Commit 8a9d5c71 authored by Charles J Archer's avatar Charles J Archer
Browse files
Compile time fixes to the latest rc of OpenFabrics Interfaces
parent 03b12134
...@@ -52,12 +52,11 @@ int MPID_nem_ofi_init(MPIDI_PG_t * pg_p, int pg_rank, char **bc_val_p, int *val_ ...@@ -52,12 +52,11 @@ int MPID_nem_ofi_init(MPIDI_PG_t * pg_p, int pg_rank, char **bc_val_p, int *val_
/* endpoint, so the netmod requires dynamic memory regions */ /* endpoint, so the netmod requires dynamic memory regions */
memset(&hints, 0, sizeof(hints)); memset(&hints, 0, sizeof(hints));
hints.mode = FI_CONTEXT; hints.mode = FI_CONTEXT;
hints.ep_type = FI_EP_RDM; /* Reliable datagram */ hints.ep_type = FI_EP_RDM; /* Reliable datagram */
hints.caps = FI_TAGGED; /* Tag matching interface */ hints.caps = FI_TAGGED; /* Tag matching interface */
hints.caps |= FI_BUFFERED_RECV; /* Buffered receives */ hints.caps |= FI_CANCEL; /* Support cancel */
hints.caps |= FI_CANCEL; /* Support cancel */ hints.caps |= FI_DYNAMIC_MR; /* Global dynamic mem region */
/* FI_VERSION provides binary backward and forward compatibility support */ /* FI_VERSION provides binary backward and forward compatibility support */
...@@ -83,12 +82,12 @@ int MPID_nem_ofi_init(MPIDI_PG_t * pg_p, int pg_rank, char **bc_val_p, int *val_ ...@@ -83,12 +82,12 @@ int MPID_nem_ofi_init(MPIDI_PG_t * pg_p, int pg_rank, char **bc_val_p, int *val_
hints.domain_attr = &domain_attr; hints.domain_attr = &domain_attr;
hints.tx_attr = &tx_attr; hints.tx_attr = &tx_attr;
FI_RC(fi_getinfo(fi_version, /* Interface version requested */ FI_RC(fi_getinfo(fi_version, /* Interface version requested */
NULL, /* Optional name or fabric to resolve */ NULL, /* Optional name or fabric to resolve */
NULL, /* Service name or port number to request */ NULL, /* Service name or port number to request */
0ULL, /* Flag: node/service specify local address */ 0ULL, /* Flag: node/service specify local address */
&hints, /* In: Hints to filter available providers */ &hints, /* In: Hints to filter available providers */
&prov_tagged), /* Out: List of providers that match hints */ &prov_tagged), /* Out: List of providers that match hints */
getinfo); getinfo);
MPIU_ERR_CHKANDJUMP4(prov_tagged == NULL, mpi_errno, MPI_ERR_OTHER, MPIU_ERR_CHKANDJUMP4(prov_tagged == NULL, mpi_errno, MPI_ERR_OTHER,
"**ofi_getinfo", "**ofi_getinfo %s %d %s %s", "**ofi_getinfo", "**ofi_getinfo %s %d %s %s",
...@@ -375,84 +374,15 @@ cvars: ...@@ -375,84 +374,15 @@ cvars:
static inline int dump_and_choose_providers(info_t * prov, info_t ** prov_use) static inline int dump_and_choose_providers(info_t * prov, info_t ** prov_use)
info_t *p = prov; info_t *p = prov;
int i = 0; int i = 0;
*prov_use = prov; *prov_use = prov;
if (MPIR_CVAR_DUMP_PROVIDERS) { if (MPIR_CVAR_DUMP_PROVIDERS) {
fprintf(stdout, "Dumping Providers(first=%p):\n", prov); fprintf(stdout, "Dumping Providers(first=%p):\n", prov);
while (p) { while(p) {
fprintf(stdout, " ********** Provider %d (%p) *********\n", i++, p); fprintf(stdout, "%s", fi_tostr(p, FI_TYPE_INFO));
fprintf(stdout, "%-18s: %-#20" PRIx64 "\n", "caps", p->caps); p=p->next;
fprintf(stdout, "%-18s: %-#20" PRIx64 "\n", "mode", p->mode);
fprintf(stdout, "%-18s: %-#20" PRIx32 "\n", "ep_type", p->ep_type);
fprintf(stdout, "%-18s: %-#20" PRIx32 "\n", "addr_format", p->addr_format);
fprintf(stdout, "%-18s: %-20lu\n", "src_addrlen", p->src_addrlen);
fprintf(stdout, "%-18s: %-20lu\n", "dest_addrlen", p->dest_addrlen);
fprintf(stdout, "%-18s: %-20p\n", "src_addr", p->src_addr);
