Commit 38ad5bc8 authored by Rob Latham's avatar Rob Latham
Browse files
Try not to leave any dangling protection domains
parent 57a8732f
...@@ -14,7 +14,7 @@ spack load -r ior@develop +mobject ...@@ -14,7 +14,7 @@ spack load -r ior@develop +mobject
module list module list
MOBJECT_PDOMAIN="mobject-test" MOBJECT_PDOMAIN="sds-nightly"
apstat -P | grep $MOBJECT_PDOMAIN || apmgr pdomain -c -u $MOBJECT_PDOMAIN apstat -P | grep $MOBJECT_PDOMAIN || apmgr pdomain -c -u $MOBJECT_PDOMAIN
...@@ -24,14 +24,17 @@ export MPICH_GNI_NDREG_ENTRIES=1024 ...@@ -24,14 +24,17 @@ export MPICH_GNI_NDREG_ENTRIES=1024
echo " ==== running server " echo " ==== running server "
export MOBJECT_CLUSTER_FILE=mobject-cluster.gid export MOBJECT_CLUSTER_FILE=mobject-cluster.gid
rm ${MOBJECT_CLUSTER_FILE} rm -f ${MOBJECT_CLUSTER_FILE}
aprun -p ${MOBJECT_PDOMAIN} -n 2 -N 1 mobject-server-daemon ofi+gni:// $MOBJECT_CLUSTER_FILE & aprun -p ${MOBJECT_PDOMAIN} -n 1 -N 1 mobject-server-daemon ofi+gni:// $MOBJECT_CLUSTER_FILE &
# give the mobject-server nodes a chance to set up # give the mobject-server nodes a chance to set up
sleep 5 sleep 5
xxd ${MOBJECT_CLUSTER_FILE} xxd ${MOBJECT_CLUSTER_FILE}
echo " ==== running benchmark " echo " ==== running benchmark "
aprun -p ${MOCHI_PDOMAIN} -n 1 -N 1 ior -g -a RADOS -t 64k -b 128k --rados.user=foo --rados.pool=bar --rados.conf $MOBJECT_CLUSTER_FILE aprun -p ${MOBJECT_PDOMAIN} -n 1 -N 1 ior -g -a RADOS -t 64k -b 128k --rados.user=foo --rados.pool=bar --rados.conf $MOBJECT_CLUSTER_FILE
kill %1 aprun -p ${MOBJECT_PDOMAIN} -n 1 -N 1 mobject-server-ctl ${MOBJECT_CLUSTER_FILE} stat
aprun -p ${MOBJECT_PDOMAIN} -n 1 -N 1 mobject-server-ctl ${MOBJECT_CLUSTER_FILE} shutdown
# give aprun a chance to tear down protection domain
sleep 5
apmgr pdomain -r -u $MOBJECT_PDOMAIN apmgr pdomain -r -u $MOBJECT_PDOMAIN
...@@ -23,7 +23,7 @@ export LD_LIBRARY_PATH=${LIBRARY_PATH} ...@@ -23,7 +23,7 @@ export LD_LIBRARY_PATH=${LIBRARY_PATH}
export MPICH_GNI_NDREG_ENTRIES=1024 export MPICH_GNI_NDREG_ENTRIES=1024
SSG_PDOMAIN="ssg-test" SSG_PDOMAIN="sds-nightly"
apmgr pdomain -c -u $SSG_PDOMAIN apmgr pdomain -c -u $SSG_PDOMAIN
SSG_STATEFILE=ssg-state.cfg SSG_STATEFILE=ssg-state.cfg
...@@ -40,5 +40,7 @@ done ...@@ -40,5 +40,7 @@ done
xxd $SSG_STATEFILE xxd $SSG_STATEFILE
aprun -cc none -p ${SSG_PDOMAIN} -n 1 -N 1 ./ssg-test-separate-group-attach ofi+gni:// ${SSG_STATEFILE} aprun -cc none -p ${SSG_PDOMAIN} -n 1 -N 1 ./ssg-test-separate-group-attach ofi+gni:// ${SSG_STATEFILE}
# give creator aprun time to clean up the protection domain
sleep 5
apmgr pdomain -r ${SSG_PDOMAIN} apmgr pdomain -r ${SSG_PDOMAIN}
Markdown is supported
0% or .
Please register or to comment
