Commit daac59c8 authored by Philip Carns's avatar Philip Carns
replace module list with spack find --loaded
parent 1ffb1937
...@@ -102,7 +102,7 @@ The following are the most important commands to know: ...@@ -102,7 +102,7 @@ The following are the most important commands to know:
install it (including dependencies and version numbers) install it (including dependencies and version numbers)
* `spack install <package>` to install a package * `spack install <package>` to install a package
* `spack load -r <package>` to load the package into your environment * `spack load -r <package>` to load the package into your environment
* `module list` to observe what modules you have loaded * `spack find --loaded` to observe what modules you have loaded
## Setting up your profile to retain Spack and compiler settings ## Setting up your profile to retain Spack and compiler settings
...@@ -138,7 +138,7 @@ spack load -r margo ...@@ -138,7 +138,7 @@ spack load -r margo
... and inspect to confirm that they are present in your environment with: ... and inspect to confirm that they are present in your environment with:
module list spack find --loaded
## Compiling an example Mochi code ## Compiling an example Mochi code
Markdown is supported
0% or
Please register or to comment
