Commit 009860fe authored by Patrick Shriwise's avatar Patrick Shriwise
Browse files
Updating OpenMC model.
parent 98b54bae
This source diff could not be displayed because it is too large. You can view the blob instead.
<?xml version='1.0' encoding='utf-8'?> <?xml version='1.0' encoding='utf-8'?>
<materials> <materials>
<material depletable="true" id="1" name="m_fuel - uranium oxycarbide - triso particles"> <material depletable="true" id="1" name="m_fuel - uranium oxycarbide - triso partciles">
<density units="g/cm3" value="10.5" /> <density units="g/cm3" value="10.5" />
<nuclide name="U234" wo="0.03565284" /> <nuclide name="U234" wo="0.03565284" />
<nuclide name="U235" wo="17.790767159999998" /> <nuclide name="U235" wo="17.790767159999998" />
...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
<nuclide name="O16" wo="8.616527990092724" /> <nuclide name="O16" wo="8.616527990092724" />
<nuclide name="O17" wo="0.003472009907274255" /> <nuclide name="O17" wo="0.003472009907274255" />
</material> </material>
<material id="2" name="m_graphite_c_buffer - triso particles"> <material id="2" name="m_graphite_c_buffer - triso partciles">
<density units="g/cm3" value="1.0" /> <density units="g/cm3" value="1.0" />
<nuclide ao="1.0" name="C0" /> <nuclide ao="1.0" name="C0" />
<sab name="c_Graphite" /> <sab name="c_Graphite" />
...@@ -19,7 +19,7 @@ ...@@ -19,7 +19,7 @@
<material id="4" name="sic - triso particles"> <material id="4" name="sic - triso partciles">
<density units="g/cm3" value="3.2" /> <density units="g/cm3" value="3.2" />
<nuclide ao="0.9222968" name="Si28" /> <nuclide ao="0.9222968" name="Si28" />
...@@ -60,10 +60,6 @@ print("Reading pebble centers from file {}...".format(pebble_centers_file), end= ...@@ -60,10 +60,6 @@ print("Reading pebble centers from file {}...".format(pebble_centers_file), end=
pebble_centers = np.loadtxt(pebble_centers_file, delimiter=' ') pebble_centers = np.loadtxt(pebble_centers_file, delimiter=' ')
print("Read {} pebble positions\n".format(len(pebble_centers))) print("Read {} pebble positions\n".format(len(pebble_centers)))
# Scale the pebble dimensions (radius of 1.0) to actual dimensions
for i in range(len(pebble_centers)):
pebble_centers[i] *= radius_pebble_outer
print(" Min pebble (center) z coordinate = {}".format(np.min(pebble_centers[:,2]))) print(" Min pebble (center) z coordinate = {}".format(np.min(pebble_centers[:,2])))
print(" Max pebble (center) z coordinate = {}".format(np.max(pebble_centers[:,2]))) print(" Max pebble (center) z coordinate = {}".format(np.max(pebble_centers[:,2])))
print(" Max pebble (center) r coordinate = {}".format(np.max(np.linalg.norm(pebble_centers[:, :-1], axis=1)))) print(" Max pebble (center) r coordinate = {}".format(np.max(np.linalg.norm(pebble_centers[:, :-1], axis=1))))
...@@ -2,8 +2,8 @@ ...@@ -2,8 +2,8 @@
<plots> <plots>
<plot basis="xy" color_by="material" filename="plot1" id="1" type="slice"> <plot basis="xy" color_by="material" filename="plot1" id="1" type="slice">
<origin>0 0 0</origin> <origin>0 0 0</origin>
<width>534.3792761548574 534.3792761548574</width> <width>271.5329013059741 271.5329013059741</width>
<pixels>2000 2000</pixels> <pixels>1000 1000</pixels>
<color id="1" rgb="165 42 42" /> <color id="1" rgb="165 42 42" />
<color id="2" rgb="176 196 222" /> <color id="2" rgb="176 196 222" />
<color id="3" rgb="0 0 255" /> <color id="3" rgb="0 0 255" />
...@@ -12,12 +12,50 @@ ...@@ -12,12 +12,50 @@
<color id="6" rgb="0 191 255" /> <color id="6" rgb="0 191 255" />
<color id="7" rgb="0 0 128" /> <color id="7" rgb="0 0 128" />
<color id="8" rgb="255 255 0" /> <color id="8" rgb="255 255 0" />
<color id="9" rgb="112 128 144" />
</plot> </plot>
<plot basis="xz" color_by="material" filename="plot2" id="2" type="slice"> <plot basis="xy" color_by="material" filename="plot2" id="2" type="slice">
<origin>0 0 0.19814939637825546</origin> <origin>0 0 1</origin>
<color id="4" rgb="255 165 0" />
<color id="5" rgb="0 255 255" />
</plot>
<plot basis="xy" color_by="material" filename="plot3" id="3" type="slice">
</plot>
<plot basis="xz" color_by="material" filename="plot4" id="4" type="slice">
<origin>0 0 0.13209959758550838</origin>
</plot>
<plot color_by="material" filename="plotv1" id="5" type="voxel">
<width>3.0 3.0 3.0</width>
<pixels>300 300 300</pixels>
...@@ -26,6 +64,5 @@ ...@@ -26,6 +64,5 @@
</plot> </plot>
</plots> </plots>
...@@ -5,15 +5,14 @@ ...@@ -5,15 +5,14 @@
<batches>250</batches> <batches>250</batches>
<inactive>50</inactive> <inactive>50</inactive>
<source strength="1.0"> <source strength="1.0">
<space type="box"> <space type="fission">
<parameters>-202.8996709794806 -202.8996709794806 -148.75708596932952 202.8996709794806 202.8996709794806 149.15338476208606</parameters> <parameters>-135.76645065298706 -135.76645065298706 -99.67139397955302 135.76645065298706 135.76645065298706 99.93559317472403</parameters>
</space> </space>
</source> </source>
<output> <output>
<summary>false</summary> <summary>false</summary>
<tallies>false</tallies>
</output> </output>
<temperature_default>573</temperature_default> <temperature_default>573.0</temperature_default>
<temperature_method>interpolation</temperature_method> <temperature_method>interpolation</temperature_method>
<temperature_multipole>true</temperature_multipole> <temperature_multipole>true</temperature_multipole>
<temperature_range>300.0 1500.0</temperature_range> <temperature_range>300.0 1500.0</temperature_range>
Markdown is supported
0% or .
Please register or to comment
