Commit 3542c123 authored by Matthieu Dorier's avatar Matthieu Dorier
Browse files
first version, file-based
parent 381c3ba8
# general cmake flags:
# -DCMAKE_INSTALL_PREFIX=/usr/local -- the prefix for installing
# -DCMAKE_BUILD_TYPE=type -- type can be Debug, Release, ...
# -DCMAKE_PREFIX_PATH=/dir -- external packages
# note that CMAKE_PREFIX_PATH can be a list of directories:
# -DCMAKE_PREFIX_PATH='/dir1;/dir2;/dir3'
cmake_minimum_required (VERSION 3.0)
project (hepnos CXX)
enable_testing ()
# add our cmake module directory to the path
set (CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH}
"${CMAKE_CURRENT_SOURCE_DIR}/cmake")
# link shared lib with full rpath
set (CMAKE_INSTALL_RPATH "${CMAKE_INSTALL_PREFIX}/lib")
set (CMAKE_INSTALL_RPATH_USE_LINK_PATH TRUE)
# setup cache variables for ccmake
if (NOT CMAKE_BUILD_TYPE)
set (CMAKE_BUILD_TYPE Release
CACHE STRING "Choose the type of build." FORCE)
set_property (CACHE CMAKE_BUILD_TYPE PROPERTY STRINGS
"Debug" "Release" "RelWithDebInfo" "MinSizeRel")
endif ()
set (CMAKE_PREFIX_PATH "" CACHE STRING "External dependencies path")
set (BUILD_SHARED_LIBS "OFF" CACHE BOOL "Build a shared library")
include_directories(${CMAKE_CURRENT_SOURCE_DIR}/include)
# packages we depend on
include (xpkg-import)
find_package (mercury CONFIG REQUIRED)
find_package (Boost REQUIRED COMPONENTS serialization filesystem)
include_directories(${Boost_INCLUDE_DIRS})
xpkg_import_module (margo REQUIRED margo)
add_subdirectory (src)
add_subdirectory (test)
# xpkg-import.cmake cmake import for "pkg-config" based packages
# 11-Aug-2016 chuck@ece.cmu.edu
# have PkgConfig use CMAKE_PREFIX_PATH for searching for pkg config files.
# this is the default for cmake 3.1 and above, on some older versions
# you can turn it on. otherwise you'll have to manually set PKG_CONFIG_PATH
if (${CMAKE_MINIMUM_REQUIRED_VERSION} VERSION_LESS 3.1)
set (PKG_CONFIG_USE_CMAKE_PREFIX_PATH 1)
endif ()
find_package(PkgConfig REQUIRED)
# PkgConfig in newer versions of cmake (>= cmake 3.6) supports imported
# targets, but older versions do not. if we have 3.6 or better, use
# the builtin imported target unless ${OLD_XPKGIMPORT} is defined.
# otherwise use the Sam Thursfield code below...
if (${CMAKE_VERSION} VERSION_LESS 3.6)
set (OLD_XPKGIMPORT 1) # can also set on cmdline -DOLD_XPKGIMPORT=1
endif ()
if (NOT OLD_XPKGIMPORT)
# xpkg_import_module(name args)
# create an imported target named "name" from a pkg-config module.
# all remaining args are passed through to pkg_check_module().
# example:
# xpkg_import_module(glog::glog REQUIRED libglog>=3.0)
message (STATUS "note: using built-in pkg_check_module imported targets")
function (xpkg_import_module name)
if (NOT TARGET ${name})
# PkgConfig only adds PREFIX_PATH to PKG_CONFIG_PATH.
# seems like it should add INSTALL_PREFIX too, so we do it here.
# (this doesn't impact the parent variable scope.)
if (CMAKE_INSTALL_PREFIX)
list (APPEND CMAKE_PREFIX_PATH ${CMAKE_INSTALL_PREFIX})
endif ()
