Commit e56d9b8f authored by Junchao Zhang's avatar Junchao Zhang Committed by Antonio J. Pena
Browse files
Implement new MPI_T routines to get vars/categories by name
The new routines are defined in upcoming MPI-3.1.
See https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/377
Signed-off-by: default avatarAntonio J. Pena <apenya@mcs.anl.gov>
parent cc25a421
...@@ -33,7 +33,10 @@ mpi_sources += \ ...@@ -33,7 +33,10 @@ mpi_sources += \
src/mpi_t/pvar_session_free.c \ src/mpi_t/pvar_session_free.c \
src/mpi_t/pvar_start.c \ src/mpi_t/pvar_start.c \
src/mpi_t/pvar_stop.c \ src/mpi_t/pvar_stop.c \
src/mpi_t/pvar_write.c src/mpi_t/pvar_write.c \
src/mpi_t/cat_get_index.c \
src/mpi_t/cvar_get_index.c \
src/mpi_t/pvar_get_index.c
mpi_core_sources += src/mpi_t/mpit.c mpi_core_sources += src/mpi_t/mpit.c
/* -*- Mode: C; c-basic-offset:4 ; indent-tabs-mode:nil ; -*- */
* (C) 2011 by Argonne National Laboratory.
* See COPYRIGHT in top-level directory.
#include "mpiimpl.h"
/* -- Begin Profiling Symbol Block for routine MPI_T_category_get_index */
#if defined(HAVE_PRAGMA_WEAK)
#pragma weak MPI_T_category_get_index = PMPI_T_category_get_index
#elif defined(HAVE_PRAGMA_HP_SEC_DEF)
#pragma _HP_SECONDARY_DEF PMPI_T_category_get_index MPI_T_category_get_index
#elif defined(HAVE_PRAGMA_CRI_DUP)
#pragma _CRI duplicate MPI_T_category_get_index as PMPI_T_category_get_index
#endif
/* -- End Profiling Symbol Block */
/* Define MPICH_MPI_FROM_PMPI if weak symbols are not supported to build
the MPI routines */
#ifndef MPICH_MPI_FROM_PMPI
#undef MPI_T_category_get_index
#define MPI_T_category_get_index PMPI_T_category_get_index
#endif /* MPICH_MPI_FROM_PMPI */
#undef FUNCNAME
#define FUNCNAME MPI_T_category_get_index
#undef FCNAME
#define FCNAME MPIU_QUOTE(FUNCNAME)
MPI_T_category_get_index - Get the index of a category
Output Parameters:
. name - the name of the category (string)
Output Parameters:
. cat_index - the index of the category (integer)
.N ThreadSafe
.N Errors
.N MPI_SUCCESS
.N MPI_T_ERR_INVALID_NAME
.N MPI_T_ERR_NOT_INITIALIZED
int MPI_T_category_get_index(const char *name, int *cat_index)
int mpi_errno = MPI_SUCCESS;
MPID_MPI_STATE_DECL(MPID_STATE_MPI_T_CATEGORY_GET_INDEX);
MPIR_ERRTEST_MPIT_INITIALIZED(mpi_errno);
MPIR_T_THREAD_CS_ENTER();
MPID_MPI_FUNC_ENTER(MPID_STATE_MPI_T_CATEGORY_GET_INDEX);
/* Validate parameters */
# ifdef HAVE_ERROR_CHECKING
MPID_BEGIN_ERROR_CHECKS
MPIR_ERRTEST_ARGNULL(name, "name", mpi_errno);
MPIR_ERRTEST_ARGNULL(cat_index, "cat_index", mpi_errno);
MPID_END_ERROR_CHECKS
# endif /* HAVE_ERROR_CHECKING */
/* ... body of routine ... */
name2index_hash_t *hash_entry;
/* Do hash lookup by the name */
HASH_FIND_STR(cat_hash, name, hash_entry);
if (hash_entry != NULL) {
*cat_index = hash_entry->idx;
