Commit d9bf97ab authored by Philip Carns's avatar Philip Carns
Browse files
jlse -> summit
parent 723b8f08
...@@ -61,8 +61,8 @@ that can be added to spack with the `spack repo add` command: ...@@ -61,8 +61,8 @@ that can be added to spack with the `spack repo add` command:
[robl@login1]~% cd ~/bootcamp [robl@login1]~% cd ~/bootcamp
[robl@login1]~/bootcamp% git clone https://xgitlab.cels.anl.gov/sds/sds-repo.git [robl@login1]~/bootcamp% git clone https://xgitlab.cels.anl.gov/sds/sds-repo.git
robl@login1]~/bootcamp/sds-repo% spack repo add sds-repo [robl@login1]~/bootcamp% spack repo add sds-repo
[carns@jlselogin2 bootcamp]$ [robl@login1]~/bootcamp%
==> Added repo with namespace 'sds'. ==> Added repo with namespace 'sds'.
## Customizing Spack for ORNL/Summit environment ## Customizing Spack for ORNL/Summit environment
...@@ -73,8 +73,9 @@ is time consuming. At this point we will install a `packages.yaml` file ...@@ -73,8 +73,9 @@ is time consuming. At this point we will install a `packages.yaml` file
that customizes Spack by informing it of system packages that it should that customizes Spack by informing it of system packages that it should
reuse, and specifies a subset of network transports to use for Mochi. reuse, and specifies a subset of network transports to use for Mochi.
We have provided a pre-configured `packages.yaml` file for this purpose in We have provided a pre-configured `packages.yaml` file for this purpose
the JLSE environment. It primarily does the following: that is already tailored to the Summit environment. It primarily does
the following:
* informs Spack to use already available software for certain common system * informs Spack to use already available software for certain common system
packages (Spack by default will build these packages itself) packages (Spack by default will build these packages itself)
Markdown is supported
0% or .
Please register or to comment
