Commit 8fae897a authored by ylan's avatar ylan
Browse files
add 127k case
parent d63a569b
...@@ -9,9 +9,9 @@ Pebble bed, outer geometries: ...@@ -9,9 +9,9 @@ Pebble bed, outer geometries:
- ann = annulus - ann = annulus
- box = box - box = box
|cases| #peb | E | E/peb | p\_ratio1 | p\_ratio2 | |cases| #peb | E | E/peb | p\_ratio1 | p\_ratio2 | note |
| cyl146 | 146 | 62,132 | 425.56 | 91.95 | | cyl146 | 146 | 62,132 | 425.56 | 72.83 | | Rs=1.5 |
| box1053 | 1503 | 376,828 | 250.72 | 34.90 | | box1053 | 1503 | 376,828 | 250.72 | 34.90 |
| cyl1568 | 1568 | 524,386 | 334.43 | 55.32 | | cyl1568 | 1568 | 524,386 | 334.43 | 55.32 |
| cyl3260 | 3260 | 1,121,214 | 343.93 | 54.85 | | cyl3260 | 3260 | 1,121,214 | 343.93 | 54.85 |
...@@ -19,6 +19,7 @@ Pebble bed, outer geometries: ...@@ -19,6 +19,7 @@ Pebble bed, outer geometries:
| cyl11k | 11145 | 3,575,076 | 320.78 | 53.41 | | cyl11k | 11145 | 3,575,076 | 320.78 | 53.41 |
| cyl44k | 44257 | 13,032,440 | 294.47 | 51.32 | | cyl44k | 44257 | 13,032,440 | 294.47 | 51.32 |
| cyl49k | 49967 | 14,864,766 | 297.49 | 51.28 | | cyl49k | 49967 | 14,864,766 | 297.49 | 51.28 |
| cyl49k | 127602 | 39,240,190 | 307.52 | 51.39 |
**p_ratio1** is an upper estimate of the prosperity ratio computed by `(1 - Nsph*4/3*pi*r^3 / vol_geom)` where `vol_geom` is comptued by the `grep xyz` with zlen = (zmax-zmin-8) for 8=extruded length. The more pebbles, the more accurate this estimation is. **p_ratio1** is an upper estimate of the prosperity ratio computed by `(1 - Nsph*4/3*pi*r^3 / vol_geom)` where `vol_geom` is comptued by the `grep xyz` with zlen = (zmax-zmin-8) for 8=extruded length. The more pebbles, the more accurate this estimation is.
**p_ratio2** (WIP) is computed directly inside user file. **p_ratio2** (WIP) is computed directly inside user file.
## 127602 (non-touching) pebbles in an annulus cylinder (Last updated: Jan. 27, 2021)
ann127602 N, Version 3.2, E39,240,190
- New features (after Aug, 2020):
- fixed edge insert
- mesh smoother+optimizer in Nek5000
- tol adjustment in edge collapse
- Notes
- DEM data from Yiqi (StarCCM++?)
- smaller edge collapse tol depends on geom + few local locations
- Geometries, pebble locations are stored at `ann127k.dat`
- Geometry and BC in re2 file:
- linear mesh, no curved sides
- Sphere distribution: free-free (selected from some range in Z, free = non-flat)
- Sphere radius = 1.0 (Wall)
- Cylinder (inner) radius = 24.256 (W01, convert to Wall in production run)
- Cylinder (outer) radius = 87.895 (W02, convert to Wall in production run)
- Zbot of the cylinder = -27.010 (W03, convert to Inflow in production run)
- Ztop of the cylinder = -29.031 (W04, convert to Outflow in production run)
xyz min -87.895 -87.895 -27.010
xyz max 87.895 87.895 29.031
mesh metrics: (linear mesh)
GLL grid spacing min/max : 6.77E-04 3.52E-01
scaled Jacobian min/max/avg: 1.70E-02 9.99E-01 3.89E-01
