Commit 059c243b authored by Noah Wolfe's avatar Noah Wolfe Committed by Nikhil
Browse files
replaced dest_num with dest_terminal_id in fattree.c
parent fda6d012
...@@ -243,7 +243,7 @@ static void copy_fattree_list_entry( fattree_message_list *cur_entry, ...@@ -243,7 +243,7 @@ static void copy_fattree_list_entry( fattree_message_list *cur_entry,
strcpy(msg->category, cur_msg->category); strcpy(msg->category, cur_msg->category);
msg->final_dest_gid = cur_msg->final_dest_gid; msg->final_dest_gid = cur_msg->final_dest_gid;
msg->sender_lp = cur_msg->sender_lp; msg->sender_lp = cur_msg->sender_lp;
msg->dest_num = cur_msg->dest_num; msg->dest_terminal_id = cur_msg->dest_terminal_id;
msg->src_terminal_id = cur_msg->src_terminal_id; msg->src_terminal_id = cur_msg->src_terminal_id;
msg->intm_lp_id = cur_msg->intm_lp_id; msg->intm_lp_id = cur_msg->intm_lp_id;
msg->saved_vc = cur_msg->saved_vc; msg->saved_vc = cur_msg->saved_vc;
...@@ -857,11 +857,11 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg ...@@ -857,11 +857,11 @@ void ft_packet_generate(ft_terminal_state * s, tw_bf * bf, fattree_message * msg
codes_mapping_get_lp_info(msg->final_dest_gid, lp_group_name, &mapping_grp_id, codes_mapping_get_lp_info(msg->final_dest_gid, lp_group_name, &mapping_grp_id,
NULL, &mapping_type_id, NULL, &mapping_rep_id, &mapping_offset); NULL, &mapping_type_id, NULL, &mapping_rep_id, &mapping_offset);
msg->dest_num = (mapping_rep_id * (p->switch_radix[0] / 2)) + msg->dest_terminal_id = (mapping_rep_id * (p->switch_radix[0] / 2)) +
(mapping_offset % (p->switch_radix[0]/2)); (mapping_offset % (p->switch_radix[0]/2));
//message for process on the same terminal //message for process on the same terminal
if(msg->dest_num == s->terminal_id) { if(msg->dest_terminal_id == s->terminal_id) {
bf->c1 = 1; bf->c1 = 1;
model_net_method_idle_event(nic_ts - s->params->cn_delay * msg->packet_size, 0, lp); model_net_method_idle_event(nic_ts - s->params->cn_delay * msg->packet_size, 0, lp);
// Trigger an event on receiving server // Trigger an event on receiving server
...@@ -1360,8 +1360,8 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1360,8 +1360,8 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg,
if(s->switch_level == 0) { if(s->switch_level == 0) {
//message for a terminal node //message for a terminal node
if(msg->dest_num >= s->start_lneigh && msg->dest_num < s->end_lneigh) { if(msg->dest_terminal_id >= s->start_lneigh && msg->dest_terminal_id < s->end_lneigh) {
outport = msg->dest_num - s->start_lneigh; outport = msg->dest_terminal_id - s->start_lneigh;
*out_off = 0; *out_off = 0;
return outport; return outport;
} else { //go up the least congested path } else { //go up the least congested path
...@@ -1369,7 +1369,7 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1369,7 +1369,7 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg,
end_port = s->num_cons; end_port = s->num_cons;
} else if(s->switch_level == 1) { } else if(s->switch_level == 1) {
int dest_switch_id = msg->dest_num / (p->switch_radix[0] / 2); int dest_switch_id = msg->dest_terminal_id / (p->switch_radix[0] / 2);
//if only two level or packet going down, send to the right switch //if only two level or packet going down, send to the right switch
if(p->num_levels == 2 || (dest_switch_id >= s->start_lneigh && if(p->num_levels == 2 || (dest_switch_id >= s->start_lneigh &&
dest_switch_id < s->end_lneigh)) { dest_switch_id < s->end_lneigh)) {
...@@ -1380,7 +1380,7 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1380,7 +1380,7 @@ int ft_get_output_port( switch_state * s, tw_bf * bf, fattree_message * msg,
} else { //switch level 2 } else { //switch level 2
int dest_l1_group = msg->dest_num / p->l1_term_size; int dest_l1_group = msg->dest_terminal_id / p->l1_term_size;
if(s->params->ft_type == 0) { if(s->params->ft_type == 0) {
start_port = dest_l1_group * (p->l1_set_size/2) * s->con_per_lneigh; start_port = dest_l1_group * (p->l1_set_size/2) * s->con_per_lneigh;
end_port = start_port + ((p->l1_set_size/2) * s->con_per_lneigh); end_port = start_port + ((p->l1_set_size/2) * s->con_per_lneigh);
...@@ -1501,7 +1501,7 @@ void switch_event(switch_state * s, tw_bf * bf, fattree_message * msg, ...@@ -1501,7 +1501,7 @@ void switch_event(switch_state * s, tw_bf * bf, fattree_message * msg,
default: default:
printf("\n (%lf) [Switch %d] Switch Message type not supported %d " printf("\n (%lf) [Switch %d] Switch Message type not supported %d "
"dest terminal id %d packet ID %d ", tw_now(lp), (int)lp->gid, "dest terminal id %d packet ID %d ", tw_now(lp), (int)lp->gid,
msg->type, (int)msg->dest_num, (int)msg->packet_ID); msg->type, (int)msg->dest_terminal_id, (int)msg->packet_ID);
tw_error(TW_LOC, "Msg type not supported in switch"); tw_error(TW_LOC, "Msg type not supported in switch");
break; break;
Markdown is supported
0% or .
Please register or to comment
