Commit a86dc8ba authored by Philip Carns's avatar Philip Carns
report bw
parent 122d70cf
...@@ -33,7 +33,6 @@ struct options ...@@ -33,7 +33,6 @@ struct options
unsigned long total_mem_size; unsigned long total_mem_size;
int duration_seconds; int duration_seconds;
int concurrency; int concurrency;
int threads;
unsigned int mercury_timeout_client; unsigned int mercury_timeout_client;
unsigned int mercury_timeout_server; unsigned int mercury_timeout_server;
char* diag_file_name; char* diag_file_name;
...@@ -252,7 +251,7 @@ static int parse_args(int argc, char **argv, struct options *opts) ...@@ -252,7 +251,7 @@ static int parse_args(int argc, char **argv, struct options *opts)
opts->mercury_timeout_client = UINT_MAX; opts->mercury_timeout_client = UINT_MAX;
opts->mercury_timeout_server = UINT_MAX; opts->mercury_timeout_server = UINT_MAX;
while((opt = getopt(argc, argv, "n:x:c:T:d:t:p:m:")) != -1) while((opt = getopt(argc, argv, "n:x:c:d:t:p:m:")) != -1)
switch(opt) switch(opt)
...@@ -287,11 +286,6 @@ static int parse_args(int argc, char **argv, struct options *opts) ...@@ -287,11 +286,6 @@ static int parse_args(int argc, char **argv, struct options *opts)
if(ret != 1) if(ret != 1)
return(-1); return(-1);
break; break;
case 'T':
ret = sscanf(optarg, "%d", &opts->threads);
if(ret != 1)
return(-1);
break;
case 't': case 't':
ret = sscanf(optarg, "%u,%u", &opts->mercury_timeout_client, &opts->mercury_timeout_server); ret = sscanf(optarg, "%u,%u", &opts->mercury_timeout_client, &opts->mercury_timeout_server);
if(ret != 2) if(ret != 2)
...@@ -329,7 +323,6 @@ static void usage(void) ...@@ -329,7 +323,6 @@ static void usage(void)
"\t-n <na> - na transport\n" "\t-n <na> - na transport\n"
"\t-p <bake pool> - existing pool created with bake-mkpool\n" "\t-p <bake pool> - existing pool created with bake-mkpool\n"
"\t[-c concurrency] - number of concurrent operations to issue with ULTs\n" "\t[-c concurrency] - number of concurrent operations to issue with ULTs\n"
"\t[-T <os threads] - number of dedicated operating system threads to run ULTs on\n"
"\t[-d filename] - enable diagnostics output\n" "\t[-d filename] - enable diagnostics output\n"
"\t[-t client_progress_timeout,server_progress_timeout] # use \"-t 0,0\" to busy spin\n" "\t[-t client_progress_timeout,server_progress_timeout] # use \"-t 0,0\" to busy spin\n"
"\t\texample: mpiexec -n 2 ./bake-p2p-bw -x 4096 -n verbs://\n" "\t\texample: mpiexec -n 2 ./bake-p2p-bw -x 4096 -n verbs://\n"
...@@ -362,6 +355,7 @@ static int run_benchmark(struct options *opts, bake_provider_handle_t bph, ...@@ -362,6 +355,7 @@ static int run_benchmark(struct options *opts, bake_provider_handle_t bph,
struct bench_worker_arg *arg_array; struct bench_worker_arg *arg_array;
ABT_mutex cur_off_mutex; ABT_mutex cur_off_mutex;
unsigned long cur_off = 0; unsigned long cur_off = 0;
double start_tm, end_tm;
tid_array = malloc(g_opts.concurrency * sizeof(*tid_array)); tid_array = malloc(g_opts.concurrency * sizeof(*tid_array));
assert(tid_array); assert(tid_array);
...@@ -376,6 +370,7 @@ static int run_benchmark(struct options *opts, bake_provider_handle_t bph, ...@@ -376,6 +370,7 @@ static int run_benchmark(struct options *opts, bake_provider_handle_t bph,
ret = ABT_xstream_get_main_pools(xstream, 1, &pool); ret = ABT_xstream_get_main_pools(xstream, 1, &pool);
assert(ret == 0); assert(ret == 0);
start_tm = ABT_get_wtime();
for(i=0; i<g_opts.concurrency; i++) for(i=0; i<g_opts.concurrency; i++)
arg_array[i].bph = bph; arg_array[i].bph = bph;
...@@ -392,6 +387,15 @@ static int run_benchmark(struct options *opts, bake_provider_handle_t bph, ...@@ -392,6 +387,15 @@ static int run_benchmark(struct options *opts, bake_provider_handle_t bph,
ABT_thread_join(tid_array[i]); ABT_thread_join(tid_array[i]);
ABT_thread_free(&tid_array[i]); ABT_thread_free(&tid_array[i]);
end_tm = ABT_get_wtime();
printf("<op>\t<concurrency>\t<xfer_size>\t<total_bytes>\t<seconds>\t<MiB/s>\n");
printf("create_write_persist\t%d\t%lu\t%lu\t%f\t%f\n",
g_opts.concurrency,
g_opts.xfer_size,
g_opts.total_mem_size,
(end_tm-start_tm),
((double)g_opts.total_mem_size/(end_tm-start_tm))/(1024.0*1024.0));
free(tid_array); free(tid_array);
ABT_mutex_free(&cur_off_mutex); ABT_mutex_free(&cur_off_mutex);
Markdown is supported
0% or
Please register or to comment
