT notice in top-level directory.
/* SUMMARY:
* This is a test harness for the lp-io API. It sets up a number of LPs and
* has each of them write some portion of various data sets.
#include <string.h>
#include <assert.h>
#include <ross.h>
#include "codes/lp-io.h"
#include "codes/codes.h"
#define NUM_SERVERS 16 /* number of servers */
typedef struct svr_msg svr_msg;
typedef struct svr_state svr_state;
enum svr_event_type
KICKOFF, /* initial event */
struct svr_state
struct svr_msg
enum svr_event_type event_type;
tw_lpid src; /* source of this request or ack */
const tw_optdef app_opt[] = {
TWOPT_GROUP("lp-io Test Model"),
TWOPT_END()
static void svr_init(
svr_state * ns,
tw_lp * lp);
static void svr_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void svr_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void svr_finalize(
svr_state * ns,
tw_lp * lp);
static tw_peid svr_node_mapping(
tw_lpid gid);
tw_lptype svr_lp = {
(init_f) svr_init,
(event_f) svr_event,
(revent_f) svr_rev_event,
(final_f) svr_finalize,
(map_f) svr_node_mapping,
sizeof(svr_state),
static void handle_kickoff_rev_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
static void handle_kickoff_event(
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp);
int main(
int argc,
char **argv)
int nprocs;
int rank;
int lps_per_proc;
int i;
int ret;
lp_io_handle handle;
g_tw_ts_end = 60*60*24*365;
tw_opt_add(app_opt);
tw_init(&argc, &argv);
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
if((NUM_SERVERS) % nprocs)
fprintf(stderr, "Error: number of server LPs (%d total) is not evenly divisible by the number of MPI processes (%d)\n", NUM_SERVERS, nprocs);
exit(-1);
lps_per_proc = (NUM_SERVERS) / nprocs;
tw_define_lps(lps_per_proc, sizeof(struct svr_msg), 0);
for(i=0; i<lps_per_proc; i++)
tw_lp_settype(i, &svr_lp);
g_tw_lookahead = 100;
ret = lp_io_prepare("lp-io-test-results", LP_IO_UNIQ_SUFFIX, &handle, MPI_COMM_WORLD);
if(ret < 0)
return(-1);
tw_run();
ret = lp_io_flush(handle, MPI_COMM_WORLD);
assert(ret == 0);
tw_end();
return 0;
svr_state * ns,
tw_lp * lp)
tw_event *e;
svr_msg *m;
tw_stime kickoff_time;
memset(ns, 0, sizeof(*ns));
/* each server sends a dummy event to itself */
/* skew each kickoff event slightly to help avoid event ties later on */
kickoff_time = g_tw_lookahead + tw_rand_unif(lp->rng);
e = codes_event_new(lp->gid, kickoff_time, lp);
m = tw_event_data(e);
m->event_type = KICKOFF;
tw_event_send(e);
return;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
switch (m->event_type)
case KICKOFF:
handle_kickoff_event(ns, b, m, lp);
break;
default:
assert(0);
break;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
case KICKOFF:
handle_kickoff_rev_event(ns, b, m, lp);
break;
default:
assert(0);
break;
return;
svr_state * ns,
tw_lp * lp)
char buffer[256];
int ret;
sprintf(buffer, "LP %ld finalize data\n", (long)lp->gid);
/* test having everyone write to same identifier */
ret = lp_io_write(lp->gid, "node_state_pointers", strlen(buffer)+1, buffer);
assert(ret == 0);
/* test having only one lp write to a particular identifier */
if(lp->gid == 3)
ret = lp_io_write(lp->gid, "subset_example", strlen(buffer)+1, buffer);
assert(ret == 0);
/* test having one lp write two buffers to the same id */
if(lp->gid == 5)
sprintf(buffer, "LP %ld finalize data (intentional duplicate)\n", (long)lp->gid);
assert(ret == 0);
return;
tw_lpid gid)
return (tw_peid) gid / g_tw_nlp;
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
assert(0);
return;
/* handle initial event */
svr_state * ns,
tw_bf * b,
svr_msg * m,
tw_lp * lp)
//printf("handle_kickoff_event(), lp %llu.\n", (unsigned long long)lp->gid);
/* do nothing */
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
#!/bin/bash
tests/lp-io-test --sync=1
Markdown is supported
0% or .
Please register or to comment