# generate a namespace to put results of pkg_check_modules in.
# newer versions of PkgConfig don't like this to have ":" in it,
# so filter them out...
string (REPLACE ":" "_" cleanname ${name})
set (prefix _${cleanname})
pkg_check_modules("${prefix}" IMPORTED_TARGET ${ARGN})
if (${prefix}_FOUND)
add_library(${name} INTERFACE IMPORTED)
set_property (TARGET ${name} PROPERTY
INTERFACE_LINK_LIBRARIES PkgConfig::${prefix})
endif ()
endif ()
endfunction ()
else (NOT OLD_XPKGIMPORT)
# BEGIN:
# pkg-config stuff adapted from https://cmake.org/Bug/view.php?id=15804
# by Sam Thursfield <sam.thursfield@codethink.co.uk>
#.rst:
# PkgImportModule
# CMake commands to create imported targets from pkg-config modules.
# Copyright 2016 Lautsprecher Teufel GmbH
# Distributed under the OSI-approved BSD License (the "License");
# see accompanying file Copyright.txt for details.
# This software is distributed WITHOUT ANY WARRANTY; without even the
# implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
# See the License for more information.
# (To distribute this file outside of CMake, substitute the full
# License text for the above reference.)
# xpkg_import_module(<name> args)
# Creates an imported target named <name> from a pkg-config module. All
# remaining arguments are passed through to pkg_check_module(). See the
# documentation of the FindPkgConfig module for information.
# Example usage:
# xpkg_import_module(Archive::Archive REQUIRED libarchive>=3.0)
# xpkg_import_module(Avahi::GObject REQUIRED avahi-gobject)
message (STATUS "note: using old xpkg_import_module imported targets")
function(xpkg_import_module name)
# seems like it should add INSTALL_PREFIX too, so we append
# it here (doesn't impact parent scope).
endif ()
pkg_check_modules("${prefix}" ${ARGN})
_xpkg_import_module_add_imported_target(
${name}
"${${prefix}_CFLAGS_OTHER}"
"${${prefix}_INCLUDE_DIRS}"
"${${prefix}_LIBRARY_DIRS}"
"${${prefix}_LIBRARIES}"
"${${prefix}_STATIC_LIBRARIES}"
endif ()
endfunction()
# create imported target using info from pkg_check_modules
function(_xpkg_import_module_add_imported_target name compile_options include_dirs library_dirs libraries staticlibraries)
# We must pass in the absolute paths to the libraries, otherwise, when
# the library is installed in a non-standard prefix the linker won't be
# able to find the libraries. CMake doesn't provide a way for us to keep
# track of the library search path for a specific target, so we have to
# do it this way.
_xpkg_import_module_find_libraries(libraries_full_paths
${name} "${libraries}" "${library_dirs}")
list(GET libraries_full_paths 0 imported_location)
if (${imported_location} MATCHES ".a$")
# unix guess
add_library(${name} STATIC IMPORTED)
# XXXCDC
# static libs do not contain their depends, so we need to fetch
# them again for additional libs that are in ${staticlibraries}.
# we do this by calling _xpkg_import_module_find_libraries() again.
# libs found in the previous call should already be in the cache
# due to earlier calls to find_library() so this should not slow
# us down that much... (this call will update
# ${libraries_full_paths})
${name} "${staticlibraries}" "${library_dirs}")
else ()
# FIXME: we should really detect whether it's SHARED or STATIC,
# instead of assuming SHARED. We can't just use UNKNOWN because
# nothing can link against it then.
add_library(${name} SHARED IMPORTED)
endif ()
# gen INTERFACE_LINK_LIBRARIES, it doesn't need the first entry on
# the list since that is already in ${imported_location}
set (if_link_libs ${libraries_full_paths})
list (LENGTH if_link_libs n_iflinks)
if (n_iflinks GREATER 0)
list (REMOVE_AT if_link_libs 0) # remove item 0 from list
endif ()
set_target_properties(${name} PROPERTIES
IMPORTED_LOCATION ${imported_location}
INTERFACE_COMPILE_OPTIONS "${compile_options}"
INTERFACE_INCLUDE_DIRECTORIES "${include_dirs}"
INTERFACE_LINK_LIBRARIES "${if_link_libs}"
endfunction()
# convert list of lib names and dirs into list of library files using
# find_library()
function(_xpkg_import_module_find_libraries output_var prefix library_names library_dirs)
foreach(libname ${library_names})
# find_library stores its result in the cache, so we must pass
# a unique variable name for each library that we look for.
set(library_path_var "${prefix}_LIBRARY_${libname}")
find_library(${library_path_var} ${libname} PATHS ${library_dirs})
mark_as_advanced (${library_path_var})
list(APPEND library_paths "${${library_path_var}}")
endforeach()
set(${output_var} ${library_paths} PARENT_SCOPE)
endfunction()
