Commit 653f6304 authored by Elia Merzari's avatar Elia Merzari
Browse files
Merge branch 'file-pebble-centers' into 'master'
Use points_file option for NearestPointAverage.
See merge request !10
parents de2b17a8 ff3429b6
This diff is collapsed.
...@@ -50,9 +50,9 @@ tolerance = 0.00 # Tolerance for pebbles univer ...@@ -50,9 +50,9 @@ tolerance = 0.00 # Tolerance for pebbles univer
radius_pebble_flibe = radius_pebble_outer+tolerance radius_pebble_flibe = radius_pebble_outer+tolerance
# Pebble centers coordinates (x,y,z) # Pebble centers coordinates (x,y,z)
print("Reading pseudo-random pebble centers from file pebble_centers.txt") print("Reading pseudo-random pebble centers from file pebble_centers_rescaled.txt")
pebble_centers = np.loadtxt('pebble_centers.txt', delimiter=' ') pebble_centers = np.loadtxt('pebble_centers_rescaled.txt', delimiter=' ')
print("File pebble_centers.txt reading completed") print("File pebble_centers_rescaled.txt reading completed")
# Vessel Dimensions # Vessel Dimensions
vessel_x, vessel_y = (0.0, 0.0) vessel_x, vessel_y = (0.0, 0.0)
...@@ -110,152 +110,6 @@ ...@@ -110,152 +110,6 @@
type = NearestPointAverage type = NearestPointAverage
variable = temp variable = temp
execute_on = 'initial timestep_end' # Evaluate on timestep end so OpenMC can get updated values next timestep execute_on = 'initial timestep_end' # Evaluate on timestep end so OpenMC can get updated values next timestep
points = '-8.065973074285714972e+00 2.236820423458646623e+00 1.168503152842105308e+01 points_file = 'pebble_centers_rescaled.txt'
-4.108761094736841812e+00 7.264663405714286704e+00 1.148013507969924873e+01
-8.190250614135338836e+00 -1.669100062556391206e+00 1.174674951699248204e+01
-5.017578366315789573e+00 -1.780129851428571497e+00 1.156140664421052655e+01
-1.650374663458646696e+00 -2.329395403308271106e+00 1.133625867067669191e+01
1.862428958796992662e+00 -5.195108160000000197e+00 1.142676995368421267e+01
-7.276481359398497162e+00 -4.216759513984962737e+00 1.377250198736842002e+01
-4.790481751578948177e+00 3.816866262857142811e+00 1.144549058165413591e+01
5.913748114285715118e-01 3.496824963609022952e+00 1.388699268812030319e+01
-3.332674473383458569e+00 1.220943688421052720e+00 1.254164748270676633e+01
-7.045073824962406306e+00 4.551014843909774399e+00 1.362872080962406152e+01
-1.954108067368421242e+00 8.099263701654134451e+00 1.366037387909774559e+01
-2.442635086917293030e+00 4.036775877293233172e+00 1.366037387909774559e+01
2.321954078796992782e+00 1.976863398496240709e+00 1.164948058105263229e+01
-4.371031218045112743e-01 4.113911711278195882e-01 1.339431273022556290e+01
-1.204804273082706878e+00 -5.375906580451127681e+00 1.187844322285714327e+01
4.231273053834586406e+00 -3.853785942857142821e+00 1.302805986045112796e+01
8.301819749774434598e+00 8.375287145864661609e-01 1.129925227669173005e+01
4.091046063157895429e-01 6.378547528421051993e+00 1.254724462556390918e+01
5.358109061052631183e+00 1.117410268872180312e+00 1.296784732150375774e+01
3.055512902255638874e+00 -9.682555813533835209e-01 1.250220342135338392e+01
7.199345503759398968e-01 -2.545482878796992754e+00 1.379743548270676712e+01
6.032339935037595247e+00 -1.611136421052631551e+00 1.146893719578947390e+01
-4.249328275488721829e+00 -4.628992590676691776e+00 1.272955814977443723e+01