} else {
mpi_errno = MPI_T_ERR_INVALID_NAME;
goto fn_fail;
/* ... end of body of routine ... */
fn_exit:
MPID_MPI_FUNC_EXIT(MPID_STATE_MPI_T_CATEGORY_GET_INDEX);
MPIR_T_THREAD_CS_EXIT();
return mpi_errno;
fn_fail:
goto fn_exit;
/* -- Begin Profiling Symbol Block for routine MPI_T_cvar_get_index */
#pragma weak MPI_T_cvar_get_index = PMPI_T_cvar_get_index
#pragma _HP_SECONDARY_DEF PMPI_T_cvar_get_index MPI_T_cvar_get_index
#pragma _CRI duplicate MPI_T_cvar_get_index as PMPI_T_cvar_get_index
#endif
the MPI routines */
#undef MPI_T_cvar_get_index
#define MPI_T_cvar_get_index PMPI_T_cvar_get_index
#undef FUNCNAME
#define FUNCNAME MPI_T_cvar_get_index
#undef FCNAME
MPI_T_cvar_get_index - Get the index of a control variable
Output Parameters:
. name - name of the control variable (string)
Output Parameters:
. cvar_index - index of the control variable (integer)
.N ThreadSafe
.N Errors
.N MPI_SUCCESS
int MPI_T_cvar_get_index(const char *name, int *cvar_index)
MPID_MPI_STATE_DECL(MPID_STATE_MPI_T_CVAR_GET_INDEX);
MPID_MPI_FUNC_ENTER(MPID_STATE_MPI_T_CVAR_GET_INDEX);
MPIR_ERRTEST_ARGNULL(cvar_index, "cvar_index", mpi_errno);
HASH_FIND_STR(cvar_hash, name, hash_entry);
*cvar_index = hash_entry->idx;
} else {
goto fn_fail;
fn_exit:
MPID_MPI_FUNC_EXIT(MPID_STATE_MPI_T_CVAR_GET_INDEX);
return mpi_errno;
fn_fail:
goto fn_exit;
/* -- Begin Profiling Symbol Block for routine MPI_T_pvar_get_index */
#pragma weak MPI_T_pvar_get_index = PMPI_T_pvar_get_index
#pragma _HP_SECONDARY_DEF PMPI_T_pvar_get_index MPI_T_pvar_get_index
#pragma _CRI duplicate MPI_T_pvar_get_index as PMPI_T_pvar_get_index
#endif
the MPI routines */
#undef MPI_T_pvar_get_index
#define MPI_T_pvar_get_index PMPI_T_pvar_get_index
#undef FUNCNAME
#define FUNCNAME MPI_T_pvar_get_index
#undef FCNAME
MPI_T_pvar_get_index - Get the index of a performance variable
Input Parameters:
. name - the name of the performance variable (string)
. var_class - the class of the performance variable (integer)
Output Parameters:
. pvar_index - the index of the performance variable (integer)
.N ThreadSafe
.N Errors
.N MPI_SUCCESS
int MPI_T_pvar_get_index(const char *name, int var_class, int *pvar_index)
MPID_MPI_STATE_DECL(MPID_STATE_MPI_T_PVAR_GET_INDEX);
MPID_MPI_FUNC_ENTER(MPID_STATE_MPI_T_PVAR_GET_INDEX);
MPIR_ERRTEST_ARGNULL(pvar_index, "pvar_index", mpi_errno);
if (var_class < MPIR_T_PVAR_CLASS_FIRST ||
var_class >= MPIR_T_PVAR_CLASS_LAST)
goto fn_fail;
int seq = var_class - MPIR_T_PVAR_CLASS_FIRST;
HASH_FIND_STR(pvar_hashs[seq], name, hash_entry);
*pvar_index = hash_entry->idx;
} else {
goto fn_fail;
fn_exit:
MPID_MPI_FUNC_EXIT(MPID_STATE_MPI_T_PVAR_GET_INDEX);
return mpi_errno;
fn_fail:
goto fn_exit;
Markdown is supported
0% or .
Please register or to comment
