Commit 0d7fe693 authored by Shane Snyder's avatar Shane Snyder
Browse files
finish implementation of darshan logutils
parent 4f5d2339
...@@ -107,7 +107,7 @@ install:: all ...@@ -107,7 +107,7 @@ install:: all
install -d $(includedir) install -d $(includedir)
install -d $(pkgconfigdir) install -d $(pkgconfigdir)
install -m 755 darshan-analyzer $(bindir) install -m 755 darshan-analyzer $(bindir)
# install -m 755 darshan-convert $(bindir) install -m 755 darshan-convert $(bindir)
# install -m 755 darshan-diff $(bindir) # install -m 755 darshan-diff $(bindir)
install -m 755 darshan-parser $(bindir) install -m 755 darshan-parser $(bindir)
# install -m 755 $(srcdir)/darshan-summary-per-file.sh $(bindir) # install -m 755 $(srcdir)/darshan-summary-per-file.sh $(bindir)
...@@ -49,7 +49,7 @@ int darshan_log_get_hdf5_file(darshan_fd fd, void **file_rec, ...@@ -49,7 +49,7 @@ int darshan_log_get_hdf5_file(darshan_fd fd, void **file_rec,
return(-1); return(-1);
memset(file, 0, sizeof(*file)); memset(file, 0, sizeof(*file));
ret = darshan_log_get_moddat(fd, DARSHAN_HDF5_MOD, ret = darshan_log_getmod(fd, DARSHAN_HDF5_MOD,
(void *)file, sizeof(*file)); (void *)file, sizeof(*file));
if(ret == 1) if(ret == 1)
...@@ -21,7 +21,7 @@ ...@@ -21,7 +21,7 @@
static int darshan_log_seek(darshan_fd fd, off_t offset); static int darshan_log_seek(darshan_fd fd, off_t offset);
static int darshan_log_read(darshan_fd fd, void *buf, int len); static int darshan_log_read(darshan_fd fd, void *buf, int len);
//static int darshan_log_write(darshan_fd fd, void *buf, int len); static int darshan_log_write(darshan_fd fd, void *buf, int len);
/* TODO: can we make this s.t. we don't care about ordering (i.e., X macro it ) */ /* TODO: can we make this s.t. we don't care about ordering (i.e., X macro it ) */
struct darshan_mod_logutil_funcs *mod_logutils[DARSHAN_MAX_MODS] = struct darshan_mod_logutil_funcs *mod_logutils[DARSHAN_MAX_MODS] =
...@@ -94,9 +94,9 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header) ...@@ -94,9 +94,9 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
/* read header from log file */ /* read header from log file */
ret = darshan_log_read(fd, header, sizeof(*header)); ret = darshan_log_read(fd, header, sizeof(*header));
if(ret < sizeof(*header)) if(ret != sizeof(*header))
fprintf(stderr, "Error: invalid darshan log file (failed to read header).\n"); fprintf(stderr, "Error: failed to read darshan log file header.\n");
...@@ -140,6 +140,38 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header) ...@@ -140,6 +140,38 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
return(0); return(0);
/* darshan_log_putheader()
* write a darshan header to log file
* returns 0 on success, -1 on failure
int darshan_log_putheader(darshan_fd fd, struct darshan_header *header)
int ret;
ret = darshan_log_seek(fd, 0);
if(ret < 0)
fprintf(stderr, "Error: unable to seek in darshan log file.\n");
return(-1);
/* write header to file */
ret = darshan_log_write(fd, header, sizeof(*header));
fprintf(stderr, "Error: failed to write Darshan log file header.\n");
return(-1);
/* copy the mapping information to the file descriptor */
memcpy(&fd->rec_map, &header->rec_map, sizeof(struct darshan_log_map));
memcpy(&fd->mod_map, &header->mod_map, DARSHAN_MAX_MODS * sizeof(struct darshan_log_map));
return(0);
/* darshan_log_getjob() /* darshan_log_getjob()
* read job level metadata from the darshan log file * read job level metadata from the darshan log file
...@@ -159,9 +191,9 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job) ...@@ -159,9 +191,9 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
/* read the job data from the log file */ /* read the job data from the log file */
ret = darshan_log_read(fd, job, sizeof(*job)); ret = darshan_log_read(fd, job, sizeof(*job));
if(ret < sizeof(*job)) if(ret != sizeof(*job))
fprintf(stderr, "Error: invalid darshan log file (failed to read job data).\n"); fprintf(stderr, "Error: failed to read darshan log file job data.\n");
...@@ -178,6 +210,56 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job) ...@@ -178,6 +210,56 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
/* darshan_log_putjob()
