Commit 0459f8ff authored by Shane Snyder's avatar Shane Snyder
Browse files
add a partial flag to darshan's header
this indicates whether the log file is complete or only partially
written
parent 928fdff4
...@@ -99,6 +99,7 @@ struct darshan_header ...@@ -99,6 +99,7 @@ struct darshan_header
char version_string[8]; char version_string[8];
int64_t magic_nr; int64_t magic_nr;
unsigned char comp_type; unsigned char comp_type;
unsigned char partial_flag;
struct darshan_log_map rec_map; struct darshan_log_map rec_map;
struct darshan_log_map mod_map[DARSHAN_MAX_MODS]; struct darshan_log_map mod_map[DARSHAN_MAX_MODS];
...@@ -1566,9 +1566,14 @@ void darshan_core_register_record( ...@@ -1566,9 +1566,14 @@ void darshan_core_register_record(
/* record not found -- add it to the hash if we aren't already tracking the /* record not found -- add it to the hash if we aren't already tracking the
* maximum number of records * maximum number of records
if(darshan_core->rec_count >= DARSHAN_CORE_MAX_RECORDS) if(darshan_core->rec_count >= DARSHAN_CORE_MAX_RECORDS)
/* if we are already tracking the max records, set a flag to indicate
* that this log file has partial results
darshan_core->log_header.partial_flag = 1;
DARSHAN_CORE_UNLOCK(); DARSHAN_CORE_UNLOCK();
return; return;
Markdown is supported
0% or .
Please register or to comment
