Commit 522acb8e authored by Matthieu Dorier's avatar Matthieu Dorier
better comments
parent 7fa89b6a
...@@ -165,6 +165,11 @@ int bake_write( ...@@ -165,6 +165,11 @@ int bake_write(
* Writes data into a previously created BAKE region like bake_write(), * Writes data into a previously created BAKE region like bake_write(),
* except the write is performed on behalf of some remote entity. * except the write is performed on behalf of some remote entity.
* Note that by passing NULL as remote_addr, the server will assume
* that the hg_bulk_t sent comes from the caller of this function, which
* is a way to do a bake_write for a buffer for which an hg_bulk_t was
* already created.
* @param [in] provider provider handle * @param [in] provider provider handle
* @param [in] rid identifier for region * @param [in] rid identifier for region
* @param [in] region_offset offset into the target region to write * @param [in] region_offset offset into the target region to write
...@@ -218,6 +223,13 @@ int bake_create_write_persist( ...@@ -218,6 +223,13 @@ int bake_create_write_persist(
bake_region_id_t *rid); bake_region_id_t *rid);
* Issues a bake_create_write_persist on behalf of a remote entity (remote_addr)
* that previously sent an hg_bulk_t.
* is a way to do a bake_create_write_persist for a buffer for which an
* hg_bulk_t was already created.
* @param [in] bti BAKE target identifier * @param [in] bti BAKE target identifier
...@@ -304,6 +316,11 @@ int bake_read( ...@@ -304,6 +316,11 @@ int bake_read(
* Reads data from a previously persisted BAKE region like bake_read(), * Reads data from a previously persisted BAKE region like bake_read(),
* except the read is performed on behalf of some remote entity. * except the read is performed on behalf of some remote entity.
* is a way to do a bake_read for a buffer for which an hg_bulk_t was
* already created.
Markdown is supported
0% or
Please register or to comment