* write job level metadat to darshan log file
int darshan_log_putjob(darshan_fd fd, struct darshan_job *job)
struct darshan_job job_copy;
int len;
int ret;
ret = darshan_log_seek(fd, sizeof(struct darshan_header));
if(ret < 0)
return(-1);
memset(&job_copy, 0, sizeof(*job));
memcpy(&job_copy, job, sizeof(*job));
/* check for newline in existing metadata, add if needed */
len = strlen(job_copy.metadata);
if(len > 0 && len < DARSHAN_JOB_METADATA_LEN)
if(job_copy.metadata[len-1] != '\n')
job_copy.metadata[len] = '\n';
job_copy.metadata[len+1] = '\0';
/* write job data to file */
ret = darshan_log_write(fd, job, sizeof(*job));
fprintf(stderr, "Error: failed to write darshan log file job data.\n");
return(-1);
return(0);
/* darshan_log_getexe()
* reads the application exe name from darshan log file
int darshan_log_getexe(darshan_fd fd, char *buf) int darshan_log_getexe(darshan_fd fd, char *buf)
int tmp_off = sizeof(struct darshan_header) + sizeof(struct darshan_job); int tmp_off = sizeof(struct darshan_header) + sizeof(struct darshan_job);
...@@ -193,9 +275,9 @@ int darshan_log_getexe(darshan_fd fd, char *buf) ...@@ -193,9 +275,9 @@ int darshan_log_getexe(darshan_fd fd, char *buf)
/* read the trailing exe data from the darshan log */ /* read the trailing exe data from the darshan log */
ret = darshan_log_read(fd, buf, DARSHAN_EXE_LEN+1); ret = darshan_log_read(fd, buf, DARSHAN_EXE_LEN+1);
if(ret < DARSHAN_EXE_LEN+1) if(ret != DARSHAN_EXE_LEN+1)
fprintf(stderr, "Error: invalid darshan log file (failed to read exe string).\n"); fprintf(stderr, "Error: failed to read exe string from darshan log file.\n");
...@@ -207,11 +289,44 @@ int darshan_log_getexe(darshan_fd fd, char *buf) ...@@ -207,11 +289,44 @@ int darshan_log_getexe(darshan_fd fd, char *buf)
return (0); return (0);
/* darshan_log_putexe()
* wrties the application exe name to darshan log file
int darshan_log_putexe(darshan_fd fd, char *buf)
int len;
int ret;
ret = darshan_log_seek(fd, tmp_off);
if(ret < 0)
return(-1);
len = strlen(buf);
ret = darshan_log_write(fd, buf, len);
if(ret != len)
fprintf(stderr, "Error: failed to write exe string to darshan log file.\n");
return(-1);
return(0);
/* darshan_log_getmounts() /* darshan_log_getmounts()
* retrieves mount table information from the log. Note that mnt_pts and * retrieves mount table information from the log. Note that mnt_pts and
* fs_types are arrays that will be allocated by the function and must be * fs_types are arrays that will be allocated by the function and must be
* freed by the caller. count will indicate the size of the arrays * freed by the caller. count will indicate the size of the arrays
int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts, int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
char*** fs_types, int* count) char*** fs_types, int* count)
...@@ -231,9 +346,9 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts, ...@@ -231,9 +346,9 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
/* read the trailing mount data from the darshan log */ /* read the trailing mount data from the darshan log */
fprintf(stderr, "Error: invalid darshan log file (failed to read mount info).\n"); fprintf(stderr, "Error: failed to read mount info from darshan log file.\n");
...@@ -273,7 +388,7 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts, ...@@ -273,7 +388,7 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
(*mnt_pts)[array_index]); (*mnt_pts)[array_index]);
if(ret != 2) if(ret != 2)
fprintf(stderr, "Error: poorly formatted mount table in log file.\n"); fprintf(stderr, "Error: poorly formatted mount table in darshan log file.\n");
pos--; pos--;
...@@ -284,6 +399,44 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts, ...@@ -284,6 +399,44 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
/* darshan_log_putmounts()
* writes mount information to the darshan log file
* NOTE: this function call should follow immediately after the call
* to darshan_log_putexe(), as it assumes the darshan log file pointer
* is pointing to the offset immediately following the exe string
int darshan_log_putmounts(darshan_fd fd, char** mnt_pts, char** fs_types, int count)
int i;
