Skip to content
GitLab
Menu
Projects
Groups
Snippets
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
Shane Snyder
darshan
Commits
9e6663d9
Commit
9e6663d9
authored
May 23, 2016
by
Philip Carns
Browse files
fscanf and vfscanf wrappers
- needs testing
parent
da08451f
Changes
2
Show whitespace changes
Inline
Side-by-side
darshan-runtime/lib/darshan-stdio.c
View file @
9e6663d9
@@ -16,6 +16,7 @@
@@ -16,6 +16,7 @@
* - POSIX_FWRITES
* - POSIX_FWRITES
* - POSIX_FSEEKS
* - POSIX_FSEEKS
* - add regression test cases for all functions captured here
* - especially the scanf and printf variants
/* catalog of stdio functions instrumented by this module
@@ -39,7 +40,8 @@
@@ -39,7 +40,8 @@
* int fgetc(FILE *); DONE
* char *fgets(char *, int, FILE *); DONE
* size_t fread(void *, size_t, size_t, FILE *); DONE
* int fscanf(FILE *, const char *, ...);
* int fscanf(FILE *, const char *, ...); DONE
* int vfscanf(FILE *, const char *, va_list); DONE
* int getc(FILE *);
* int getc(FILE *);
* int getc_unlocked(FILE *);
* int getw(FILE *);
* int getw(FILE *);
@@ -100,6 +102,8 @@ DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
fwrite
size_t
const
void
ptr
size_t
size
size_t
nmemb
FILE
stream
fwrite
size_t
const
void
ptr
size_t
size
size_t
nmemb
FILE
stream
fread
size_t
void
ptr
size_t
size
size_t
nmemb
FILE
stream
fread
size_t
void
ptr
size_t
size
size_t
nmemb
FILE
stream
fgetc
int
FILE
stream
fgetc
int
FILE
stream
fscanf
int
FILE
stream
const
char
format
vfscanf
int
FILE
stream
const
char
format
va_list
ap
fgets
char
char
s
int
size
FILE
stream
fgets
char
char
s
int
size
FILE
stream
fseek
int
FILE
stream
long
offset
int
whence
fseek
int
FILE
stream
long
offset
int
whence
@@ -449,6 +453,59 @@ size_t DARSHAN_DECL(fgetc)(FILE *stream)
return
ret
return
ret
int
DARSHAN_DECL
fscanf
FILE
stream
const
char
format
int
ret
double
tm1
tm2
va_list
ap
long
start_off
end_off
MAP_OR_FAIL
vfscanf
tm1
darshan_core_wtime
/* NOTE: we intentionally switch to vfscanf here to handle the variable
* length arguments.
start_off
ftell
stream
va_start
ap
format
ret
__real_vfscanf
stream
format
ap
va_end
ap
end_off
ftell
stream
tm2
darshan_core_wtime
STDIO_LOCK
stdio_runtime_initialize
if
ret
0
STDIO_RECORD_READ
stream
end_off
start_off
tm1
tm2
STDIO_UNLOCK
return
ret
int
DARSHAN_DECL
vfscanf
FILE
stream
const
char
format
va_list
ap
int
ret
double
tm1
tm2
long
start_off
end_off
MAP_OR_FAIL
vfscanf
tm1
darshan_core_wtime
start_off
ftell
stream
ret
__real_vfscanf
stream
format
ap
end_off
ftell
stream
tm2
darshan_core_wtime
STDIO_LOCK
if
ret
0
STDIO_RECORD_READ
stream
end_off
start_off
tm1
tm2
STDIO_UNLOCK
return
ret
char
DARSHAN_DECL
fgets
char
s
int
size
FILE
stream
char
DARSHAN_DECL
fgets
char
s
int
size
FILE
stream
char
ret
char
ret
darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
View file @
9e6663d9
@@ -8,5 +8,7 @@
@@ -8,5 +8,7 @@
--wrap=fwrite
--wrap=fwrite
--wrap=fread
--wrap=fread
--wrap=fgetc
--wrap=fgetc
--wrap=fscanf
--wrap=vfscanf
--wrap=fgets
--wrap=fgets
--wrap=fseek
--wrap=fseek
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
