Commit 0172498f authored by Jonathan Jenkins's avatar Jonathan Jenkins Committed by Justin Wozniak
Browse files
version bump, changelog cleanup
parent 39ff7fcc
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
# Process this file with autoconf to produce a configure script. # Process this file with autoconf to produce a configure script.
AC_PREREQ([2.67]) AC_PREREQ([2.67])
AC_INIT([codes], [0.5.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes], [0.5.1], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
AC_CANONICAL_TARGET AC_CANONICAL_TARGET
AC_CANONICAL_SYSTEM AC_CANONICAL_SYSTEM
0.5.0 0.5.1 (June 09, 2016)
network:
corrected link latency calculation in dragonfly model
printf argument mismatch in dragonfly model
refactors to the torus bandwidth calculation to mirror that of the other
networks (no functional change)
more robust type conversions in dragonfly (int sizes -> uint64_t)
0.5.0 (May 24, 2016)
general: general:
...@@ -88,8 +104,18 @@ model_net_event_rc (use model_net_event_rc2, which will eventually be renamed ...@@ -88,8 +104,18 @@ model_net_event_rc (use model_net_event_rc2, which will eventually be renamed
codes_event_new (define your own bounds-checking macro if need be) codes_event_new (define your own bounds-checking macro if need be)
0.4.0 0.4.1 (September 30, 2015)
general:
fix compatibility with recent ROSS releases
0.4.0 (May 6, 2015)
codes-base codes-base
...@@ -215,7 +241,9 @@ Adding network workload test program for debugging ...@@ -215,7 +241,9 @@ Adding network workload test program for debugging
Updating MPI wait/wait_all code in replay tool Updating MPI wait/wait_all code in replay tool
0.3.0 ----------
0.3.0 (November 7, 2014)
Markdown is supported
0% or .
Please register or to comment
