Commit 684c4d31 authored by Philip Carns's avatar Philip Carns
Browse files
simplify ross configure checks
parent 67e2834d
...@@ -65,24 +65,10 @@ AC_TRY_COMPILE([#include <mpi.h>], [int ret = MPI_Init(0, (void*)0)], ...@@ -65,24 +65,10 @@ AC_TRY_COMPILE([#include <mpi.h>], [int ret = MPI_Init(0, (void*)0)],
AC_MSG_ERROR(CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line.) AC_MSG_ERROR(CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line.)
# # get ROSS flags
# clear ROSS options
ROSS_CFLAGS=""
ROSS_CPPFLAGS=""
ROSS_LDFLAGS=""
ROSS_LIBS=""
ENABLE_ROSS=0
AC_ARG_WITH([ross],[AS_HELP_STRING([--with-ross@<:@=DIR@:>@], AC_ARG_WITH([ross],[AS_HELP_STRING([--with-ross@<:@=DIR@:>@],
[location of ROSS installation])]) [location of ROSS installation])])
# if we have ROSS, add ROSS flags
if test "x${with_ross}" != "x" ; then if test "x${with_ross}" != "x" ; then
ORIG_LDFLAGS="${LDFLAGS}"
ORIG_CPPFLAGS="${CPPFLAGS}"
ORIG_LIBS="${LIBS}"
ORIG_CFLAGS="${CFLAGS}"
checkpath="${with_ross}/bin" checkpath="${with_ross}/bin"
ROSS_CONFIG="" ROSS_CONFIG=""
...@@ -91,50 +77,15 @@ if test "x${with_ross}" != "x" ; then ...@@ -91,50 +77,15 @@ if test "x${with_ross}" != "x" ; then
AC_MSG_ERROR(ROSS not found at: $with_ross) AC_MSG_ERROR(ROSS not found at: $with_ross)
fi fi
if test "${ROSS_CONFIG}x" != "x" ; then ROSS_LDFLAGS=`${with_ross}/bin/ross-config --ldflags`
ROSS_CFLAGS=`${with_ross}/bin/ross-config --cflags`
LDFLAGS=`${with_ross}/bin/ross-config --ldflags` ROSS_CPPFLAGS=`${with_ross}/bin/ross-config --cflags`
CFLAGS=`${with_ross}/bin/ross-config --cflags` ROSS_LIBS=`${with_ross}/bin/ross-config --libs`
CPPFLAGS=`${with_ross}/bin/ross-config --cflags` AC_SUBST(ROSS_LDFLAGS)
LIBS=`${with_ross}/bin/ross-config --libs` AC_SUBST(ROSS_CFLAGS)
AC_SUBST(ROSS_CPPFLAGS)
ENABLE_ROSS=1 AC_SUBST(ROSS_LIBS)
AC_CHECK_LIB([ROSS],[tw_init],,[ENABLE_ROSS=;])
if test -z "$ENABLE_ROSS" ; then
ENABLE_ROSS=0
AC_MSG_ERROR([Could not find usable ROSS library])
fi
ENABLE_ROSS=1
# TODO this is weird... need to add -c back to CPPFLAGS or CHECK_HEADERS
# tries to compile an exe using a c file that includes ross.h and no
# main()
CPPFLAGS_2="${CPPFLAGS}"
CPPFLAGS="-c ${CPPFLAGS}"
AC_CHECK_HEADERS([ross.h], [], [ENABLE_ROSS=;])
ENABLE_ROSS=0
AC_MSG_ERROR([Could not find usable ross.h])
else
CPPFLAGS="${CPPFLAGS_2}"
checkpath="$PATH"
AC_SUBST([ROSS_LDFLAGS],["${LDFLAGS}"])
AC_SUBST([ROSS_CFLAGS],["${CFLAGS}"])
AC_SUBST([ROSS_CPPFLAGS],["${CPPFLAGS}"])
AC_SUBST([ROSS_LIBS],["${LIBS}"])
fi
CFLAGS="${ORIG_CFLAGS}"
CPPFLAGS="${ORIG_CPPFLAGS}"
LDFLAGS="${ORIG_LDFLAGS}"
LIBS="${ORIG_LIBS}"
AC_DEFINE([HAVE_ROSS],[1],[If ROSS is supported on target build platform])
fi
else else
ENABLE_ROSS=0
AC_MSG_ERROR([Could not find usable ROSS installation, try --with-ross=DIR]) AC_MSG_ERROR([Could not find usable ROSS installation, try --with-ross=DIR])
fi fi
Markdown is supported
0% or .
Please register or to comment