char line[1024];
int ret;
/* write each mount entry to file */
for(i=count-1; i>=0; i--)
sprintf(line, "\n%s\t%s", fs_types[i], mnt_pts[i]);
ret = darshan_log_write(fd, line, strlen(line));
if (ret != strlen(line))
fprintf(stderr, "Error: failed to write darshan log mount entry.\n");
return(-1);
/* seek ahead to end of exe region, will be zero filled */
ret = darshan_log_seek(fd, DARSHAN_JOB_RECORD_SIZE);
if (ret < 0)
fprintf(stderr, "Error: unable to seek forward in darshan log file.\n");
return(-1);
return(0);
/* darshan_log_gethash() /* darshan_log_gethash()
* read the hash of records from the darshan log file * read the hash of records from the darshan log file
...@@ -301,10 +454,6 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash) ...@@ -301,10 +454,6 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
struct darshan_record_ref *ref; struct darshan_record_ref *ref;
int ret; int ret;
hash_buf = malloc(hash_buf_sz);
if(!hash_buf)
return(-1);
ret = darshan_log_seek(fd, fd->rec_map.off); ret = darshan_log_seek(fd, fd->rec_map.off);
if(ret < 0) if(ret < 0)
...@@ -312,11 +461,15 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash) ...@@ -312,11 +461,15 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
if(!hash_buf)
return(-1);
/* read the record hash from the log file */ /* read the record hash from the log file */
ret = darshan_log_read(fd, hash_buf, fd->rec_map.len); ret = darshan_log_read(fd, hash_buf, fd->rec_map.len);
if(ret < fd->rec_map.len) if(ret != fd->rec_map.len)
fprintf(stderr, "Error: invalid darshan log file (failed to read record hash).\n"); fprintf(stderr, "Error: failed to read record hash from darshan log file.\n");
...@@ -369,8 +522,105 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash) ...@@ -369,8 +522,105 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
int darshan_log_get_moddat(darshan_fd fd, darshan_module_id mod_id, /* darshan_log_puthash()
void *moddat_buf, int moddat_buf_sz) *
* writes the hash table of records to the darshan log file
int darshan_log_puthash(darshan_fd fd, struct darshan_record_ref *hash)
size_t hash_buf_sz;
char *hash_buf;
char *hash_buf_off;
struct darshan_record_ref *ref, *tmp;
uint32_t name_len;
size_t record_sz;
int ret;
if(ret < 0)
return(-1);
/* allocate a buffer to store 2 MiB worth of record data */
/* NOTE: this buffer may be reallocated if estimate is too small */
hash_buf_sz = 2 * 1024 * 1024;
if(!hash_buf)
return(-1);
/* serialize the record hash into a buffer for writing */
hash_buf_off = hash_buf;
HASH_ITER(hlink, hash, ref, tmp)
name_len = strlen(ref->rec.name);
record_sz = sizeof(darshan_record_id) + sizeof(uint32_t) + name_len;
/* make sure there is room in the buffer for this record */
if((hash_buf_off + record_sz) > (hash_buf + hash_buf_sz))
char *tmp_buf;
size_t old_buf_sz;
/* if no room, reallocate the hash buffer at twice the current size */
old_buf_sz = hash_buf_off - hash_buf;
hash_buf_sz *= 2;
tmp_buf = malloc(hash_buf_sz);
if(!tmp_buf)
free(hash_buf);
return(-1);
memcpy(tmp_buf, hash_buf, old_buf_sz);
free(hash_buf);
hash_buf = tmp_buf;
hash_buf_off = hash_buf + old_buf_sz;
/* now serialize the record into the hash buffer.
* NOTE: darshan record hash serialization method:
* ... darshan_record_id | (uint32_t) path_len | path ...
*((darshan_record_id *)hash_buf_off) = ref->rec.id;
hash_buf_off += sizeof(darshan_record_id);
*((uint32_t *)hash_buf_off) = name_len;
hash_buf_off += sizeof(uint32_t);
memcpy(hash_buf_off, ref->rec.name, name_len);
hash_buf_off += name_len;
/* collectively write out the record hash to the darshan log */
hash_buf_sz = hash_buf_off - hash_buf;
/* write the record hash to file */
ret = darshan_log_write(fd, hash_buf, hash_buf_sz);
if(ret != hash_buf_sz)
fprintf(stderr, "Error: failed to write record hash to darshan log file.\n");
return(-1);
free(hash_buf);
return(0);
/* darshan_log_getmod()
* reads a chunk of data for a corresponding darshan instrumentation module
* NOTE: mod_buf_sz is the uncompressed size of data we wish to read for the given
* module. chunks of data can be read sequentially for a given module by
* repeatedly calling this function with the desired chunk sizes.
