Commit 8dc29263 authored by Philip Carns's avatar Philip Carns
Browse files
migrated
parent 81bdd17f
# abt-io Repository has migrated to https://github.com/mochi-hpc/mochi-abt-io/releases
abt-io provides Argobots-aware wrappers to common POSIX I/O
functions. The wrappers behave identically to their POSIX counterparts from
a caller's point of view, but internally they delegate I/O system calls to a
dedicated Argobots pool. The caller is suspended until the system call
completes so that other concurrent ULTs can make progress in the mean time.
If multiple I/O operations are issued at the same time then they will make
progress concurrently according to the number of execution streams assigned
to abt-io.
This library is a companion to the Margo library (which provides similar
capability, but for the Mercury RPC library). When used with Margo it
prevents RPC handlers (callbacks) from blocking on I/O operations, thereby
improving RPC throughput.
Margo: https://xgitlab.cels.anl.gov/sds/margo
## Dependencies
* argobots (https://github.com/pmodels/argobots)
## Building Argobots (dependency)
Example configuration:
../configure --prefix=/home/pcarns/working/install
## Building
../configure --prefix=/home/pcarns/working/install \
PKG_CONFIG_PATH=/home/pcarns/working/install/lib/pkgconfig \
CFLAGS="-g -Wall"
## Design details
![abt-io architecture](doc/fig/abt-io-diagram.png)
abt-io provides Argobots-aware wrappers to common POSIX I/O functions
like open(), pwrite(), and close(). The wrappers behave identically to
their POSIX counterparts from a caller's point of view, but internally
they delegate blocking I/O system calls to a dedicated Argobots pool.
The caller is suspended until the system call completes so that other
The delegation step is implemented by spawning a new tasklet that
coordinates with the calling ULT via an eventual construct. The tasklets
are allowed to block on system calls because they are executing on a
dedicated pool that has been designated for that purpose. This division
of responsibility between a request servicing pool and an I/O system
call servicing pool can be thought of as a form of I/O forwarding.
The use of multiple execution streams in the abt-io pool means that
multiple I/O operations can make asynchronous progress concurrently.
The caller can issue abt\_io calls from an arbitrary number of ULTs,
but the actual underying operations will be issued to the local file
system with a level of concurrency determined by the number of execution
streams in the abt-io pool. This is similar to aio functionality but with a
simpler interface and less serialization.
Markdown is supported
0% or .
Please register or to comment