aspect ratio min/max/avg: 1.05E+00 9.23E+01 1.58E+01
- Mesh file (`mshmesh_retry2.fld+X`)
- lx1=3 GLL points projected onto curved sides
- no issues for interpolation onto lx1=8 and mid-multigrid levels at lx1=4
- no issues for lx1=2 corase grid
- Production run
- Use re2 for boundary conditions, but use restart file for the curved mesh
- Time is NOT set to 0 when reading the mesh file, physical time = simulation time - 20.0
- We use dimless scale to run Re10000 with vz=1.0
- NekRS version (old)
commit 636fe6281c1db7e45ef0a223e16745bd0fb95a16
Author: Malachi <malachi2@illinois.edu>
Date: Mon Nov 2 09:08:19 2020 -0600
Time all reduce and copy to device in ellipticResidualProjection (#168)
- Runs (check `dat_logfiles`):
- run1
step= 1 t= 2.00000100e+01 dt=1.0e-05 C= 0.07
step= 1170 t= 2.00117000e+01 dt=1.0e-05 C= 0.07 U: 2 V: 2 W: 2 P: 15 eTime= 7.32e-01, 8.82609e+02 s
- run2
step= 1 t= 2.00100500e+01 dt=5.0e-05 C= 0.34
step= 6590 t= 2.03395000e+01 dt=5.0e-05 C= 0.35 U: 2 V: 2 W: 2 P: 12 eTime= 7.06e-01, 4.36998e+03 s
- run3
step= 1 t= 2.03101000e+01 dt=1.0e-04 C= 0.72
step= 3960 t= 2.07060000e+01 dt=1.0e-04 C= 0.84 U: 2 V: 2 W: 2 P: 45 eTime= 2.04e+00, 5.60561e+03 s
- run4
step= 1 t= 2.06103000e+01 dt=3.0e-04 C= 2.59
step= 4090 t= 2.18370000e+01 dt=3.0e-04 C= 3.66 U: 3 V: 3 W: 3 P: 120 eTime= 4.87e+00, 1.33436e+04 s
- run5 start using Pr-proj=F
step= 1 t= 2.18102000e+01 dt=2.0e-04 C= 1.91
step= 5740 t= 2.29580000e+01 dt=2.0e-04 C= 1.92 U: 2 V: 2 W: 3 P: 56 eTime= 2.29e+00, 1.31354e+04 s
- run6
step= 1 t= 2.28102000e+01 dt=2.0e-04 C= 1.89
step= 5580 t= 2.39260000e+01 dt=2.0e-04 C= 2.84 U: 3 V: 2 W: 3 P: 54 eTime= 2.45e+00, 1.31585e+04 s
- run7
step= 1 t= 2.38101000e+01 dt=1.0e-04 C= 1.21
step= 6430 t= 2.44530000e+01 dt=1.0e-04 C= 0.95 U: 2 V: 2 W: 2 P: 43 eTime= 2.07e+00, 1.30440e+04 s
- run8
step= 1 t= 2.44102000e+01 dt=2.0e-04 C= 2.10
step= 5090 t= 2.54280000e+01 dt=2.0e-04 C= 1.89 U: 2 V: 2 W: 3 P: 55 eTime= 2.76e+00, 1.31923e+04 s
// Boundary conditions
/* wall 1, inflow 2, outflow 3, x-slip 4, y-slip 5, z-slip 6 */
void insVelocityDirichletConditions3D(bcData *bc)
bc->uP = 0.0;
bc->vP = 0.0;
bc->wP = 1.0;
void insVelocityNeumannConditions3D(bcData *bc)
void cdsDirichletConditions3D(bcData *bc)
bc->sP = 0.0;
void cdsNeumannConditions3D(bcData *bc)
bc->sF = 1.0;
// Stabilized outflow (Dong et al)
void insPressureDirichletConditions3D(bcData *bc)
const dfloat iU0delta = 10.0;
const dfloat un = bc->uM*bc->nx + bc->vM*bc->ny + bc->wM*bc->nz;
const dfloat s0 = 0.5 * (1.0 - tanh(un*iU0delta));
bc->pP = -0.5 * (bc->uM*bc->uM + bc->vM*bc->vM + bc->wM*bc->wM) * s0;
[OCCA]
backend = CUDA
deviceNumber = 0
[GENERAL]
#verbose = true
polynomialOrder = 7
#startFrom = mshmesh_retry2.fld+X
startFrom = r8.fld
stopAt = numSteps
numSteps = 200000
dt = 2.0e-4
timeStepper = tombo2
extrapolation = subCycling
subCyclingSteps = 2
writeControl = TIMESTEP