* returns 1 on successful read of data, 0 on end of module region, -1 on failure
int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
void *mod_buf, int mod_buf_sz)
int mod_buf_end = fd->mod_map[mod_id].off + fd->mod_map[mod_id].len; int mod_buf_end = fd->mod_map[mod_id].off + fd->mod_map[mod_id].len;
int ret; int ret;
...@@ -393,12 +643,19 @@ int darshan_log_get_moddat(darshan_fd fd, darshan_module_id mod_id, ...@@ -393,12 +643,19 @@ int darshan_log_get_moddat(darshan_fd fd, darshan_module_id mod_id,
/* read the record hash from the log file */ /* if the requested amount of data violates mapping info, error out */
ret = darshan_log_read(fd, moddat_buf, moddat_buf_sz); if(mod_buf_sz > (mod_buf_end - fd->pos))
if(ret != moddat_buf_sz) {
fprintf(stderr, "Error: module data read violates stored mapping information.\n");
return(-1);
/* read the module chunk from the log file */
ret = darshan_log_read(fd, mod_buf, mod_buf_sz);
if(ret != mod_buf_sz)
fprintf(stderr, fprintf(stderr,
"Error: invalid darshan log file (failed to read module %s data).\n", "Error: failed to read module %s data from darshan log file.\n",
darshan_module_names[mod_id]); darshan_module_names[mod_id]);
...@@ -406,6 +663,59 @@ int darshan_log_get_moddat(darshan_fd fd, darshan_module_id mod_id, ...@@ -406,6 +663,59 @@ int darshan_log_get_moddat(darshan_fd fd, darshan_module_id mod_id,
return(1); return(1);
/* darshan_log_putmod()
* write a chunk of module data to the darshan log file
int darshan_log_putmod(darshan_fd fd, darshan_module_id mod_id,
int ret;
if(!fd->mod_map[mod_id].len)
fprintf(stderr, "Error: attempting to write data for empty module.\n");
return(-1);
/* only seek to start of module data if current log file position
* is not within the given mod_id's range. This allows one to
* repeatedly call this function and put chunks of a module's
* data piecemeal.
if((fd->pos < fd->mod_map[mod_id].off) || (fd->pos > mod_buf_end))
ret = darshan_log_seek(fd, fd->mod_map[mod_id].off);
if(ret < 0)
return(-1);
/* if the given data violates stored mapping info, error out */
fprintf(stderr, "Error: module data write violates stored mapping information.\n");
return(-1);
/* write the module chunk to the log file */
ret = darshan_log_write(fd, mod_buf, mod_buf_sz);
fprintf(stderr,
"Error: failed to write module %s data to darshan log file.\n",
return(-1);
return(0);
/* darshan_log_close() /* darshan_log_close()
* close an open darshan file descriptor * close an open darshan file descriptor
...@@ -449,16 +759,15 @@ static int darshan_log_seek(darshan_fd fd, off_t offset) ...@@ -449,16 +759,15 @@ static int darshan_log_seek(darshan_fd fd, off_t offset)
#if 0 /* return amount read on success, 0 on EOF, -1 on failure.
/* return amount written on success, -1 on failure.
static int darshan_log_write(darshan_fd fd, void* buf, int len) static int darshan_log_read(darshan_fd fd, void* buf, int len)
int ret; int ret;
if(fd->gzf) if(fd->gzf)
ret = gzwrite(fd->gzf, buf, len); ret = gzread(fd->gzf, buf, len);
if(ret > 0) if(ret > 0)
fd->pos += ret; fd->pos += ret;
return(ret); return(ret);
...@@ -466,17 +775,16 @@ static int darshan_log_write(darshan_fd fd, void* buf, int len) ...@@ -466,17 +775,16 @@ static int darshan_log_write(darshan_fd fd, void* buf, int len)
#endif
/* return amount read on success, 0 on EOF, -1 on failure. /* return amount written on success, -1 on failure.
static int darshan_log_read(darshan_fd fd, void* buf, int len) static int darshan_log_write(darshan_fd fd, void* buf, int len)
int ret; int ret;
if(fd->gzf)
