Commit 5df15cc4 authored by Philip Carns's avatar Philip Carns
add note
parent f5cc48c9
...@@ -34,6 +34,9 @@ Shutting down data_xfer server. ...@@ -34,6 +34,9 @@ Shutting down data_xfer server.
Alternatively, you can run the two services in the same executable, in which case the relay Alternatively, you can run the two services in the same executable, in which case the relay
will bypass the network layer of Mercury entirely. will bypass the network layer of Mercury entirely.
<NOTE: if one daemon is used to run both services, then data-xfer must be listed first in
the comma-separated list>
$ ./composed-svc-daemon na+sm:// data-xfer,delegator $ ./composed-svc-daemon na+sm:// data-xfer,delegator
Markdown is supported
0% or
Please register or to comment