# xadd_object_library_dependencies(<name> <dep1> [<dep2> ...])
# This is a workaround for <http://public.kitware.com/Bug/view.php?id=14778>.
# It should be possible to delete this function and use target_link_libraries()
# as normal once that is fixed.
function(xadd_object_library_dependencies object_library)
set(dependencies ${ARGN})
foreach(dependency ${dependencies})
if(NOT TARGET ${dependency})
message(FATAL_ERROR
"xadd_object_library_dependencies(): ${dependency} is not "
"a target.")
endif()
target_compile_definitions(
${object_library} PUBLIC
$<TARGET_PROPERTY:${dependency},INTERFACE_COMPILE_DEFINITIONS>)
target_compile_options(
$<TARGET_PROPERTY:${dependency},INTERFACE_COMPILE_OPTIONS>)
target_include_directories(
$<TARGET_PROPERTY:${dependency},INTERFACE_INCLUDE_DIRECTORIES>)
endforeach()
set_property(TARGET ${object_library}
APPEND PROPERTY LINK_LIBRARIES ${dependencies})
endfunction()
# END
endif (NOT OLD_XPKGIMPORT)
# some of the packages we want to import come with either "pkg-config"
# .pc files or with cmake config files, depending on how they were
# installed. for example, glog installed with "apt-get install" on
# "libgoogle-glog-dev" puts in a "libglog.pc" while installing glog
# from source via github installs a cmake config file for glog.
# this is complicated by the fact that the pkg-config .pc file names
# the package "libglog" while the cmake config file from github defines
# a library target "glog::glog" that you load with find_package(glog).
# we'd like to be able to use either mechanism to find glog, and we'd
# like the resulting target name to match between the two mechanisms
# (i.e. we just want to use "glog::glog" for both cases).
# to address this we add a wrapper function that trys both way.
# we first use "find_package()" in hopes of picking up a cmake config.
# if that fails, we fall back to "xpkg_import_module()"...
# xdual_import(names)
# Where "names" is: target-name,find-package-name,xpkg-names
# names can be omitted (target-name will be used)
# Example usage:
# xdual_import (foo REQUIRED)
# xdual_import (glog::glog,glog,libglog REQUIRED)
function (xdual_import names)
# parse spec
set (resid ${names})
foreach (var target cm_pkg)
string (FIND "${resid}" "," slash)
if (${slash} EQUAL -1)
set (${var} ${resid})
set (resid "")
else ()
math (EXPR slashplus ${slash}+1)
string (SUBSTRING "${resid}" 0 ${slash} ${var})
string (SUBSTRING "${resid}" ${slashplus} -1 resid)
endif ()
if ("${${var}}" STREQUAL "")
set (${var} ${target})
endif ()
endforeach ()
if ("${resid}" STREQUAL "")
set (xpkg ${target})
else ()
set (xpkg ${resid})
endif ()
# try to find it both ways
if (NOT TARGET ${target})
find_package (${cm_pkg} QUIET)
string (REPLACE "," " " xpkg "${xpkg}")
xpkg_import_module (${target} ${ARGN} ${xpkg})
endif ()
endif ()
endfunction ()
#ifndef __HEPNOS_FILE_DATASTORE_H
#define __HEPNOS_FILE_DATASTORE_H
#include <string>
#include <iterator>
#include <boost/filesystem.hpp>
#include <hepnos/FileNamespace.hpp>
namespace hepnos {
namespace fs = boost::filesystem;
class FileDataStore {
public:
typedef FileNamespace namespace_type;
typedef FileRun run_type;
typedef FileSubRun subrun_type;
typedef FileEvent event_type;
FileDataStore(const std::string path)
: _path(path) {
if(_path.empty()) _path = "./";
if(_path.back() != '/') _path += std::string("/");
fs::create_directories(_path);
fs::create_directory(_path+std::string(".ref"));
namespace_type createNamespace(const std::string& name) {
std::string dir = _path + name;
if(fs::is_directory(dir))
return FileNamespace(name, dir);
