Commit 7e42c491 authored by Yu-Hsiang Lan's avatar Yu-Hsiang Lan
Browse files
Update README.md
parent 8fae897a
...@@ -19,7 +19,7 @@ Pebble bed, outer geometries: ...@@ -19,7 +19,7 @@ Pebble bed, outer geometries:
| cyl11k | 11145 | 3,575,076 | 320.78 | 53.41 | | cyl11k | 11145 | 3,575,076 | 320.78 | 53.41 |
| cyl44k | 44257 | 13,032,440 | 294.47 | 51.32 | | cyl44k | 44257 | 13,032,440 | 294.47 | 51.32 |
| cyl49k | 49967 | 14,864,766 | 297.49 | 51.28 | | cyl49k | 49967 | 14,864,766 | 297.49 | 51.28 |
| cyl49k | 127602 | 39,240,190 | 307.52 | 51.39 | | ann127k | 127602 | 39,240,190 | 307.52 | 51.39 |
**p_ratio1** is an upper estimate of the prosperity ratio computed by `(1 - Nsph*4/3*pi*r^3 / vol_geom)` where `vol_geom` is comptued by the `grep xyz` with zlen = (zmax-zmin-8) for 8=extruded length. The more pebbles, the more accurate this estimation is. **p_ratio1** is an upper estimate of the prosperity ratio computed by `(1 - Nsph*4/3*pi*r^3 / vol_geom)` where `vol_geom` is comptued by the `grep xyz` with zlen = (zmax-zmin-8) for 8=extruded length. The more pebbles, the more accurate this estimation is.
**p_ratio2** (WIP) is computed directly inside user file. **p_ratio2** (WIP) is computed directly inside user file.
Markdown is supported
0% or .
Please register or to comment