writeInterval = 1000
filtering = hpfrt
filterWeight = 200
filterModes = 2
[PRESSURE]
#preconditioner = semg_amg
#amgSolver = parAlmond
#galerkinCoarseOperator = yes
residualTol = 1e-04
residualProj = false
[VELOCITY]
#solver = pcg+block
boundaryTypeMap = inlet, outlet, wall, wall
density = 1.0
viscosity = -10000.0
residualTol = 1e-06
#[TEMPERATURE]
#solver = none
#boundaryTypeMap = inlet, outlet, insulated, flux
#rhoCp = 1.0
#conductivity = -100
#residualTol = 1e-06
#[SCALAR01]
#solver = none
[BOOMERAMG]
#coarsenType = 10
#interpolationType = 6
#smootherType = -1
#iterations = 2 # testing
#strongThreshold = 0.25
#nonGalerkinTol = 0.1
// nekRS User Defined File
#include <math.h>
#include "udf.hpp"
/* UDF Functions */
void UDF_LoadKernels(ins_t *ins)
void UDF_Setup(ins_t *ins)
// get IC from nek
if (!ins->readRestartFile) nek_copyTo(ins->startTime);
void UDF_ExecuteStep(ins_t *ins, dfloat time, int tstep)
if (ins->isOutputStep) {
nek_ocopyFrom(time, tstep);
nek_userchk();
c-----------------------------------------------------------------------
subroutine uservp(i,j,k,eg) ! set variable properties
include 'SIZE'
include 'TOTAL'
include 'NEKUSE'
integer i,j,k,e,eg
c e = gllel(eg)
udiff = 0.0
utrans = 0.0
return
end
subroutine userf(i,j,k,eg) ! set acceleration term
c
c Note: this is an acceleration term, NOT a force!
c Thus, ffx will subsequently be multiplied by rho(x,t).
c
include 'SIZE'
include 'TOTAL'
include 'NEKUSE'
integer i,j,k,e,eg
c e = gllel(eg)
ffx = 0.0
ffy = 0.0
ffz = 0.0
return
end
subroutine userq(i,j,k,eg) ! set source term
include 'SIZE'
include 'TOTAL'
include 'NEKUSE'
integer i,j,k,e,eg
c e = gllel(eg)
qvol = 0.0
return
end
subroutine userbc(i,j,k,f,eg) ! set up boundary conditions
c NOTE ::: This routine MAY NOT be called by every process
include 'SIZE'
include 'TOTAL'
include 'NEKUSE'
integer i,j,k,f,e,eg
e=gllel(eg)
ux = 0.0
uy = 0.0
uz = 1.0
if (cbu.eq.'o ') then
U0 = 1.0 ! characteristic velocity
delta = 0.1 ! small positive constant
pa = dongOutflow(i,j,k,e,f,U0,delta)
endif
flux = 0.0
temp = 0.0
c if (cbc(f,e,1).eq.'W '.AND.cbc(f,e,2).eq.'t ') temp=1.0
if (cbc(f,e,1).eq.'W '.AND.cbc(f,e,2).eq.'f ') flux=1.0
return
end
subroutine useric(i,j,k,eg) ! set up initial conditions
include 'SIZE'
include 'TOTAL'
include 'NEKUSE'
integer i,j,k,e,eg
ux = 0.0
uy = 0.0
uz = 1.0
temp = 0.0
return
end
subroutine userchk
include 'SIZE'
include 'TOTAL'
integer icalld
save icalld
data icalld /0/
integer elist(lelt)
common /imy_fld/ elist
real ca,cb,cc,cd,tmp(lx1,ly1,lz1),tmp2(lx1,ly1,lz1),plmax,plmin
n=lx1*ly1*lz1*nelt
if (istep.eq.0) then
xxmax = glmax(xm1,n)
yymax = glmax(ym1,n)
zzmax = glmax(zm1,n)
xxmin = glmin(xm1,n)
yymin = glmin(ym1,n)
zzmin = glmin(zm1,n)
if (nio.eq.0) then
write(6,18) xxmin,yymin,zzmin
write(6,19) xxmax,yymax,zzmax
18 format(' xyz min ',5g13.5)
19 format(' xyz max ',5g13.5)
endif
ifxyo=.true.
