Commit fc65e461 authored by Philip Carns's avatar Philip Carns
Browse files
fill out remainder of README
parent 336821fb
...@@ -73,9 +73,7 @@ default: ...@@ -73,9 +73,7 @@ default:
You can see in this case that it only found `gcc 4.8.5`, which will work, You can see in this case that it only found `gcc 4.8.5`, which will work,
but is quite old. There are newer compilers available in the JLSE but is quite old. There are newer compilers available in the JLSE
environment that you can use in slack by putting them in your path and environment that you can use in slack by putting them in your path and
re-running spack compiler find (you will not need to modify your path when re-running spack compiler find:
you log in in the future; spack will store the location of the compiler in
it's persistent configuration):
[carns@jlselogin2 bootcamp]$ export PATH="/soft/compilers/gcc/8.2.0/linux-rhel7-x86_64/bin/:$PATH" [carns@jlselogin2 bootcamp]$ export PATH="/soft/compilers/gcc/8.2.0/linux-rhel7-x86_64/bin/:$PATH"
...@@ -141,6 +139,19 @@ The following are the most important commands to know: ...@@ -141,6 +139,19 @@ The following are the most important commands to know:
* `spack load -r <package>` to load the package into your environment * `spack load -r <package>` to load the package into your environment
* `module list` to observe what modules you have loaded * `module list` to observe what modules you have loaded
## Setting up your profile to retain Spack and compiler settings
There are two critical commands that you will want to either run every time
you log into a JLSE node, or else add to your ~/.bashrc file so that they
are performed automatically. We recommend the latter to save time:
cat ~/bootcamp/mochi-boot-camp/sessions/s2-hands-on/bashrc.mochi.jlse >> ~/.bashrc
Now when you log into JLSE moving forward you will have the correct compiler
and Spack command line tools available in your environment.
## Installing your first Mochi components ## Installing your first Mochi components
Run the following to download, compile, and install Margo: Run the following to download, compile, and install Margo:
...@@ -150,18 +161,70 @@ spack install margo ...@@ -150,18 +161,70 @@ spack install margo
This will take a few minutes and will install all of the necessary This will take a few minutes and will install all of the necessary
dependencies, including Mercury and Argobots. dependencies, including Mercury and Argobots. You can now load these
packages by running:
## Running a hands on example ```
spack load -r margo
... and inspect to confirm that they are present in your environment with:
module list
## TODO NOTES (TEMPORARY) ## Compiling an example Mochi code
cd ~/bootcamp/mochi-boot-camp/sessions/s2-hands-on/hello-world
make
The above example will compile a simple client and server program, linked
against margo. If you inspect the Makfile you will see pkg-config commands
that are used to find the correct CFLAGS and LDFLAGS for the build.
TODO: Phil handle JLSE setup/documentation ## running an interactive job on the JLSE compute nodes
TODO: make content here first with step by step, details, packages.yaml, The following command will allocate a single JLSE node for your use for 8
etc. hours and open up an interactive terminal on that node.
qsub qsub -I -n 1 -t 480 -q it
Once the terminal is open, you can open additional terminals to that node
with ssh. For example:
ssh it03
Note that you only have ssh access to nodes that you currently have
allocated, and your allocation will end once time expires or you log out of
the original interactive terminal that was created with the qsub command.
## Running an example Mochi code
cd /home/carns/bootcamp/mochi-boot-camp/sessions/s2-hands-on/hello-world
# in one terminal:
./server
Server running at address na+sm://156045/0
# in the other terminal, run client with argument matching the address
# shown above
./client na+sm://156045/0
TODO: is this too long (especially with all of the Spack stuff?) Could make
it shorter by bundling some of this into scripts, but then attendees won't
see the inner workings of the environment. Not sure about the tradeoff
here.
TODO: then make 5 minute presentation that summarizes and kicks off the TODO: then make 5 minute presentation that summarizes and kicks off the
session so people have the big picture of what they are setting up session so people have the big picture of what they are setting up
...@@ -170,9 +233,5 @@ TODO: have a few slides (not detailed) how to adapt this stuff for your home ...@@ -170,9 +233,5 @@ TODO: have a few slides (not detailed) how to adapt this stuff for your home
system. Ask people not to start there, do JLSE first. Exercise for the system. Ask people not to start there, do JLSE first. Exercise for the
reader to get their laptop or home cluster set up. reader to get their laptop or home cluster set up.
TODO: initial example is a "hello world" rpc, something attendees can run
without having to write code. Bare minimum expectation to have executed
this by end of session.
TODO: second example will be an exercise: copy the rpc, rename it, and TODO: second example will be an exercise: copy the rpc, rename it, and
modify it to do something else (increment an integer, for example) modify it to do something else (increment an integer, for example)
Markdown is supported
0% or .
Please register or to comment
