Commit 13e494da authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
formatting footers
parent b860fa0f
...@@ -720,3 +720,12 @@ struct codes_workload_method dumpi_trace_workload_method = ...@@ -720,3 +720,12 @@ struct codes_workload_method dumpi_trace_workload_method =
.codes_workload_load = dumpi_trace_nw_workload_load, .codes_workload_load = dumpi_trace_nw_workload_load,
.codes_workload_get_next = dumpi_trace_nw_workload_get_next, .codes_workload_get_next = dumpi_trace_nw_workload_get_next,
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
...@@ -219,3 +219,11 @@ static int hash_rank_compare(void *key, struct qhash_head *link) ...@@ -219,3 +219,11 @@ static int hash_rank_compare(void *key, struct qhash_head *link)
return 0; return 0;
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
...@@ -135,3 +135,11 @@ void scala_trace_nw_workload_get_next(int rank, struct codes_workload_op *op) ...@@ -135,3 +135,11 @@ void scala_trace_nw_workload_get_next(int rank, struct codes_workload_op *op)
assert(current_counter <= mpi_info.events_per_rank); assert(current_counter <= mpi_info.events_per_rank);
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
Markdown is supported
0% or .
Please register or to comment