endif
return
end
subroutine usrdat ! This routine to modify element vertices
include 'SIZE'
include 'TOTAL'
return
end
subroutine usrdat3
include 'SIZE'
include 'TOTAL'
return
end
subroutine usrdat2
include 'SIZE'
include 'TOTAL'
integer e,f
ifheat = .false.
nface = 2*ldim
do e=1,nelv
do f=1,nface
if(cbc(f,e,1).eq.'E '.or.cbc(f,e,1).eq.' ')then
cbc(f,e,1)='E '
cbc(f,e,2)='E '
elseif(cbc(f,e,1).eq.'W ')then ! pebbles
boundaryID(f,e) = 4
cbc(f,e,1)='W '
cbc(f,e,2)='f '
elseif(cbc(f,e,1).eq.'W01')then ! side of cylinder inner
boundaryID(f,e) = 3
cbc(f,e,1)='W '
cbc(f,e,2)='I '
elseif(cbc(f,e,1).eq.'W02')then ! side of cylinder outer
boundaryID(f,e) = 3
cbc(f,e,1)='W '
cbc(f,e,2)='I '
elseif(cbc(f,e,1).eq.'W03')then ! z_bottom
boundaryID(f,e) = 1
cbc(f,e,1)='v '
cbc(f,e,2)='t '
elseif(cbc(f,e,1).eq.'W04')then ! z_top
boundaryID(f,e) = 2
cbc(f,e,1)='o ' ! Dong's outflow
cbc(f,e,2)='O '
else
write(*,*)'bc incorrect',e,f,cbc(f,e,1)
endif
enddo
enddo
param(18) = 1 ! use algebraic residual norm
return
end
function dongOutflow(ix,iy,iz,iel,iside,u0,delta)
include 'SIZE'
include 'SOLN'
include 'GEOM'
real sn(3)
ux = vx(ix,iy,iz,iel)
uy = vy(ix,iy,iz,iel)
uz = vz(ix,iy,iz,iel)
call getSnormal(sn,ix,iy,iz,iside,iel)
vn = ux*sn(1) + uy*sn(2) + uz*sn(3)
S0 = 0.5*(1.0 - tanh(vn/u0/delta))
dongOutflow = -0.5*(ux*ux+uy*uy+uz*uz)*S0
return
end
subroutine comp_Reynolds
implicit none
include 'SIZE'
include 'TOTAL'
integer i,n,npeb
real Rcyl,Rpeb
real z0,z1,wd,fun_z,wt(lx1*ly1*lz1*lelv)
real zz,dis,glsum,glsc2
real wght_vol,area_peb,area_cyl1,area_cyl2,vz_bar,Dh1,Dh2
npeb = 1568
Rpeb = 1.0
Rcyl = 13.858
! min/max of pebble centers are -1.05733229e+01 1.15912238e+01
! f ------\
! o ) .
! P 1 | wd |
wd = 1.5
z0 = -10.573 - 1.0 - wd*0.5
z1 = 11.159 + 1.0 + wd*0.5
n=lx1*ly1*lz1*nelv
do i=1,n
zz=zm1(i,1,1,1)
if (zz>z1) then
dis = -abs(zz-z0)
elseif (zz>z0) then
dis = min(abs(z1-zz),abs(zz-z0))
else
dis = -abs(z0-zz)
endif
fun_z = tanh(dis*wd)
wt(i) = fun_z * bm1(i,1,1,1)
enddo
wght_vol = glsum(wt,n)
area_peb = npeb*4.0*pi*Rpeb*Rpeb
area_cyl1 = 2.0*Rcyl*pi*(z1-z0)
area_cyl2 = 2.0*Rcyl*pi*(z1-z0+wd)
vz_bar=glsc2(wt,vz,n)/wght_vol
Dh1 = 4.0*wght_vol/(area_peb+area_cyl1)
Dh2 = 4.0*wght_vol/(area_peb+area_cyl2)
if(nid.eq.0)then
write(*,1)z0,z1,wd,wght_vol
write(*,2)area_peb,area_cyl1,area_cyl2
write(*,3)time,vz_bar,Dh1,Dh2
endif
1 format('CompRe, domain',1p4e11.3)
2 format('CompRe, s_area',1p3e11.3)
3 format('CompRe, vz/Dh ',1p4e11.3)
return
end
#/bin/bash
: ${PROJ_ID:=""}
: ${NEKRS_HOME:="$HOME/.local/nekrs_repo1105"}