-3.262119295037594124e+00 -7.700073123609022296e+00 1.283088735518797030e+01
5.441487702857143560e+00 -6.363833229473684128e+00 1.159813470676691871e+01
2.950657645714285682e+00 -7.807019704060151000e+00 1.289387935037593991e+01
3.491400732631579462e+00 5.551142201503759921e+00 1.259826765112781821e+01
-1.172474959398496219e-01 -8.344772167218046377e+00 1.240390993443608991e+01
8.304959289022555424e+00 -1.079901827368421108e+00 1.386601664481203144e+01
7.944992012030075657e+00 2.622618723609023039e+00 1.390710577804511416e+01
7.358425717894736984e+00 -3.938736599097745206e+00 1.318160614375939765e+01
6.598890900451128694e+00 5.125867997593984704e+00 1.262288587308270493e+01
-7.400317786466166226e-01 2.223469043007519019e+00 1.081451595067669302e+01
-1.867423167518796889e+00 5.140196423458647246e+00 1.076329776000000038e+01
2.490511687218044834e+00 7.952550756090225548e+00 1.081269631759398564e+01
-1.236599148270676629e+00 8.243005725112782400e+00 1.059267114586466185e+01
-7.095468454736843178e+00 -4.424456730225564627e+00 1.066665043488721842e+01
7.285327651127818660e-01 -5.268291645112781474e-01 1.036214385563909701e+01
5.007038508270676758e+00 3.281589217443609208e+00 1.065039062616541443e+01
-4.947073963308270983e+00 -6.729047436992482645e+00 1.036497467909774350e+01
-2.120261720300752106e+00 -8.076281918796993864e+00 9.935519418947370340e+00
-5.437722341052632302e+00 1.051229074285714438e+00 1.014711555248120334e+01
5.213936975639097859e+00 6.519832363308271539e+00 1.015162676571428690e+01
3.572533782857143070e+00 -2.921783722105263159e+00 1.003864377744360858e+01
1.663920003609022702e+00 4.730619876090225162e+00 1.017882627969924947e+01
1.886021503759398810e+00 -8.124411212030075546e+00 9.951542905263158545e+00
-3.685640293533835266e+00 -3.895882231578946975e+00 9.628868726616541807e+00
-2.518158279699248325e+00 6.397115909774436782e-02 9.479703222857144951e+00
4.235105059849623821e+00 3.675343181954887073e-01 9.772589633684209076e+00
7.126418591278195436e+00 -4.342682537142856347e+00 9.833584720601503903e+00
-8.342011524812029677e+00 2.082813040601503851e-01 9.238140093834585898e+00
-5.950863500751879975e+00 5.895005377443609085e+00 9.271530611729323468e+00
8.244475456240602185e+00 -1.464858229172932402e+00 9.232617148872179769e+00
-9.625496120300752745e-01 -5.275269571127820356e+00 8.877295283007518023e+00
-3.595474080000000239e+00 3.147738449323308707e+00 8.583448175639096789e+00
1.872605850225563806e+00 2.007630012631579142e+00 8.558087169924812443e+00
-7.644703882105264192e+00 3.351640771127819551e+00 8.679441538646617715e+00
4.575647801503759382e+00 -7.002747009924812360e+00 8.691659729323308881e+00
6.963510416842105144e+00 1.350765495338345890e+00 8.533391108571429129e+00
7.026851678796992573e+00 4.515084498045112582e+00 8.579821126015037436e+00
-5.016530122105263167e+00 -1.364844530526315713e+00 8.172900259849624760e+00
-3.428667215639097599e+00 7.615850039097744606e+00 8.389084013233082615e+00
5.636473335338346713e-01 7.064799056842105074e+00 8.261703197593984527e+00
-4.619242538345864624e-01 -2.261659521203007728e+00 8.086045299248119989e+00
-6.303907885714286063e-01 4.000298851127819688e+00 8.107978776541353128e+00
-7.875339071278195213e+00 -2.677839374436090214e+00 8.138632348872180344e+00
3.903554706766917182e+00 4.387745824962405727e+00 7.919806863157894838e+00