fprintf(stdout, "%-18s: %-20p\n", "dest_addr", p->dest_addr);
fprintf(stdout, "%-18s: %-20p\n", "connreq", p->connreq);
fprintf(stdout, "%-18s: %-20p\n", "tx_attr", p->tx_attr);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".caps", p->tx_attr->caps);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".mode", p->tx_attr->mode);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".op_flags", p->tx_attr->op_flags);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".msg_order", p->tx_attr->msg_order);
fprintf(stdout, " %-18s: %-20lu\n", ".inject_size", p->tx_attr->inject_size);
fprintf(stdout, " %-18s: %-20lu\n", ".size", p->tx_attr->size);
fprintf(stdout, " %-18s: %-20lu\n", ".iov_limit", p->tx_attr->iov_limit);
fprintf(stdout, "%-18s: %-20p\n", "rx_attr", p->rx_attr);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".caps", p->rx_attr->caps);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".mode", p->rx_attr->mode);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".op_flags", p->rx_attr->op_flags);
fprintf(stdout, " %-18s: %-#20" PRIx64 "\n", ".msg_order", p->rx_attr->msg_order);
fprintf(stdout, " %-18s: %-20lu\n", ".total_buffered_recv",
p->rx_attr->total_buffered_recv);
fprintf(stdout, " %-18s: %-20lu\n", ".size", p->rx_attr->size);
fprintf(stdout, " %-18s: %-20lu\n", ".iov_limit", p->rx_attr->iov_limit);
fprintf(stdout, "%-18s: %-20p\n", "ep_attr", p->ep_attr);
fprintf(stdout, " %-18s: %-#20" PRIx32 "\n", ".protocol", p->ep_attr->protocol);
fprintf(stdout, " %-18s: %-20lu\n", ".max_msg_size", p->ep_attr->max_msg_size);
fprintf(stdout, " %-18s: %-20lu\n", ".inject_size", p->ep_attr->inject_size);
p->ep_attr->total_buffered_recv);
fprintf(stdout, " %-18s: %-20lu\n", ".max_order_raw_size",
p->ep_attr->max_order_raw_size);
fprintf(stdout, " %-18s: %-20lu\n", ".max_order_war_size",
p->ep_attr->max_order_war_size);
fprintf(stdout, " %-18s: %-20lu\n", ".max_order_waw_size",
p->ep_attr->max_order_waw_size);
fprintf(stdout, " %-18s: %-20lu\n", ".mem_tag_format",
p->ep_attr->mem_tag_format);
fprintf(stdout, " %-18s: %-20lu\n", ".msg_order", p->ep_attr->msg_order);
fprintf(stdout, " %-18s: %-20lu\n", ".tx_ctx_cnt", p->ep_attr->tx_ctx_cnt);
fprintf(stdout, " %-18s: %-20lu\n", ".rx_ctx_cnt", p->ep_attr->rx_ctx_cnt);
fprintf(stdout, "%-18s: %-20p\n", "domain_attr", p->domain_attr);
fprintf(stdout, " %-18s: %-20s\n", ".name", p->domain_attr->name);
fprintf(stdout, " %-18s: %-#20" PRIx32 "\n", ".threading",
p->domain_attr->threading);
fprintf(stdout, " %-18s: %-#20" PRIx32 "\n", ".control_progress",
p->domain_attr->control_progress);
fprintf(stdout, " %-18s: %-#20" PRIx32 "\n", ".data_progress",
p->domain_attr->data_progress);
fprintf(stdout, " %-18s: %-20lu\n", ".mr_key_size",
p->domain_attr->mr_key_size);
fprintf(stdout, " %-18s: %-20lu\n", ".cq_data_size",
p->domain_attr->cq_data_size);
fprintf(stdout, " %-18s: %-20lu\n", ".ep_cnt", p->domain_attr->ep_cnt);
p->domain_attr->tx_ctx_cnt);
p->domain_attr->rx_ctx_cnt);
fprintf(stdout, " %-18s: %-20lu\n", ".max_ep_tx_ctx",
p->domain_attr->max_ep_tx_ctx);
fprintf(stdout, " %-18s: %-20lu\n", ".max_ep_rx_ctx",
p->domain_attr->max_ep_rx_ctx);
fprintf(stdout, "%-18s: %-20p\n", "fabric_attr", p->fabric_attr);
fprintf(stdout, " %-18s: %-20s\n", ".name", p->fabric_attr->name);
fprintf(stdout, " %-18s: %-20s\n", ".prov_name", p->fabric_attr->prov_name);
fprintf(stdout, " %-18s: %-#20" PRIx32 "\n", ".prov_version",
p->fabric_attr->prov_version);
p = p->next;
return i; }
return i;
Markdown is supported
0% or .
Please register or to comment