: ${OCCA_CACHE_DIR:="$PWD/.cache/occa"}
NVME_HOME="/mnt/bb/$USER/"
XL_HOME="/sw/summit/xl/16.1.1-3/xlC/16.1.1"
: ${CPUONLY:=0}
export NEKRS_HOME
export OCCA_CACHE_DIR
export NEKRS_HYPRE_NUM_THREADS=1
export OGS_MPI_SUPPORT=1
export OCCA_CXX="$XL_HOME/bin/xlc"
export OCCA_CXXFLAGS="-O3 -qarch=pwr9 -qhot -DUSE_OCCA_MEM_BYTE_ALIGN=64"
export OCCA_LDFLAGS="$XL_HOME/lib/libibmc++.a"
#export OCCA_VERBOSE=1
#export OMPI_LD_PRELOAD_POSTPEND=$OLCF_SPECTRUM_MPI_ROOT/lib/libmpitrace.so
#export PAMI_ENABLE_STRIPING=1
#export PAMI_IBV_ADAPTER_AFFINITY=1
#export PAMI_IBV_DEVICE_NAME="mlx5_0:1,mlx5_3:1"
#export PAMI_IBV_DEVICE_NAME_1="mlx5_3:1,mlx5_0:1"
if [ -z "$PROJ_ID" ]; then
echo "ERROR: PROJ_ID is empty"
exit 1
fi
if [ $# -ne 3 ]; then
echo "usage: [PROJ_ID] [CPUONLY=1] $0 <casename> <number of compute nodes> <hh:mm>"
exit 0
fi
module unload darshan-runtime
module load gcc
bin=$NEKRS_HOME/bin/nekrs
case=$1
nodes=$2
gpu_per_node=6
cores_per_socket=21
let nn=$nodes*$gpu_per_node
let ntasks=nn
time=$3
backend=CUDA
if [ $CPUONLY -eq 1 ]; then
backend=CPU
let nn=2*$nodes
let ntasks=$nn*$cores_per_socket
fi
if [ ! -f $bin ]; then
echo "Cannot find" $bin
exit 1
fi
if [ ! -f $case.par ]; then
echo "Cannot find" $case.par
exit 1
fi
if [ ! -f $case.co2 ]; then
echo "Cannot find" $case.co2
exit 1
fi
if [ ! -f $case.udf ]; then
echo "Cannot find" $case.udf
exit 1
fi
if [ ! -f $case.oudf ]; then
echo "Cannot find" $case.oudf
exit 1
fi
if [ ! -f $case.re2 ]; then
echo "Cannot find" $case.re2
exit 1
fi
mkdir -p $OCCA_CACHE_DIR 2>/dev/null
while true; do
read -p "Do you want precompile (recommended)? [N]" yn
case $yn in
[Yy]* )
echo $NEKRS_HOME
CUDA_VISIBLE_DEVICES=0 mpirun -pami_noib -np 1 $NEKRS_HOME/bin/nekrs --setup $case --build-only $ntasks --backend $backend;
if [ $? -ne 0 ]; then
exit 1
fi
break ;;
break ;;
esac
done
jsrun="jsrun -X 1 -n$nodes -r1 -a1 -c1 -g0 -b packed:1 -d packed cp -a $OCCA_CACHE_DIR/* $NVME_HOME; export OCCA_CACHE_DIR=$NVME_HOME; jsrun -X 1 -n$nn -a$cores_per_socket -c$cores_per_socket -g0 -b packed:1 -d packed $bin --setup $case --backend $backend"
else
jsrun="jsrun -X 1 -n$nodes -r1 -a1 -c1 -g0 -b packed:1 -d packed cp -a $OCCA_CACHE_DIR/* $NVME_HOME; export OCCA_CACHE_DIR=$NVME_HOME; jsrun --smpiargs='-gpu' -X 1 -n$nn -r$gpu_per_node -a1 -c2 -g1 -b rs -d packed $bin --setup $case --backend $backend --device-id 0"
fi
cmd="bsub -nnodes $nodes -alloc_flags NVME -W $time -P $PROJ_ID -J nekRS_$case \"${jsrun}\""
echo $cmd
echo $cmd > qq
$cmd
Markdown is supported
0% or .
Please register or to comment