-6.361813844210526092e+00 -5.387853924812030293e+00 7.697013444812030869e+00
2.363079291428571427e+00 -9.440533425563910619e-01 7.643747007518798320e+00
-3.883201670977443509e+00 -7.365062807819549029e+00 7.426113978947369354e+00
3.638316588270676721e+00 7.523824092631579141e+00 7.585276716992481738e+00
-1.139308294736842142e-01 -8.334286282105262345e+00 7.496931204812030458e+00
5.013157227067670085e+00 -4.084452660451128203e+00 7.483439559699249344e+00
-6.864981978947368724e-01 1.013736996090225606e+00 7.084287132631579276e+00
-5.702905526616541820e+00 1.492095955488721870e+00 7.021743092932331010e+00
4.386988107067669063e+00 1.498693692631579033e+00 6.738174893233082940e+00
-3.016651734135338270e+00 -4.446158143759398662e+00 6.575180690526314820e+00
-2.485831109774435888e+00 5.300686985864662581e+00 5.871265172932331744e+00
-1.351379411729323410e+00 8.243042284511279405e+00 6.041501713082707781e+00
-2.710211747368421076e+00 -1.254646033082706946e+00 6.028808672481202890e+00
7.967707308270678690e-02 -5.596224898646616097e+00 5.891945514586465649e+00
-5.494808239398496497e+00 6.314841773233083266e+00 6.243261859849624784e+00
1.462926738045112973e+00 5.133970282105263294e+00 5.970177845413534357e+00
-8.327453644511278341e+00 -2.370449359398496270e-01 6.189384173233082542e+00
2.733243587368421323e+00 -7.880205192180451235e+00 6.247232221353383963e+00
5.841352994887217598e+00 5.968163151879699591e+00 5.963019572932330092e+00
8.348759162706766546e+00 -1.103825684210526237e-01 6.115168236992482242e+00
7.711771669172933663e+00 -3.205175808721804742e+00 6.133808925112782084e+00
7.793783693233084620e+00 2.954375321503759366e+00 5.941218875187970205e+00
-7.359727145864662035e+00 3.838532975639098233e+00 5.469066492631579735e+00
2.555186926917293544e+00 -3.340980721804511333e+00 5.621313419548872758e+00
5.128508058947368831e+00 -1.399891116992481255e+00 5.748621661353383594e+00
5.389944678496241259e+00 -6.387402236390977706e+00 5.385420086616541369e+00
1.676907064060150443e+00 8.168932886616541822e+00 5.188006231578947691e+00
-2.025178809022556425e+00 -8.084641847819549199e+00 4.983947112180451278e+00
7.423747163909775182e-01 -8.656667873684211756e-01 4.950941381052632373e+00
-7.436966739248120462e+00 -3.811048179248120338e+00 5.104909804511278182e+00
-5.448650739248121155e+00 -6.300931607819549640e+00 4.892984113082706088e+00
4.001048881804511126e+00 3.815975148270676964e+00 4.608533846616541751e+00
1.113800087819549089e+00 2.264923023157894733e+00 4.730310059548871848e+00
-2.048581609624060107e+00 2.481741921203008072e+00 4.617133273984962649e+00
-5.531780282706766805e+00 -6.945629485714286400e-01 4.782469995789473849e+00
-5.130775553684210344e+00 2.348205325714285863e+00 4.049563687218044272e+00
-3.566946640601504015e+00 7.500605258345864890e+00 3.980638401203008048e+00
-4.349532083007519034e+00 -3.494828448721804648e+00 3.903227274586466677e+00
8.789550315789474988e-01 -8.282310167819549207e+00 3.745045494135338604e+00
2.783515622255638977e+00 -5.795547139849624330e+00 3.697458644210525947e+00
-4.118811717293233143e-01 6.296173757593984455e+00 3.714335451428571577e+00
3.561181580751879849e+00 5.340659548872180862e-01 3.824344143157894838e+00
-8.189685625263159352e+00 1.608845994586466155e+00 3.539648066165413720e+00
4.241364166015038073e+00 7.168659374436090026e+00 3.589011360000000206e+00
