Commit 390168c1 authored by Philip Carns's avatar Philip Carns
start bake provider
parent dc756dfe
...@@ -24,6 +24,7 @@ ...@@ -24,6 +24,7 @@
#include <abt.h> #include <abt.h>
#include <ssg.h> #include <ssg.h>
#include <ssg-mpi.h> #include <ssg-mpi.h>
#include <bake-server.h>
struct options struct options
...@@ -31,11 +32,11 @@ struct options ...@@ -31,11 +32,11 @@ struct options
int duration_seconds; int duration_seconds;
int concurrency; int concurrency;
int threads; int threads;
char* mmap_filename;
unsigned int mercury_timeout_client; unsigned int mercury_timeout_client;
unsigned int mercury_timeout_server; unsigned int mercury_timeout_server;
char* diag_file_name; char* diag_file_name;
char* na_transport; char* na_transport;
char* bake_pool;
/* defealt to 512 MiB total xfer unless specified otherwise */ /* defealt to 512 MiB total xfer unless specified otherwise */
...@@ -67,6 +68,7 @@ int main(int argc, char **argv) ...@@ -67,6 +68,7 @@ int main(int argc, char **argv)
MPI_Init(&argc, &argv); MPI_Init(&argc, &argv);
/* TODO: relax this, maybe 1 server N clients? */
/* 2 processes only */ /* 2 processes only */
MPI_Comm_size(MPI_COMM_WORLD, &nranks); MPI_Comm_size(MPI_COMM_WORLD, &nranks);
if(nranks != 2) if(nranks != 2)
...@@ -137,7 +139,20 @@ int main(int argc, char **argv) ...@@ -137,7 +139,20 @@ int main(int argc, char **argv)
if(self == 1) if(self == 1)
bake_provider_t provider;
bake_target_id_t tid;
/* server side */ /* server side */
ret = bake_provider_register(mid, 1, BAKE_ABT_POOL_DEFAULT, &provider);
assert(ret == 0);
ret = bake_provider_add_storage_target(provider, g_opts.bake_pool, &tid);
if(ret != 0)
fprintf(stderr, "Error: failed to add bake pool %s\n", g_opts.bake_pool);
abort();
MPI_Barrier(MPI_COMM_WORLD); MPI_Barrier(MPI_COMM_WORLD);
...@@ -179,10 +194,18 @@ static int parse_args(int argc, char **argv, struct options *opts) ...@@ -179,10 +194,18 @@ static int parse_args(int argc, char **argv, struct options *opts)
opts->mercury_timeout_client = UINT_MAX; opts->mercury_timeout_client = UINT_MAX;
opts->mercury_timeout_server = UINT_MAX; opts->mercury_timeout_server = UINT_MAX;
while((opt = getopt(argc, argv, "n:x:c:T:d:t:")) != -1) while((opt = getopt(argc, argv, "n:x:c:T:d:t:p:")) != -1)
switch(opt) switch(opt)
case 'p':
opts->bake_pool = strdup(optarg);
if(!opts->bake_pool)
perror("strdup");
return(-1);
break;
case 'd': case 'd':
opts->diag_file_name = strdup(optarg); opts->diag_file_name = strdup(optarg);
if(!opts->diag_file_name) if(!opts->diag_file_name)
...@@ -224,7 +247,8 @@ static int parse_args(int argc, char **argv, struct options *opts) ...@@ -224,7 +247,8 @@ static int parse_args(int argc, char **argv, struct options *opts)
if(opts->xfer_size < 1 || opts->concurrency < 1 || !opts->na_transport) if(opts->xfer_size < 1 || opts->concurrency < 1 || !opts->na_transport
|| !opts->bake_pool)
return(-1); return(-1);
...@@ -239,6 +263,7 @@ static void usage(void) ...@@ -239,6 +263,7 @@ static void usage(void)
"bake-p2p-bw -x <xfer_size> -n <na>\n" "bake-p2p-bw -x <xfer_size> -n <na>\n"
"\t-x <xfer_size> - size of each bulk tranfer in bytes\n" "\t-x <xfer_size> - size of each bulk tranfer in bytes\n"
"\t-n <na> - na transport\n" "\t-n <na> - na transport\n"
"\t-p <bake pool> - existing pool created with bake-mkpool\n"
"\t[-c concurrency] - number of concurrent operations to issue with ULTs\n" "\t[-c concurrency] - number of concurrent operations to issue with ULTs\n"
"\t[-T <os threads] - number of dedicated operating system threads to run ULTs on\n" "\t[-T <os threads] - number of dedicated operating system threads to run ULTs on\n"
"\t[-d filename] - enable diagnostics output\n" "\t[-d filename] - enable diagnostics output\n"
Markdown is supported
0% or
Please register or to comment
