Commit 16787f14 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
clean up best practices doc
parent f25d26a7
...@@ -21,9 +21,7 @@ int lp_io_prepare(char *directory, int flags, lp_io_handle* handle, MPI_Comm com ...@@ -21,9 +21,7 @@ int lp_io_prepare(char *directory, int flags, lp_io_handle* handle, MPI_Comm com
/* to be called within LPs to store a block of data */ /* to be called within LPs to store a block of data */
int lp_io_write(tw_lpid gid, char* identifier, int size, void* buffer); int lp_io_write(tw_lpid gid, char* identifier, int size, void* buffer);
/* undo the immediately preceding write for the given LP /* undo the immediately preceding write for the given LP */
* (hack for logging/testing optimistic mode, not recommended for general use)
int lp_io_write_rev(tw_lpid gid, char* identifier); int lp_io_write_rev(tw_lpid gid, char* identifier);
/* to be called (collectively) after tw_run() to flush data to disk */ /* to be called (collectively) after tw_run() to flush data to disk */
This diff is collapsed.
Markdown is supported
0% or .
Please register or to comment