fs::create_directory(dir);
namespace_type openNamespace(const std::string& name) {
else
return FileNamespace();
private:
std::string _path;
#endif
#ifndef __HEPNOS_FILE_EVENT_H
#define __HEPNOS_FILE_EVENT_H
#include <string>
#include <limits>
#include <hepnos/FileProductAccessorBackend.hpp>
#include <hepnos/FileObjectIterator.hpp>
#include <hepnos/ProductAccessor.hpp>
namespace hepnos {
class FileSubRun;
class FileEvent : public ProductAccessor<FileProductAccessorBackend> {
private:
friend class FileSubRun;
friend class FileObjectIterator<FileEvent>;
void createRefAndSetID() {
std::size_t h = std::hash<std::string>()(_path);
std::string linkName;
std::stringstream ss;
do {
ss.str("");
ss << _path << "../../../../.ref/";
ss << std::setfill('0') << std::setw(20) << h;
h += 1;
} while(fs::exists(ss.str()));
_eventID = h-1;
fs::create_symlink(_path, ss.str());
FileEvent(std::uint64_t eventNumber, const std::string& dir)
: ProductAccessor<FileProductAccessorBackend>(dir)
, _eventNumber(eventNumber)
, _path(dir) {
createRefAndSetID();
FileEvent()
: ProductAccessor<FileProductAccessorBackend>("")
, _eventNumber(std::numeric_limits<std::uint64_t>::max())
, _path("") {}
std::uint64_t _eventNumber;
std::string _path;
std::size_t _eventID;
public:
std::uint64_t getEventNumber() const {
return _eventNumber;
std::size_t getEventID() const {
return _eventID;
bool isValid() const {
return _eventNumber != std::numeric_limits<std::uint64_t>::max();
#endif
#ifndef __HEPNOS_FILE_NAMESPACE_H
#define __HEPNOS_FILE_NAMESPACE_H
#include <string>
#include <iomanip>
#include <hepnos/FileRun.hpp>
namespace hepnos {
class FileDataStore;
class FileNamespace {
friend class FileDataStore;
private:
std::string _name;
std::string _path;
FileNamespace(const std::string& name, const std::string& dir)
: _name(name), _path(dir+std::string("/")) {}
FileNamespace() {}
public:
typedef FileObjectIterator<FileRun> iterator;
const std::string& getName() const {
return _name;
return !_name.empty();
FileRun createRun() {
fs::directory_iterator begin(_path), end;
size_t runNumber = std::count_if(begin, end,
[](const fs::directory_entry& d) {
return fs::is_directory(d.path());
ss << _path << std::setfill('0') << std::setw(12) << runNumber << "/";
std::string dir = ss.str();
return FileRun(runNumber, dir);
FileRun openRun(std::uint64_t runNumber) {
else
return FileRun();
std::size_t numRuns() const {
return std::count_if(begin, end,
iterator begin() {
return iterator(_path,0,numRuns());
iterator end() {
auto n = numRuns();
return iterator(_path,n,n);
#endif
#ifndef __HEPNOS_FILE_OBJECT_ITERATOR_H
#define __HEPNOS_FILE_OBJECT_ITERATOR_H
namespace hepnos {
template<typename T>
class FileObjectIterator {
private:
std::string _path;
std::uint64_t _numObjects;
std::uint64_t _currentIdx;
T _current;
public:
FileObjectIterator(const std::string& path, std::uint64_t idx, std::uint64_t nobj)
: _path(path), _numObjects(nobj), _currentIdx(idx) {
if(_currentIdx != _numObjects) {
ss << _path << std::setfill('0') << std::setw(12) << _currentIdx << "/";
_current = T(_currentIdx, ss.str());
bool operator==(const FileObjectIterator& other) const {
return _path == other._path
&& _currentIdx == other._currentIdx
&& _numObjects == other._numObjects;
bool operator!=(const FileObjectIterator& other) const {
return !(*this == other);
const T& operator*() const {
return _current;
const T* operator->() const {
return &_current;
T* operator->() {
return &_current;
FileObjectIterator operator++() {
FileObjectIterator old = *this;
_currentIdx += 1;
return old;
