Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
S
sds-tests
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
sds
sds-tests
Commits
390168c1
Commit
390168c1
authored
Jan 03, 2019
by
Philip Carns
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
start bake provider
parent
dc756dfe
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
28 additions
and
3 deletions
+28
-3
perf-regression/bake-p2p-bw.c
+28
-3
No files found.
View file @
390168c1
@@ -24,6 +24,7 @@
@@ -24,6 +24,7 @@
#include <abt.h>
#include <abt.h>
#include <ssg.h>
#include <ssg.h>
#include <ssg-mpi.h>
#include <bake-server.h>
struct
options
struct
options
@@ -31,11 +32,11 @@ struct options
int
duration_seconds
int
duration_seconds
int
concurrency
int
concurrency
int
threads
int
threads
char
mmap_filename
unsigned
int
mercury_timeout_client
unsigned
int
unsigned
int
mercury_timeout_server
unsigned
int
char
diag_file_name
char
diag_file_name
char
na_transport
char
na_transport
char
bake_pool
/* defealt to 512 MiB total xfer unless specified otherwise */
@@ -67,6 +68,7 @@ int main(int argc, char **argv)
MPI_Init
argc
argv
MPI_Init
argc
argv
/* TODO: relax this, maybe 1 server N clients? */
/* 2 processes only */
MPI_Comm_size
MPI_COMM_WORLD
nranks
MPI_Comm_size
MPI_COMM_WORLD
nranks
if
nranks
2
if
nranks
2
@@ -137,7 +139,20 @@ int main(int argc, char **argv)
if
self
1
if
self
1
bake_provider_t
provider
bake_target_id_t
tid
/* server side */
/* server side */
ret
bake_provider_register
mid
1
BAKE_ABT_POOL_DEFAULT
provider
assert
ret
0
ret
bake_provider_add_storage_target
provider
g_opts
bake_pool
tid
if
ret
0
fprintf
stderr
"Error: failed to add bake pool %s
\n
g_opts
bake_pool
abort
MPI_Barrier
MPI_COMM_WORLD
MPI_Barrier
MPI_COMM_WORLD
@@ -179,10 +194,18 @@ static int parse_args(int argc, char **argv, struct options *opts)
opts
UINT_MAX
opts
UINT_MAX
opts
UINT_MAX
opts
UINT_MAX
while
opt
getopt
argc
argv
"n:x:c:T:d:t:"
1
while
opt
getopt
argc
argv
"n:x:c:T:d:t:
p:
1
switch
opt
switch
opt
case
'p'
opts
bake_pool
strdup
optarg
if
opts
bake_pool
perror
"strdup"
return
1
break
case
'd'
case
'd'
opts
diag_file_name
strdup
optarg
opts
diag_file_name
strdup
optarg
if
opts
diag_file_name
if
opts
diag_file_name
@@ -224,7 +247,8 @@ static int parse_args(int argc, char **argv, struct options *opts)
if
opts
xfer_size
1
opts
concurrency
1
opts
na_transport
if
opts
xfer_size
1
opts
concurrency
1
opts
na_transport
opts
bake_pool
return
1
return
1
@@ -239,6 +263,7 @@ static void usage(void)
"bake-p2p-bw -x <xfer_size> -n <na>
\n
\n
\t
-x <xfer_size> - size of each bulk tranfer in bytes
\n
\t
\n
\t
-n <na> - na transport
\n
\t
\n
\t
-p <bake pool> - existing pool created with bake-mkpool
\n
\t
[-c concurrency] - number of concurrent operations to issue with ULTs
\n
\t
\n
\t
[-T <os threads] - number of dedicated operating system threads to run ULTs on
\n
\t
\n
\t
[-d filename] - enable diagnostics output
\n
\t
\n
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
