Commit 0875c01a authored by Jonathan Jenkins's avatar Jonathan Jenkins
promote configfile to public API
parent f0c2ef4b
...@@ -91,7 +91,8 @@ nobase_include_HEADERS = \ ...@@ -91,7 +91,8 @@ nobase_include_HEADERS = \
codes/net/loggp.h \ codes/net/loggp.h \
codes/net/simplenet-upd.h \ codes/net/simplenet-upd.h \
codes/net/simplep2p.h \ codes/net/simplep2p.h \
codes/net/torus.h codes/net/torus.h \
codes/configfile.h
#codes/codes-nw-workload.h #codes/codes-nw-workload.h
...@@ -114,7 +115,6 @@ src_libcodes_a_SOURCES = \ ...@@ -114,7 +115,6 @@ src_libcodes_a_SOURCES = \
src/modelconfig/configfile.c \ src/modelconfig/configfile.c \
src/modelconfig/configglue.h \ src/modelconfig/configglue.h \
src/modelconfig/configglue.c \ src/modelconfig/configglue.c \
src/modelconfig/configfile.h \
src/modelconfig/configstore.h \ src/modelconfig/configstore.h \
src/modelconfig/configstore.c \ src/modelconfig/configstore.c \
src/modelconfig/configstoreadapter.h \ src/modelconfig/configstoreadapter.h \
...@@ -15,7 +15,7 @@ ...@@ -15,7 +15,7 @@
#include <stdlib.h> #include <stdlib.h>
#endif #endif
#include "configfile.h" #include <codes/configfile.h>
#include "txt_configfile.h" #include "txt_configfile.h"
static int cf_equal_helper (struct ConfigVTable * h1, SectionHandle s1, struct ConfigVTable * h2, static int cf_equal_helper (struct ConfigVTable * h1, SectionHandle s1, struct ConfigVTable * h2,
...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
/* Common header for parser and lexer */ /* Common header for parser and lexer */
typedef struct typedef struct
...@@ -7,7 +7,7 @@ ...@@ -7,7 +7,7 @@
#ifndef SRC_COMMON_MODELCONFIG_CONFIGSTOREADAPTER_H #ifndef SRC_COMMON_MODELCONFIG_CONFIGSTOREADAPTER_H
#define SRC_COMMON_MODELCONFIG_CONFIGSTOREADAPTER_H #define SRC_COMMON_MODELCONFIG_CONFIGSTOREADAPTER_H
#include "configstore.h" #include "configstore.h"
#ifdef __cplusplus #ifdef __cplusplus
...@@ -13,7 +13,7 @@ ...@@ -13,7 +13,7 @@
#include "codes/configuration.h" #include "codes/configuration.h"
#include <ross.h> #include <ross.h>
#include <stdio.h> #include <stdio.h>
extern "C" { extern "C" {
Markdown is supported
0%
or
Please register or to comment
