Commit 13995b9f authored by Ron Rahaman's avatar Ron Rahaman
Merge branch 'ci-short-runs' into 'develop'
Fewer timesteps for integration_example
See merge request nek5000/giraffe!3
parents b5acc7b0 e115e61a
Pipeline #3016 passed with stages
in 27 minutes and 7 seconds
...@@ -56,8 +56,8 @@ run_giraffe_serial_job: ...@@ -56,8 +56,8 @@ run_giraffe_serial_job:
script: script:
- cd examples/integration_example - cd examples/integration_example
- rm -f *sch integration_example_serial.stdout - rm -f *sch integration_example_serial.stdout
- ../../giraffe-opt -i coefficient_integration.i > integration_example_serial.stdout - ../../giraffe-opt -i coefficient_integration.i | tee integration_example_serial.stdout
- tail -n1000 integration_example_serial.stdout - exit $?
verify_giraffe_serial_job: verify_giraffe_serial_job:
stage: verify_giraffe_serial stage: verify_giraffe_serial
...@@ -88,8 +88,8 @@ run_giraffe_parallel_job: ...@@ -88,8 +88,8 @@ run_giraffe_parallel_job:
script: script:
- rm -f *sch integration_example_parallel.stdout - rm -f *sch integration_example_parallel.stdout
- mpirun -np 4 ../../giraffe-opt -i coefficient_integration.i > integration_example_parallel.stdout - mpirun -np 4 ../../giraffe-opt -i coefficient_integration.i | tee integration_example_parallel.stdout
- tail -n1000 integration_example_parallel.stdout - exit $?
verify_giraffe_parallel_job: verify_giraffe_parallel_job:
stage: verify_giraffe_parallel stage: verify_giraffe_parallel
...@@ -818,7 +818,7 @@ ...@@ -818,7 +818,7 @@
scheme = 'Explicit-Euler' # Others available: backward Euler, Crank-Nicholson, etc. scheme = 'Explicit-Euler' # Others available: backward Euler, Crank-Nicholson, etc.
dt = 0.001 # Initial timestep size dt = 0.001 # Initial timestep size
start_time = 0 # Starting time start_time = 0 # Starting time
num_steps = 1501 # Number of Steps num_steps = 50 # Number of Steps
nl_rel_tol = 1e-6 # Nonlinear relative tolerance nl_rel_tol = 1e-6 # Nonlinear relative tolerance
l_tol = 1e-6 # Linear tolerance l_tol = 1e-6 # Linear tolerance
...@@ -12,7 +12,7 @@ ...@@ -12,7 +12,7 @@
1.00000 p008 CONDUCT 1.00000 p008 CONDUCT
0.00000 p009 0.00000 p009
0.00000 p010 FINTIME 0.00000 p010 FINTIME
5000.000 p011 NSTEPS 50.000 p011 NSTEPS
-0.00100 p012 DT -0.00100 p012 DT
0.00000 p013 IOCOMM 0.00000 p013 IOCOMM
0.00000 p014 IOTIME 0.00000 p014 IOTIME
Markdown is supported
0%
or
Please register or to comment