-8.183563907368421653e+00 -1.517429922406015264e+00 3.211424358496240750e+00
6.998185375037595080e+00 -4.537632660451127897e+00 3.333644232180451361e+00
-1.847782264060150670e+00 -5.325928121503760160e+00 3.431325520601503865e+00
-6.148818716390977990e+00 5.603232194887217688e+00 3.260722361503759714e+00
8.179898324210526539e+00 -1.604828437894737059e+00 3.336550390375940367e+00
8.178593749172932803e+00 1.552982158195488793e+00 3.150945646917292731e+00
-1.818246680300751983e+00 -3.036155440601503996e-01 3.137262045112782172e+00
6.955264439097744500e+00 4.638992365714286414e+00 3.342759699248120331e+00
6.860023651127818978e-01 -3.426345336541353870e+00 3.105425388270676823e+00
4.337285792481202940e+00 -2.859118866766916955e+00 3.104987942255639677e+00
-3.181971482706767329e+00 4.610864246616541706e+00 2.692303030375939876e+00
2.178972241804511434e+00 5.110024735037594468e+00 2.362699658345864595e+00
-6.763637453233083185e+00 -4.900708648421052693e+00 2.359236332030075545e+00
-4.210563969924812078e+00 -7.188684956390978265e+00 2.119734929323308315e+00
1.332892554586466050e+00 -4.000238905263157618e-01 1.876511133834586786e+00
4.983688637593984616e+00 2.674637485714285834e+00 1.837798892030074960e+00
-3.882441527819548988e-01 2.252196014436090188e+00 1.901691046015037800e+00
5.786137378646617258e+00 -3.756968517293232668e-01 1.829254686315789691e+00
-1.291032458345864775e+00 -8.230331927819548810e+00 1.407082051127819478e+00
-1.559318645413533932e+00 8.177299755789475100e+00 1.486889987368421151e+00
-2.029652134736842140e+00 -2.881886078796992212e+00 1.469854209924812194e+00
-3.469649734736842461e+00 1.721376613533834643e+00 1.301245378646616491e+00
3.227581136842105902e-01 -5.648267007518796845e+00 8.480393936842104408e-01
2.474478878796992465e+00 -7.961366833082708538e+00 1.063221697443609060e+00
-7.477229658947369018e+00 3.604132280300751834e+00 1.245090886015037590e+00
-4.437924079398496424e+00 7.046885507368421564e+00 8.480393936842104408e-01
4.841371723308270703e+00 6.643437863458646397e+00 4.834029618045113663e-01
-6.724127386466166589e-01 5.244819367218044981e+00 7.177464252631579056e-01
-8.257228435488721985e+00 6.186197196992481162e-01 6.891657780451128090e-01
6.132404181654135478e+00 -3.846200867368421150e+00 4.651844030075187875e-01
2.083285898345864862e+00 -5.036898178646616486e+00 8.289085436390976724e+00
5.188124881804511368e+00 -6.529300016842105592e+00 1.814257270375940090e+00
-5.577345621654135499e+00 -5.983219488721804868e-01 1.714640037293233332e+00
1.527366279699248208e+00 8.193179978345865422e+00 2.094158479398496198e+00
...@@ -186,152 +186,6 @@ ...@@ -186,152 +186,6 @@
...@@ -30,155 +30,8 @@ ...@@ -30,155 +30,8 @@
power = 1460 # 1000 per pebble power = 1460 # 1000 per pebble
tally_type = 'cell' tally_type = 'cell'
mesh_template = 'sphere.e' mesh_template = 'sphere.e'
centers = '-8.065973074285714972e+00 2.236820423458646623e+00 1.168503152842105308e+01 centers_file = 'pebble_centers_rescaled.txt'
-4.108761094736841812e+00 7.264663405714286704e+00 1.148013507969924873e+01 volumes = '14.137166941154067'
# volumes = '14.137166941154067 14.137166941154067'
volumes = '14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067 14.137166941154067'
[Executioner] [Executioner]
...@@ -76,153 +76,7 @@ ...@@ -76,153 +76,7 @@
